1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: RE: AreaDetector ADFFmpeg with FFmpeg 5.1
From: "Daykin, Evan via Tech-talk" <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 13 Jun 2023 17:08:26 +0000
I found the issue: AVPacket takes ownership of whatever memory is passed to it, and it is unref’d during the call to avcodec_receive_packet. I’ll need to figure out how to use ffmpeg’s custom memory-management callbacks to instead use NDArrayPool.
Sent: Monday, June 12, 2023 10:57 AM
To: Mark Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov
[EXTERNAL] This email originated from outside of FRIB
Hi Mark,
I am indeed working on this, but I’ve run into an issue I don’t quite understand.
In the actual codec bit of processCallbacks, the call to avcodec_encode_video2() is deprecated in favor of the decoupled send/receive avcodec_send_frame(AVFrame*)/avcodec_receive_packet(AVPacket*)(Relevant diff below).  So my intent is to do the following:
1.       Allocate block of memory for encoded frame using NDArrayPool
2.       Allocate an ffmpeg packet using ffmpeg
3.       Point ffmpeg packet data to the NDArrayPool allocated memory
4.       Send raw frame (scPicture) to the encoder for encoding w/avcodec_send_frame
5.       Pull encoded frame from encoder w/avcodec_receive_packet
6.       Encoded data ends up in this->jpeg
But, when I run this, there is no data returned from the server. If I instead maintain two blocks of memory, one maintained by ffmpeg’s memory pool and the other with AreaDetector, then memcpy the relevant data from ffmpeg to AD, everything works fine. However, I’d prefer if I can just pass around pointers to the same data.
     if (this->jpeg) {
         this->jpeg->release();
-    /* Convert it to a jpeg */
-    this->jpeg = this->pNDArrayPool->alloc(1, &size, NDInt8, 0, NULL);
-    AVPacket pkt;
-    int got_output;
-    av_init_packet(&pkt);
-    pkt.data = "" // packet data will be allocated by the encoder
-    pkt.size = c->width * c->height;
+    /* Convert it to a jpeg */
+    this->jpeg = this->pNDArrayPool->alloc(1, &size, NDInt8, 0, NULL);
+    //this->jpeg->reserve();
+    AVPacket* pkt = av_packet_alloc();
+    pkt->data = "">
+    pkt->size = c->width*c->height;
+    //pkt->buf = av_buffer_alloc(c->coded_width*c->coded_height);
     // needed to stop a stream of "AVFrame.format is not set" etc. messages
     scPicture->format = c->pix_fmt;
     scPicture->width = c->width;
     scPicture->height = c->height;
-    if (avcodec_encode_video2(c, &pkt, scPicture, &got_output)) {
+    int sts;
+    sts = avcodec_send_frame(c, scPicture);
+    char err[64];
+    if(sts) {
+        av_strerror(sts, err, 64*sizeof(char));
         asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
-            "%s:%s: Encoding jpeg failed\n",
-            driverName, functionName);
-        got_output = 0; // got_output is undefined on error, so explicitly set it for use later
+                  "%s%s: Encoding jpeg failed - %d - %s\n",
+                   driverName, functionName, sts, err);
-    if (got_output) {
-        this->jpeg->dims[0].size = pkt.size;
-        av_packet_unref(&pkt);
+    sts = avcodec_receive_packet(c,pkt);
+    if (sts){
+        asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
+                  "%s:%s: Recv packet failed - %d - %s\n",
+    this->jpeg->dims[0].size = pkt->size;
+    //memcpy(this->jpeg->pData, pkt->data, pkt->size);
     //printf("Frame! Size: %d\n", this->jpeg->dims[0].size);
     /* signal fresh_frame to output plugin and unlock mutex */
     for (int i=0; i<config.server_maxconn; i++) {
         pthread_cond_signal(&(this->cond[i]));
     pthread_mutex_unlock(&this->mutex);
+    av_packet_free(&pkt);
     /* We must enter the loop and exit with the mutex locked */
     this->lock();
     /* Update the parameters.  */
     callParamCallbacks(0, 0);
//    gettimeofday(&end, NULL);
Sent: Monday, June 5, 2023 11:35 AM
To: Daykin, Evan <daykin at frib.msu.edu>; tech-talk at aps.anl.gov
I don’t know of any ongoing work on this, so it would be great if you could do it.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Daykin, Evan via Tech-talk
Sent: Monday, June 5, 2023 10:15 AM
To: tech-talk at aps.anl.gov
Subject: AreaDetector ADFFmpeg with FFmpeg 5.1
Hi tech-talk,
We are in the process of updating our systems to Debian Bookworm. The currently available FFmpeg toolchain packages for Bookworm are on version 5.1. Are there any plans to update the ADFFmpeg plugin to support this? I’m currently trying to update our fork of the plugin, but I’m running into some hard-to-find runtime errors that I’m sure are some combination of my unfamiliarity with the new API, and the fact that I’m using the pre-built FFmpeg library without debug symbols. If there isn’t yet an existing effort to do this, I’m happy to start.
-Evan
Evan Daykin
Controls Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7678
Email: daykin at frib.msu.edu
AreaDetector ADFFmpeg with FFmpeg 5.1 Daykin, Evan via Tech-talk
RE: AreaDetector ADFFmpeg with FFmpeg 5.1 Mark Rivers via Tech-talk
RE: AreaDetector ADFFmpeg with FFmpeg 5.1 Daykin, Evan via Tech-talk
Prev: Re: Alarm Problem Kasemir, Kay via Tech-talk
Next: C++ std problem Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: RE: AreaDetector ADFFmpeg with FFmpeg 5.1 Daykin, Evan via Tech-talk
Next: Using Macros in the Alarm Tree Lloyd, Tate Wallace via Tech-talk
ANJ, 13 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
