On 5/13/24 12:37, Johnson, Andrew N. via Tech-talk wrote:
IIRC the original build rules for DB_INSTALLS allow the source path to point into a support module or other external directory, whereas the DB rules were designed for generating and copying files from the local application only. Thus you can use DB_INSTALLS += $(ASYN)/db/asynRecord.dbto copy that file from your Asyn module into the IOC's $(TOP)/dbdirectory.
... so that an iocsh script need only read files from "$(TOP)/db".
I see this as an important compliment to static linking of IOC executables.
Both act to "isolate" an IOC instance from changes to files elsewhere in
the system. Hopefully avoiding a situation where an unplanned IOC restart
picks up unexpected changes.
fyi. a concrete example of copying "save_restoreStatus.db" into "$(TOP)/db"
to avoid referencing "$(AUTOSAVE)" at runtime from st.cmd.
https://urldefense.us/v3/__https://github.com/epics-modules/mrfioc2/blob/57d848582abc7896d58a4750f73d49bf625db946/mrfApp/Db/Makefile*L21-L23__;Iw!!G_uCfscf7eWS!cJ9PfMN-HsPjs00Wg-P3QWgURu_T6SOkgNyDs2tUexc2J5r3-XYNiDtUHgk7Wi2lMVSlXHVRwd5hUUqVR945jGwnpQ$
https://urldefense.us/v3/__https://github.com/epics-modules/mrfioc2/blob/57d848582abc7896d58a4750f73d49bf625db946/iocBoot/iocevgmrm/st.cmd*L34__;Iw!!G_uCfscf7eWS!cJ9PfMN-HsPjs00Wg-P3QWgURu_T6SOkgNyDs2tUexc2J5r3-XYNiDtUHgk7Wi2lMVSlXHVRwd5hUUqVR94ArF8bVg$
- Re: difference between DB and DB_INSTALLS Ralph Lange via Tech-talk
- difference between DB and DB_INSTALLS William Kirstaedter via Tech-talk
- Re: difference between DB and DB_INSTALLS Johnson, Andrew N. via Tech-talk
Re: ADUrl and digest authentication Heesterman, Peter via Tech-talk
RE: Magna Power TS Abdalla Ahmad via Tech-talk
<2024>
<2024>
