Hi Mark,
I do have my paths set in stream/configure/RELEASE, do I also need to set the paths in stream/StreamDevice/configure/RELEASE?
I am supposed to be executing make from /support/stream/StreamDevice not from /support/stream, correct?
Also, it instructs me to execute makeBaseApp.pl -t support in /support/stream/ -- doing so prompts a name upon which "App" is to be appended, am I supposed to name this something specific?
Thank you, Brandon
You need to edit stream/configure/RELEASE and set the correct paths to EPICS_BASE, ASYN, etc.
Hello,
When I run make from ~/EPICS/support/stream/StreamDevice, I get these errors:
$ make
configure/CONFIG:18: /usr/local/epics/base-7.0.3/configure/CONFIG: No such file or directory
Makefile:33: /usr/local/epics/base-7.0.3/configure/RULES_TOP: No such file or directory
make: *** No rule to make target `/usr/local/epics/base-7.0.3/configure/RULES_TOP'. Stop.
Am I supposed to have an epics directory in /usr/local? I am unsure if this is an issue with setting paths correctly or an issue with my epics base install as I do not seem to see anything with the directory structure .../epics/base-7.0.3/...
Thank you,
Brandon
- Issue installing StreamDevice on CentOS 7 Brandon Gunn via Tech-talk
- Re: Issue installing StreamDevice on CentOS 7 Mark Rivers via Tech-talk
Re: Issue installing StreamDevice on CentOS 7 Han Lee via Tech-talk
Re: cross-compiling v7.0.7 Johnson, Andrew N. via Tech-talk
<2023>
Re: Issue installing StreamDevice on CentOS 7 Lang, Keenan C. via Tech-talk
<2023>
ANJ, 15 Jun 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
