Hello all,
I am using CS-Studio Phoebus (version 4.7.3) with Epics (version 7.0.8).
I am having issues with changing runtime limits with Channel Access.
I have an ao record that I want to use as upper limit for other ao records through a dfanout one.
If I monitor these upper limits I see them changing when I change the first ao record, but they are not propagated to the spinners controlling the other PVs.
I set the dbe_property_supported to True in the Phoebus settings but this didn't help.
Is there anything wrong with what I'm doing?
Alessandra
Alessandra Palazzo
Control System Engineer
Present: Mon - Tue - Wed - Thu - Fri
High Voltage Engineering Europa B.V.
Amsterdamseweg 63, 3812 RR Amersfoort
P.O. Box 99, 3800 AB Amersfoort, The Netherlands
Tel +31334619741
Fax +31334615291
E-mail
apalazzo at highvolteng.com
Web
www.highvolteng.com
