1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Issue installing StreamDevice on CentOS 7
From: Zimoch Dirk via Tech-talk <tech-talk at aps.anl.gov>
To: "klang at anl.gov" <klang at anl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "bgunn at ucsd.edu" <bgunn at ucsd.edu>
Date: Fri, 16 Jun 2023 07:44:23 +0000
On Thu, 2023-06-15 at 19:09 +0000, Lang, Keenan C. via Tech-talk wrote:
> Hello Brandon,
> EPICS modules are made aware about the location of other files they must include or link against through the use of the configure/RELEASE file. In StreamDevice, the configure/RELEASE file has the following line:
> EPICS_BASE=/usr/local/epics/base-7.0.3
That is why for a long time I had no configure in StreamDevice but rather
expected people to run makeBaseApp.pl to get their own correct settings. But
some people insisted on adding configure. Thus. now you get my configure/RELEASE
and have to change it to fit your situation, as with  most other modules.
Probably every module uses a different EPICS_BASE location and it is pure luck
if that fits your settings.
Dirk
Issue installing StreamDevice on CentOS 7 Brandon Gunn via Tech-talk
Re: Issue installing StreamDevice on CentOS 7 Lang, Keenan C. via Tech-talk
Prev: Re: Issue installing StreamDevice on CentOS 7 Ralph Lange via Tech-talk
Next: Re: cross-compiling v7.0.7 Simon Rose via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Next: Sequenzer repository not available Jörn Dreyer via Tech-talk
ANJ, 16 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
