1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: [EXTERNAL] Re: Re: Question about fetching history data from MySQL by using phoebus
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: "lzfneu at live.com" <lzfneu at live.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 30 Jun 2023 13:04:44 +0000
Hi:
> The error messages to connect MySQL 5.7.12 on server side (192.168.1.230) with lib/ -java-8.0.30.jar are shown below:
Cannot connect to jdbc:mysql://192.168.1.230/archive as root
Caused by: javax.net.ssl.SSLHandshakeException: Remote host terminated the handshake.
One step forward, one step back.
You have a valid jdbc:mysql:… connection string, it’s using the lib/mysql-connector-java-8.0.30.jar to establish a network connection to your mysql server.
So all is fine as far as Java/CS-Studio/Phoebus/your jdbc:mysql:… connection string are concerned.
But then the mysql-connector client lib fails to agree with your MySQL server on some SSL handshake detail.
So now it’s a MySQL problem, where I really have no immediate solution, but the good news is that there’s a large world-wide MySQL user base out way beyond EPICS/CS-Studio where you can look for help.
Now we’ve seen similar issues before, in that case a new mysql-connector client library required “CLIENT_PLUGIN_AUTH” which was not supported by older MySQL servers (5.1.73), see https://github.com/ControlSystemStudio/phoebus/issues/1409
Eventually we updated to mysql-connector-java-8.0.30.jar which is relatively new (~1 year old, since March there’s 8.0.33). Your MySQL server version 5.7.12 is way old (2016), so maybe they are simply incompatible.
Things you can try: Look at the MySQL server side. Maybe there’s a way to disable SSL, which may not be desirable for a production setup, but gets you going for initial tests.
Since right now your client (ca. 2022) is much newer than the server (ca. 2016), use a newer MySQL or MariaDB version.
Or change to an older client side. You can fetch them from https://search.maven.org/artifact/mysql/mysql-connector-java . But note that simply replacing the file lib/mysql-connector-java-8.0.30.jar with for example an older lib/mysql-connector-java-5.1.45.jar doesn’t work. It’s not sufficient to simply place a *.jar file in the lib folder, the exact name also needs to be listed in the META-INF/MANUFEST.MF file that’s inside the product.jar, which you can’t conveniently edit. To test other mysql-connector jar file versions, it’s thus much easier to keep the currently used name. Just copy them into the lib folder by using the name mysql-connector-java-8.0.30.jar. For example, get a mysql-connector-java-5.1.45.jar, rename it to mysql-connector-java-8.0.30.jar and then copy that into the lib folder, replacing the one that’s there.
-Kay
Re: Re: [EXTERNAL] Re: Re: Question about fetching history data from MySQL by using phoebus lzfneu--- via Tech-talk
Question about fetching history data from MySQL by using phoebus neu lzf via Tech-talk
Re: Question about fetching history data from MySQL by using phoebus Kasemir, Kay via Tech-talk
Re: Question about fetching history data from MySQL by using phoebus neu lzf via Tech-talk
RE: Question about fetching history data from MySQL by using phoebus CAOUEN Loic via Tech-talk
Prev: Re: Help using newest OPC UA Modules/IOCs Ralph Lange via Tech-talk
Next: Re: [EXTERNAL] Phoebus Increased Slider Sensitivity? Hartman, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: Re: Question about fetching history data from MySQL by using phoebus lzfneu--- via Tech-talk
Next: Re: Re: [EXTERNAL] Re: Re: Question about fetching history data from MySQL by using phoebus lzfneu--- via Tech-talk
ANJ, 06 Jul 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
