IIRC the original build rules for DB_INSTALLS allow the source path to point into a support module or other external directory, whereas the DB rules were designed for generating and copying files from the
local application only. Thus you can use DB_INSTALLS += $(ASYN)/db/asynRecord.db to copy that file from your Asyn module into the IOC's
$(TOP)/db directory.
The DB rules might have changed more recently, but there are other variables like BIN_INSTALLS and LIB_INSTALLS which still follow the original design, for example I use BIN_INSTALLS to copy the binary for
the CA Gateway into an application that runs on a host which can't see our support module directories.
- Andrew
On 5/13/24, 10:24 AM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
short question regarding EPICS' build system ...:
whats the difference between DB += myfile.db and DB_INSTALLS += myfile.db ?
generate *.db using a large and complex set of rules
DB_INSTALLS is typically used to install Stream protocol files or Access configuration files or ...
anything where applying the *.db generation rules would create havoc.
- Re: difference between DB and DB_INSTALLS Michael Davidsaver via Tech-talk
- difference between DB and DB_INSTALLS William Kirstaedter via Tech-talk
- Re: difference between DB and DB_INSTALLS Ralph Lange via Tech-talk
Re: 4 instances vs 1 instance of Tomcat for ArchiverAppliance Shankar, Murali via Tech-talk
Re: MVME6100 vxworks and maxv timeout Kevin Peterson via Tech-talk
<2024>
<2024>
ANJ, 18 May 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
