1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: caget from win failed when xspress3
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk <tech-talk at aps.anl.gov>, lynn <lynn0703 at yeah.net>
Date: Wed, 14 Jun 2023 16:36:04 +0000
Hi Lynn,
This sounds like a firewall problem.  You said "firewall was closed".  What firewall are you referring to?  It could be either the Linux firewall or the Windows firewall.  To begin with I suggest completely disabling both firewalls.  If the firewall is the problem then re-enable them with rules to allow EPICS traffic to pass.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of lynn via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, June 14, 2023 6:53 AM
Subject: caget from win failed when xspress3
   I met an question about caget.
  The situatuion was like  https://epics.anl.gov/tech-talk/2019/msg01836.php. I try a lot, but i still failed.
   I have 2 pc, first one was xspress Linux pc, which provided by the manufacturer;  the second was a windows pc.
   The linux pc( xspress pc ): there are two NIC and one wireless, one NIC is 192.168.0.2 for device1 , another NIC is 192.168.2.31(for epics)
   The windows pc: one wireless and one NIC:192.168.2.30( 255.255.255.0, gateway:192.168.2.1 and no gateway neither could worke )
   192.168.2.30 and 192.168.2.31 was in same router, just has the two cables in the router.
    Device connection was good, firewall was closed, IOC was good and started, pv name was right and i could caget from the linux pc itself.
    I set both pc the environment to YES or NO/localhost or NO/192.168.2.31or NO/192.168.2.255. None could work.
    I don't think it was a big question, but i do failed. After so many failed, maybe it's the question about network setting, so i put the setting bellow.
These thing has lagued me.
Could someone give me some advice.
epics> epicsPrtEnvParams
EPICS_CA_ADDR_LIST: localhost
EPICS_CA_CONN_TMO: 30.0
EPICS_CA_AUTO_ADDR_LIST: NO
EPICS_CA_REPEATER_PORT: 5065
EPICS_CA_SERVER_PORT: 5064
EPICS_CA_MAX_ARRAY_BYTES: 6000000
EPICS_CA_MAX_SEARCH_PERIOD: 300.0
EPICS_CA_NAME_SERVERS is undefined
EPICS_CAS_INTF_ADDR_LIST: localhost
EPICS_CAS_IGNORE_ADDR_LIST is undefined
EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_ADDR_LIST is undefined
EPICS_CAS_SERVER_PORT is undefined
EPICS_CA_BEACON_PERIOD: 15.0
EPICS_CAS_BEACON_PERIOD is undefined
EPICS_CAS_BEACON_PORT is undefined
EPICS_TIMEZONE: CST/CDT::360:030802:110102
EPICS_TS_NTP_INET is undefined
EPICS_IOC_LOG_PORT: 7004
EPICS_IOC_LOG_INET is undefined
EPICS_IOC_LOG_FILE_LIMIT: 1000000
EPICS_IOC_LOG_FILE_NAME is undefined
EPICS_IOC_LOG_FILE_COMMAND is undefined
EPICS_CMD_PROTO_PORT is undefined
EPICS_AR_PORT: 7002
IOCSH_PS1: epics>
IOCSH_HISTSIZE: 50
set:
C:\Users\dell>set
CATOOLS=C:\Program Files (x86)\National Instruments\LabVIEW 2022\user.lib\caLab\lib
EPICS_CA_AUTO_ADDR_LIST=YES
EPICS_CA_MAX_ARRAY_BYTES=6000000
EPICS_HOST_ARCH=windows-x64
[xspress3@xspress3 network-scripts]$ ifconfig
enp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.2.31  netmask 255.255.255.0  broadcast 192.168.2.255
        inet6 fe80::201:2eff:fea3:132d  prefixlen 64  scopeid 0x20<link>
        ether 00:01:2e:a3:13:2d  txqueuelen 1000  (Ethernet)
        RX packets 1124  bytes 101271 (98.8 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 2194  bytes 108450 (105.9 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
enp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.1  netmask 255.255.255.0  broadcast 192.168.0.255
        ether 00:01:2e:a3:13:2e  txqueuelen 1000  (Ethernet)
        RX packets 1253  bytes 159935 (156.1 KiB)
        TX packets 1244  bytes 434296 (424.1 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 30655  bytes 2448058 (2.3 MiB)
        TX packets 30655  bytes 2448058 (2.3 MiB)
virbr0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 192.168.122.1  netmask 255.255.255.0  broadcast 192.168.122.255
        ether 52:54:00:36:41:17  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
wlo1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.10.21  netmask 255.255.255.0  broadcast 192.168.10.255
        inet6 fe80::83c1:3539:d0ad:203f  prefixlen 64  scopeid 0x20<link>
        ether 68:54:5a:8a:07:e6  txqueuelen 1000  (Ethernet)
        RX packets 91427  bytes 11020700 (10.5 MiB)
        TX packets 123470  bytes 50140843 (47.8 MiB)
C:\user\Dell> ipconfig
 Ethernet 2:
192.168.2.30
255.255.255.0
192.168.2.1
WLAN:
192.168.10.11
255.255.255.0
192.168.10.1
and type: casr 1
Channel Access Server V4.13
No clients connected.
Lynn
Re: caget from win failed when xspress3 Yin, Zhijian via Tech-talk
caget from win failed when xspress3 lynn via Tech-talk
Prev: Re: C++ std problem Wlodek, Jakub via Tech-talk
Next: Re: caget from win failed when xspress3 Yin, Zhijian via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: caget from win failed when xspress3 lynn via Tech-talk
ANJ, 14 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
