Do you see the same with basically any pop-up dialog?
Application -> Utility -> File Browser, then use context menu to create “New Folder” or “Rename”, do those dialogs behave the same way?
On Linux, we use GTK, and can (for now) run with either GTK2 or GTK3. See
https://github.com/ControlSystemStudio/phoebus/wiki/JavaFX for adding the -Djdk.gtk.verbose=true option to see what you have, and adding -Djdk.gtk.version=2 or -Djdk.gtk.version=3 to select
a specific one.
Do they behave differently?
-Kay
Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Sinclair, John via Tech-talk <tech-talk at aps.anl.gov>
Date: Tuesday, June 13, 2023 at 12:28 PM
To: tech-talk <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Alarm Problem
I'm having a problem with alarm tree. When I right click and choose "Add Component", the app performs a grab of the keyboard and mouse with the following result:
No keyboard input is accepted from the alarm tree popup window (where I may select the type and content)
No Keyboard or mouse input is seen by other Phoebus applications or external applications
The only input accepted is using the mouse to select the type (node or pv/s) or clicking the cancel or OK button in the popup window but at this point no new content has been entered so nothing
may be added to the tree.
Has anyone seen anything like this?
I am accessing the system though vnc and see no other issues except for one that may be related. If I make a change in display builder
and exit without having already saved the change, I get a popup which allows me to save or discard changes but something has performed a keyboard and mouse grab and I have to kill the vnc session
from a terminal to recover.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.2 LTS
5.19.0-38-generic #39~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC
Phoebus commit - 0b4e47a760649775f926438e08301933e60a5ef5
- Re: Alarm Problem Kasemir, Kay via Tech-talk
- Alarm Problem Sinclair, John via Tech-talk
RE: AreaDetector ADFFmpeg with FFmpeg 5.1 Daykin, Evan via Tech-talk
<2023>
<2023>
ANJ, 15 Jun 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
