Hi John,
Hm, that does seem like it is from the hardware. Are you pointing to the same xps3 settings files with both IOC versions?
I sometimes find that just removing all of the xsp* files in /dev/shm helps, especially if the setup or calibration changes. These files will be recreated on restart.
Matt
--Matt
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of John Dobbins via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, May 16, 2024 10:35:18 AM To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov> Subject: XSPRESS3 error messages
All,
I don't think this is an EPICS issue but I am asking in case anyone might have related experience.
We have a four channel XSPRESS3, which is 10+ year old. This has the older hardware format in which a single card hosts up to 8 channels. This past January I updated the IOC from the original IOC to
the build_xspress3.py script at the time called out
'xspress3': 'xspress3-2-4.tar.gz'
which is see has since been updates to
'xspress3': 'xspress3-2-8.tar.gz'
The new IOC runs, though the data is sporadically noisier than with the old IOC. Also, we get error messages at the IOC console like:
epics> Received data from wrong channel = 0 at path=0, card=0, chan_of_card=3
ERROR: Received end of frame marker from chan=2. old frame=158 but count=13, not 2 WHY? Received data from wrong channel = 1 at path=0, card=0, chan_of_card=0 Received data from wrong channel = 0 at path=0, card=0, chan_of_card=1 Received data from wrong channel = 2 at path=0, card=0, chan_of_card=0 Received data from wrong channel = 1 at path=0, card=0, chan_of_card=2 Received data from wrong channel = 0 at path=0, card=0, chan_of_card=1 Received data from wrong channel = 3 at path=0, card=0, chan_of_card=0 Received data from wrong channel = 1 at path=0, card=0, chan_of_card=3 **** TOO MANY WRONG CHAN WARNINGS disabling printing*** Received data from wrong channel = 0 at path=0, card=0, chan_of_card=3 Received data from wrong channel = 3 at path=0, card=0, chan_of_card=2 Received data from wrong channel = 3 at path=0, card=0, chan_of_card=1 **** TOO MANY WRONG CHAN WARNINGS disabling printing*** **** TOO MANY WRONG CHAN WARNINGS disabling printing*** Received data from wrong channel = 1 at path=0, card=0, chan_of_card=2 **** TOO MANY WRONG CHAN WARNINGS disabling printing*** ERROR: Received end of frame marker from chan=0. old frame=160 but count=13, not 2 WHY? ERROR: Received end of frame marker from chan=0. old frame=167 but count=13, not 2 WHY? ERROR: Received end of frame marker from chan=1. old frame=176 but count=1010, n ot 2 WHY?
I see that the messages come from the xspress3 library and not the EPICS source code.
Regards, any help appreciated.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
ANJ, 16 May 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
