Hi Alessandra, Please could you post here the snippet of the database logic showing the records involved in setting these limits? Its not clear from your message which fields you are using. You should be using the HOPR and LOPR fields as described in the "Operator Display Parameters" in the ao record docs. It may also be useful if you post the relevant snippet of your Phoebus configuration file where you set the dbe_property_supported configuration parameter. Cheers, Ulrik --- Ulrik Pedersen Observatory Sciences Ltd. Rutherford Appleton Laboratory Building R104, 1-09 Harwell Campus, Didcot, OX11 0QX Phone: 01223 655 603 On Fri, 17 May 2024 at 13:43, Alessandra Palazzo via Tech-talk <tech-talk at aps.anl.gov> wrote:
ANJ, 20 May 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
