1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: C++ std problem
From: "Wlodek, Jakub via Tech-talk" <tech-talk at aps.anl.gov>
To: "Pearson, Matthew" <pearsonmr at ornl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Mark Rivers <rivers at cars.uchicago.edu>
Date: Wed, 14 Jun 2023 15:23:14 +0000
Hi all,
Did some testing with this and was able to get ADPICam building with gcc 4.8.5 by adding a specialization to std::hash to handle the PicamParameter type (and the -std=c++11 flag):
I have submitted the change as a PR: https://github.com/areaDetector/ADPICam/pull/19
Best regards,
Jakub
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, June 14, 2023 9:56 AM
To: Pearson, Matthew <pearsonmr at ornl.gov>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
 Hi Matt,
  • Using enum for the hash was fixed in C++14, so for gcc 4.8.5 can you try this and see if it works?
  •  USR_CXXFLAGS_Linux += -std=c++1y
Thanks for the suggestion.  I tried using -std=c++1y, but the results are the same as -std=c++11.  It looks like ADPICam requires a newer version of gcc than 4.8.5.  CentOS 8 with gcc 8.5.0 works fine.
Sent: Tuesday, June 13, 2023 2:05 PM
To: Mark Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: RE: C++ std problem
Hi Mark,
Using std::hash with enum types (and PicamParameter is an enum) might be the issue:
https://stackoverflow.com/questions/18837857/cant-use-enum-class-as-unordered-map-key
The Galil driver declares a map like:
std::unordered_map<std::string, Source> map
And std::string was already supported as a hash type in C++11.
C++14 is the default for gcc 8.5.0, which might explain why it works on Centos 8.
Cheers,
Matt
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Mark Rivers via Tech-talk
Sent: Tuesday, June 13, 2023 1:55 PM
Subject: [EXTERNAL] RE: C++ std problem
I should add that ADPICam.cpp compiles fine on Centos 8 Stream (gcc 8.5.0).
I have compiled other files that use std::unordered_map on gcc 4.8.5 without problems, for example the EPICS Galil motor controller.
Sent: Tuesday, June 13, 2023 12:47 PM
To: tech-talk at aps.anl.gov
Subject: C++ std problem
I am trying to build areaDetector/ADPICam on Centos 7 (gcc 4.8.5).  It uses std::unordered_map which I believe was added in C++11.
If I compile without this line in the Makefile
USR_CXXFLAGS_Linux += -std=c++11
then I get this error, which is expected because it is not using C++11.
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/corvette/home/epics/devel/asyn-4-43/include     -I/corvette/home/epics/devel/areaDetector-3-12-1/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-12-1/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-12-1/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.7/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.7/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.7/include        -c ../ADPICam.cpp
In file included from /usr/include/c++/4.8.2/unordered_map:35:0,
                 from ../ADPICam.h:16,
                 from ../ADPICam.cpp:19:
/usr/include/c++/4.8.2/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
#error This file requires compiler and library support for the \
In file included from ../ADPICam.cpp:19:0:
../ADPICam.h:546:33: warning: non-static data member initializers only available with -std=c++11 or -std=gnu++11 [enabled by default]
     bool imageThreadKeepAlive = true;
../ADPICam.h:553:5: error: 'unordered_map' in namespace 'std' does not name a type
     std::unordered_map<PicamParameter, int> parameterExistsMap;
If I use the c++11 flag then I get this error:
make[1]: Entering directory `/home/epics/devel/areaDetector-3-12-1/ADPICam/PICamApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall     -std=c++11  -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/corvette/home/epics/devel/asyn-4-43/include     -I/corvette/home/epics/devel/areaDetector-3-12-1/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-12-1/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-12-1/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.7/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.7/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.7/include        -c ../ADPICam.cpp
In file included from /usr/include/c++/4.8.2/bits/hashtable.h:35:0,
                 from /usr/include/c++/4.8.2/unordered_map:47,
/usr/include/c++/4.8.2/bits/hashtable_policy.h: In instantiation of 'struct std::__detail::_Hash_code_base<PicamParameter, std::pair<const PicamParameter, int>, std::__detail::_Select1st, std::hash<PicamParameter>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, true>':
/usr/include/c++/4.8.2/bits/hashtable_policy.h:1402:10:   required from 'struct std::__detail::_Hashtable_base<PicamParameter, std::pair<const PicamParameter, int>, std::__detail::_Select1st, std::equal_to<PicamParameter>, std::hash<PicamParameter>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Hashtable_traits<true, false, true> >'
/usr/include/c++/4.8.2/bits/hashtable.h:174:11:   required from 'class std::_Hashtable<PicamParameter, std::pair<const PicamParameter, int>, std::allocator<std::pair<const PicamParameter, int> >, std::__detail::_Select1st, std::equal_to<PicamParameter>, std::hash<PicamParameter>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, false, true> >'
/usr/include/c++/4.8.2/bits/unordered_map.h:100:18:   required from 'class std::unordered_map<PicamParameter, int>'
../ADPICam.h:553:45:   required from here
/usr/include/c++/4.8.2/bits/hashtable_policy.h:1070:12: error: invalid use of incomplete type 'struct std::hash<PicamParameter>'
     struct _Hash_code_base<_Key, _Value, _ExtractKey, _H1, _H2,
In file included from /usr/include/c++/4.8.2/bits/basic_string.h:3033:0,
                 from /usr/include/c++/4.8.2/string:52,
                 from /usr/include/c++/4.8.2/random:41,
                 from /usr/include/c++/4.8.2/bits/stl_algo.h:65,
                 from /usr/include/c++/4.8.2/algorithm:62,
                 from ../ADPICam.cpp:11:
/usr/include/c++/4.8.2/bits/functional_hash.h:58:12: error: declaration of 'struct std::hash<PicamParameter>'
     struct hash;
     struct hash;
Can anyone explain what that error means, and is it possible to use gcc 4.8.5 to compile this file?
C++ std problem Mark Rivers via Tech-talk
RE: C++ std problem Mark Rivers via Tech-talk
RE: C++ std problem Pearson, Matthew via Tech-talk
Re: C++ std problem Mark Rivers via Tech-talk
Prev: RE: C++ std problem Pearson, Matthew via Tech-talk
Next: Re: caget from win failed when xspress3 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Next: Re: C++ std problem Michael Davidsaver via Tech-talk
ANJ, 15 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
