22 long (*special_linconv)(
struct aoRecord *
prec,
int after);
28 #ifndef aoOIF_NUM_CHOICES
35 #define aoOIF_NUM_CHOICES 2
71 struct asgMember *
asp;
73 struct processNotifyRecord *
ppnr;
240 aoRecordOLDSIMM = 95,
249 #ifdef GEN_SIZE_OFFSET
260 if (prt->no_fields != 102) {
262 " The aoRecord defined in the DBD file has %d fields,\n"
263 " but the record support code was built with 102.\n",
266 prt->papFldDes[aoRecordNAME]->size =
sizeof(prec->
name);
267 prt->papFldDes[aoRecordNAME]->offset = (
unsigned short)((
char *)&prec->
name - (
char *)prec);
268 prt->papFldDes[aoRecordDESC]->size =
sizeof(prec->
desc);
269 prt->papFldDes[aoRecordDESC]->offset = (
unsigned short)((
char *)&prec->
desc - (
char *)prec);
270 prt->papFldDes[aoRecordASG]->size =
sizeof(prec->
asg);
271 prt->papFldDes[aoRecordASG]->offset = (
unsigned short)((
char *)&prec->
asg - (
char *)prec);
272 prt->papFldDes[aoRecordSCAN]->size =
sizeof(prec->
scan);
273 prt->papFldDes[aoRecordSCAN]->offset = (
unsigned short)((
char *)&prec->
scan - (
char *)prec);
274 prt->papFldDes[aoRecordPINI]->size =
sizeof(prec->
pini);
275 prt->papFldDes[aoRecordPINI]->offset = (
unsigned short)((
char *)&prec->
pini - (
char *)prec);
276 prt->papFldDes[aoRecordPHAS]->size =
sizeof(prec->
phas);
277 prt->papFldDes[aoRecordPHAS]->offset = (
unsigned short)((
char *)&prec->
phas - (
char *)prec);
278 prt->papFldDes[aoRecordEVNT]->size =
sizeof(prec->
evnt);
279 prt->papFldDes[aoRecordEVNT]->offset = (
unsigned short)((
char *)&prec->
evnt - (
char *)prec);
280 prt->papFldDes[aoRecordTSE]->size =
sizeof(prec->
tse);
281 prt->papFldDes[aoRecordTSE]->offset = (
unsigned short)((
char *)&prec->
tse - (
char *)prec);
282 prt->papFldDes[aoRecordTSEL]->size =
sizeof(prec->
tsel);
283 prt->papFldDes[aoRecordTSEL]->offset = (
unsigned short)((
char *)&prec->
tsel - (
char *)prec);
284 prt->papFldDes[aoRecordDTYP]->size =
sizeof(prec->
dtyp);
285 prt->papFldDes[aoRecordDTYP]->offset = (
unsigned short)((
char *)&prec->
dtyp - (
char *)prec);
286 prt->papFldDes[aoRecordDISV]->size =
sizeof(prec->
disv);
287 prt->papFldDes[aoRecordDISV]->offset = (
unsigned short)((
char *)&prec->
disv - (
char *)prec);
288 prt->papFldDes[aoRecordDISA]->size =
sizeof(prec->
disa);
289 prt->papFldDes[aoRecordDISA]->offset = (
unsigned short)((
char *)&prec->
disa - (
char *)prec);
290 prt->papFldDes[aoRecordSDIS]->size =
sizeof(prec->
sdis);
291 prt->papFldDes[aoRecordSDIS]->offset = (
unsigned short)((
char *)&prec->
sdis - (
char *)prec);
292 prt->papFldDes[aoRecordMLOK]->size =
sizeof(prec->
mlok);
293 prt->papFldDes[aoRecordMLOK]->offset = (
unsigned short)((
char *)&prec->
mlok - (
char *)prec);
294 prt->papFldDes[aoRecordMLIS]->size =
sizeof(prec->
mlis);
295 prt->papFldDes[aoRecordMLIS]->offset = (
unsigned short)((
char *)&prec->
mlis - (
char *)prec);
296 prt->papFldDes[aoRecordBKLNK]->size =
sizeof(prec->
bklnk);
297 prt->papFldDes[aoRecordBKLNK]->offset = (
unsigned short)((
char *)&prec->
bklnk - (
char *)prec);
298 prt->papFldDes[aoRecordDISP]->size =
sizeof(prec->
disp);
299 prt->papFldDes[aoRecordDISP]->offset = (
unsigned short)((
char *)&prec->
disp - (
char *)prec);
300 prt->papFldDes[aoRecordPROC]->size =
sizeof(prec->
proc);
301 prt->papFldDes[aoRecordPROC]->offset = (
unsigned short)((
char *)&prec->
proc - (
char *)prec);
302 prt->papFldDes[aoRecordSTAT]->size =
sizeof(prec->
stat);
303 prt->papFldDes[aoRecordSTAT]->offset = (
unsigned short)((
char *)&prec->
stat - (
char *)prec);
304 prt->papFldDes[aoRecordSEVR]->size =
sizeof(prec->
sevr);
305 prt->papFldDes[aoRecordSEVR]->offset = (
unsigned short)((
char *)&prec->
sevr - (
char *)prec);
306 prt->papFldDes[aoRecordAMSG]->size =
sizeof(prec->
amsg);
307 prt->papFldDes[aoRecordAMSG]->offset = (
unsigned short)((
char *)&prec->
amsg - (
char *)prec);
308 prt->papFldDes[aoRecordNSTA]->size =
sizeof(prec->
nsta);
309 prt->papFldDes[aoRecordNSTA]->offset = (
unsigned short)((
char *)&prec->
nsta - (
char *)prec);
310 prt->papFldDes[aoRecordNSEV]->size =
sizeof(prec->
nsev);
311 prt->papFldDes[aoRecordNSEV]->offset = (
unsigned short)((
char *)&prec->
nsev - (
char *)prec);
312 prt->papFldDes[aoRecordNAMSG]->size =
sizeof(prec->
namsg);
313 prt->papFldDes[aoRecordNAMSG]->offset = (
unsigned short)((
char *)&prec->
namsg - (
char *)prec);
314 prt->papFldDes[aoRecordACKS]->size =
sizeof(prec->
acks);
315 prt->papFldDes[aoRecordACKS]->offset = (
unsigned short)((
char *)&prec->
acks - (
char *)prec);
316 prt->papFldDes[aoRecordACKT]->size =
sizeof(prec->
ackt);
317 prt->papFldDes[aoRecordACKT]->offset = (
unsigned short)((
char *)&prec->
ackt - (
char *)prec);
318 prt->papFldDes[aoRecordDISS]->size =
sizeof(prec->
diss);
319 prt->papFldDes[aoRecordDISS]->offset = (
unsigned short)((
char *)&prec->
diss - (
char *)prec);
320 prt->papFldDes[aoRecordLCNT]->size =
sizeof(prec->
lcnt);
321 prt->papFldDes[aoRecordLCNT]->offset = (
unsigned short)((
char *)&prec->
lcnt - (
char *)prec);
322 prt->papFldDes[aoRecordPACT]->size =
sizeof(prec->
pact);
323 prt->papFldDes[aoRecordPACT]->offset = (
unsigned short)((
char *)&prec->
pact - (
char *)prec);
324 prt->papFldDes[aoRecordPUTF]->size =
sizeof(prec->
putf);
325 prt->papFldDes[aoRecordPUTF]->offset = (
unsigned short)((
char *)&prec->
putf - (
char *)prec);
326 prt->papFldDes[aoRecordRPRO]->size =
sizeof(prec->
rpro);
327 prt->papFldDes[aoRecordRPRO]->offset = (
unsigned short)((
char *)&prec->
rpro - (
char *)prec);
328 prt->papFldDes[aoRecordASP]->size =
sizeof(prec->
asp);
329 prt->papFldDes[aoRecordASP]->offset = (
unsigned short)((
char *)&prec->
asp - (
char *)prec);
330 prt->papFldDes[aoRecordPPN]->size =
sizeof(prec->
ppn);
331 prt->papFldDes[aoRecordPPN]->offset = (
unsigned short)((
char *)&prec->
ppn - (
char *)prec);
332 prt->papFldDes[aoRecordPPNR]->size =
sizeof(prec->
ppnr);
333 prt->papFldDes[aoRecordPPNR]->offset = (
unsigned short)((
char *)&prec->
ppnr - (
char *)prec);
334 prt->papFldDes[aoRecordSPVT]->size =
sizeof(prec->
spvt);
335 prt->papFldDes[aoRecordSPVT]->offset = (
unsigned short)((
char *)&prec->
spvt - (
char *)prec);
336 prt->papFldDes[aoRecordRSET]->size =
sizeof(prec->
rset);
337 prt->papFldDes[aoRecordRSET]->offset = (
unsigned short)((
char *)&prec->
rset - (
char *)prec);
338 prt->papFldDes[aoRecordDSET]->size =
sizeof(prec->
dset);
339 prt->papFldDes[aoRecordDSET]->offset = (
unsigned short)((
char *)&prec->
dset - (
char *)prec);
340 prt->papFldDes[aoRecordDPVT]->size =
sizeof(prec->
dpvt);
341 prt->papFldDes[aoRecordDPVT]->offset = (
unsigned short)((
char *)&prec->
dpvt - (
char *)prec);
342 prt->papFldDes[aoRecordRDES]->size =
sizeof(prec->
rdes);
343 prt->papFldDes[aoRecordRDES]->offset = (
unsigned short)((
char *)&prec->
rdes - (
char *)prec);
344 prt->papFldDes[aoRecordLSET]->size =
sizeof(prec->
lset);
345 prt->papFldDes[aoRecordLSET]->offset = (
unsigned short)((
char *)&prec->
lset - (
char *)prec);
346 prt->papFldDes[aoRecordPRIO]->size =
sizeof(prec->
prio);
347 prt->papFldDes[aoRecordPRIO]->offset = (
unsigned short)((
char *)&prec->
prio - (
char *)prec);
348 prt->papFldDes[aoRecordTPRO]->size =
sizeof(prec->
tpro);
349 prt->papFldDes[aoRecordTPRO]->offset = (
unsigned short)((
char *)&prec->
tpro - (
char *)prec);
350 prt->papFldDes[aoRecordBKPT]->size =
sizeof(prec->
bkpt);
351 prt->papFldDes[aoRecordBKPT]->offset = (
unsigned short)((
char *)&prec->
bkpt - (
char *)prec);
352 prt->papFldDes[aoRecordUDF]->size =
sizeof(prec->
udf);
353 prt->papFldDes[aoRecordUDF]->offset = (
unsigned short)((
char *)&prec->
udf - (
char *)prec);
354 prt->papFldDes[aoRecordUDFS]->size =
sizeof(prec->
udfs);
355 prt->papFldDes[aoRecordUDFS]->offset = (
unsigned short)((
char *)&prec->
udfs - (
char *)prec);
356 prt->papFldDes[aoRecordTIME]->size =
sizeof(prec->
time);
357 prt->papFldDes[aoRecordTIME]->offset = (
unsigned short)((
char *)&prec->
time - (
char *)prec);
358 prt->papFldDes[aoRecordUTAG]->size =
sizeof(prec->
utag);
359 prt->papFldDes[aoRecordUTAG]->offset = (
unsigned short)((
char *)&prec->
utag - (
char *)prec);
360 prt->papFldDes[aoRecordFLNK]->size =
sizeof(prec->
flnk);
361 prt->papFldDes[aoRecordFLNK]->offset = (
unsigned short)((
char *)&prec->
flnk - (
char *)prec);
362 prt->papFldDes[aoRecordVAL]->size =
sizeof(prec->
val);
363 prt->papFldDes[aoRecordVAL]->offset = (
unsigned short)((
char *)&prec->
val - (
char *)prec);
364 prt->papFldDes[aoRecordOVAL]->size =
sizeof(prec->
oval);
365 prt->papFldDes[aoRecordOVAL]->offset = (
unsigned short)((
char *)&prec->
oval - (
char *)prec);
366 prt->papFldDes[aoRecordOUT]->size =
sizeof(prec->
out);
367 prt->papFldDes[aoRecordOUT]->offset = (
unsigned short)((
char *)&prec->
out - (
char *)prec);
368 prt->papFldDes[aoRecordOROC]->size =
sizeof(prec->
oroc);
369 prt->papFldDes[aoRecordOROC]->offset = (
unsigned short)((
char *)&prec->
oroc - (
char *)prec);
370 prt->papFldDes[aoRecordDOL]->size =
sizeof(prec->
dol);
371 prt->papFldDes[aoRecordDOL]->offset = (
unsigned short)((
char *)&prec->
dol - (
char *)prec);
372 prt->papFldDes[aoRecordOMSL]->size =
sizeof(prec->
omsl);
373 prt->papFldDes[aoRecordOMSL]->offset = (
unsigned short)((
char *)&prec->
omsl - (
char *)prec);
374 prt->papFldDes[aoRecordOIF]->size =
sizeof(prec->
oif);
375 prt->papFldDes[aoRecordOIF]->offset = (
unsigned short)((
char *)&prec->
oif - (
char *)prec);
376 prt->papFldDes[aoRecordPREC]->size =
sizeof(prec->
prec);
377 prt->papFldDes[aoRecordPREC]->offset = (
unsigned short)((
char *)&prec->
prec - (
char *)prec);
378 prt->papFldDes[aoRecordLINR]->size =
sizeof(prec->
linr);
379 prt->papFldDes[aoRecordLINR]->offset = (
unsigned short)((
char *)&prec->
linr - (
char *)prec);
380 prt->papFldDes[aoRecordEGUF]->size =
sizeof(prec->
eguf);
381 prt->papFldDes[aoRecordEGUF]->offset = (
unsigned short)((
char *)&prec->
eguf - (
char *)prec);
382 prt->papFldDes[aoRecordEGUL]->size =
sizeof(prec->
egul);
383 prt->papFldDes[aoRecordEGUL]->offset = (
unsigned short)((
char *)&prec->
egul - (
char *)prec);
384 prt->papFldDes[aoRecordEGU]->size =
sizeof(prec->
egu);
385 prt->papFldDes[aoRecordEGU]->offset = (
unsigned short)((
char *)&prec->
egu - (
char *)prec);
386 prt->papFldDes[aoRecordROFF]->size =
sizeof(prec->
roff);
387 prt->papFldDes[aoRecordROFF]->offset = (
unsigned short)((
char *)&prec->
roff - (
char *)prec);
388 prt->papFldDes[aoRecordEOFF]->size =
sizeof(prec->
eoff);
389 prt->papFldDes[aoRecordEOFF]->offset = (
unsigned short)((
char *)&prec->
eoff - (
char *)prec);
390 prt->papFldDes[aoRecordESLO]->size =
sizeof(prec->
eslo);
391 prt->papFldDes[aoRecordESLO]->offset = (
unsigned short)((
char *)&prec->
eslo - (
char *)prec);
392 prt->papFldDes[aoRecordDRVH]->size =
sizeof(prec->
drvh);
393 prt->papFldDes[aoRecordDRVH]->offset = (
unsigned short)((
char *)&prec->
drvh - (
char *)prec);
394 prt->papFldDes[aoRecordDRVL]->size =
sizeof(prec->
drvl);
395 prt->papFldDes[aoRecordDRVL]->offset = (
unsigned short)((
char *)&prec->
drvl - (
char *)prec);
396 prt->papFldDes[aoRecordHOPR]->size =
sizeof(prec->
hopr);
397 prt->papFldDes[aoRecordHOPR]->offset = (
unsigned short)((
char *)&prec->
hopr - (
char *)prec);
398 prt->papFldDes[aoRecordLOPR]->size =
sizeof(prec->
lopr);
399 prt->papFldDes[aoRecordLOPR]->offset = (
unsigned short)((
char *)&prec->
lopr - (
char *)prec);
400 prt->papFldDes[aoRecordAOFF]->size =
sizeof(prec->
aoff);
401 prt->papFldDes[aoRecordAOFF]->offset = (
unsigned short)((
char *)&prec->
aoff - (
char *)prec);
402 prt->papFldDes[aoRecordASLO]->size =
sizeof(prec->
aslo);
403 prt->papFldDes[aoRecordASLO]->offset = (
unsigned short)((
char *)&prec->
aslo - (
char *)prec);
404 prt->papFldDes[aoRecordHIHI]->size =
sizeof(prec->
hihi);
405 prt->papFldDes[aoRecordHIHI]->offset = (
unsigned short)((
char *)&prec->
hihi - (
char *)prec);
406 prt->papFldDes[aoRecordLOLO]->size =
sizeof(prec->
lolo);
407 prt->papFldDes[aoRecordLOLO]->offset = (
unsigned short)((
char *)&prec->
lolo - (
char *)prec);
408 prt->papFldDes[aoRecordHIGH]->size =
sizeof(prec->
high);
409 prt->papFldDes[aoRecordHIGH]->offset = (
unsigned short)((
char *)&prec->
high - (
char *)prec);
410 prt->papFldDes[aoRecordLOW]->size =
sizeof(prec->
low);
411 prt->papFldDes[aoRecordLOW]->offset = (
unsigned short)((
char *)&prec->
low - (
char *)prec);
412 prt->papFldDes[aoRecordHHSV]->size =
sizeof(prec->
hhsv);
413 prt->papFldDes[aoRecordHHSV]->offset = (
unsigned short)((
char *)&prec->
hhsv - (
char *)prec);
414 prt->papFldDes[aoRecordLLSV]->size =
sizeof(prec->
llsv);
415 prt->papFldDes[aoRecordLLSV]->offset = (
unsigned short)((
char *)&prec->
llsv - (
char *)prec);
416 prt->papFldDes[aoRecordHSV]->size =
sizeof(prec->
hsv);
417 prt->papFldDes[aoRecordHSV]->offset = (
unsigned short)((
char *)&prec->
hsv - (
char *)prec);
418 prt->papFldDes[aoRecordLSV]->size =
sizeof(prec->
lsv);
419 prt->papFldDes[aoRecordLSV]->offset = (
unsigned short)((
char *)&prec->
lsv - (
char *)prec);
420 prt->papFldDes[aoRecordHYST]->size =
sizeof(prec->
hyst);
421 prt->papFldDes[aoRecordHYST]->offset = (
unsigned short)((
char *)&prec->
hyst - (
char *)prec);
422 prt->papFldDes[aoRecordADEL]->size =
sizeof(prec->
adel);
423 prt->papFldDes[aoRecordADEL]->offset = (
unsigned short)((
char *)&prec->
adel - (
char *)prec);
424 prt->papFldDes[aoRecordMDEL]->size =
sizeof(prec->
mdel);
425 prt->papFldDes[aoRecordMDEL]->offset = (
unsigned short)((
char *)&prec->
mdel - (
char *)prec);
426 prt->papFldDes[aoRecordRVAL]->size =
sizeof(prec->
rval);
427 prt->papFldDes[aoRecordRVAL]->offset = (
unsigned short)((
char *)&prec->
rval - (
char *)prec);
428 prt->papFldDes[aoRecordORAW]->size =
sizeof(prec->
oraw);
429 prt->papFldDes[aoRecordORAW]->offset = (
unsigned short)((
char *)&prec->
oraw - (
char *)prec);
430 prt->papFldDes[aoRecordRBV]->size =
sizeof(prec->
rbv);
431 prt->papFldDes[aoRecordRBV]->offset = (
unsigned short)((
char *)&prec->
rbv - (
char *)prec);
432 prt->papFldDes[aoRecordORBV]->size =
sizeof(prec->
orbv);
433 prt->papFldDes[aoRecordORBV]->offset = (
unsigned short)((
char *)&prec->
orbv - (
char *)prec);
434 prt->papFldDes[aoRecordPVAL]->size =
sizeof(prec->
pval);
435 prt->papFldDes[aoRecordPVAL]->offset = (
unsigned short)((
char *)&prec->
pval - (
char *)prec);
436 prt->papFldDes[aoRecordLALM]->size =
sizeof(prec->
lalm);
437 prt->papFldDes[aoRecordLALM]->offset = (
unsigned short)((
char *)&prec->
lalm - (
char *)prec);
438 prt->papFldDes[aoRecordALST]->size =
sizeof(prec->
alst);
439 prt->papFldDes[aoRecordALST]->offset = (
unsigned short)((
char *)&prec->
alst - (
char *)prec);
440 prt->papFldDes[aoRecordMLST]->size =
sizeof(prec->
mlst);
441 prt->papFldDes[aoRecordMLST]->offset = (
unsigned short)((
char *)&prec->
mlst - (
char *)prec);
442 prt->papFldDes[aoRecordPBRK]->size =
sizeof(prec->
pbrk);
443 prt->papFldDes[aoRecordPBRK]->offset = (
unsigned short)((
char *)&prec->
pbrk - (
char *)prec);
444 prt->papFldDes[aoRecordINIT]->size =
sizeof(prec->
init);
445 prt->papFldDes[aoRecordINIT]->offset = (
unsigned short)((
char *)&prec->
init - (
char *)prec);
446 prt->papFldDes[aoRecordLBRK]->size =
sizeof(prec->
lbrk);
447 prt->papFldDes[aoRecordLBRK]->offset = (
unsigned short)((
char *)&prec->
lbrk - (
char *)prec);
448 prt->papFldDes[aoRecordSIOL]->size =
sizeof(prec->
siol);
449 prt->papFldDes[aoRecordSIOL]->offset = (
unsigned short)((
char *)&prec->
siol - (
char *)prec);
450 prt->papFldDes[aoRecordSIML]->size =
sizeof(prec->
siml);
451 prt->papFldDes[aoRecordSIML]->offset = (
unsigned short)((
char *)&prec->
siml - (
char *)prec);
452 prt->papFldDes[aoRecordSIMM]->size =
sizeof(prec->
simm);
453 prt->papFldDes[aoRecordSIMM]->offset = (
unsigned short)((
char *)&prec->
simm - (
char *)prec);
454 prt->papFldDes[aoRecordSIMS]->size =
sizeof(prec->
sims);
455 prt->papFldDes[aoRecordSIMS]->offset = (
unsigned short)((
char *)&prec->
sims - (
char *)prec);
456 prt->papFldDes[aoRecordOLDSIMM]->size =
sizeof(prec->
oldsimm);
457 prt->papFldDes[aoRecordOLDSIMM]->offset = (
unsigned short)((
char *)&prec->
oldsimm - (
char *)prec);
458 prt->papFldDes[aoRecordSSCN]->size =
sizeof(prec->
sscn);
459 prt->papFldDes[aoRecordSSCN]->offset = (
unsigned short)((
char *)&prec->
sscn - (
char *)prec);
460 prt->papFldDes[aoRecordSDLY]->size =
sizeof(prec->
sdly);
461 prt->papFldDes[aoRecordSDLY]->offset = (
unsigned short)((
char *)&prec->
sdly - (
char *)prec);
462 prt->papFldDes[aoRecordSIMPVT]->size =
sizeof(prec->
simpvt);
463 prt->papFldDes[aoRecordSIMPVT]->offset = (
unsigned short)((
char *)&prec->
simpvt - (
char *)prec);
464 prt->papFldDes[aoRecordIVOA]->size =
sizeof(prec->
ivoa);
465 prt->papFldDes[aoRecordIVOA]->offset = (
unsigned short)((
char *)&prec->
ivoa - (
char *)prec);
466 prt->papFldDes[aoRecordIVOV]->size =
sizeof(prec->
ivov);
467 prt->papFldDes[aoRecordIVOV]->offset = (
unsigned short)((
char *)&prec->
ivov - (
char *)prec);
468 prt->papFldDes[aoRecordOMOD]->size =
sizeof(prec->
omod);
469 prt->papFldDes[aoRecordOMOD]->offset = (
unsigned short)((
char *)&prec->
omod - (
char *)prec);
470 prt->rec_size =
sizeof(*prec);
epicsInt32 orbv
Prev Readback Value.
epicsEnum16 sims
Simulation Mode Severity.
epicsInt16 prec
Display Precision.
epicsEnum16 stat
Alarm Status.
epicsFloat64 oroc
Output Rate of Change.
epicsFloat64 eguf
Eng Units Full.
epicsEnum16 dtyp
Device Type.
epicsFloat64 lalm
Last Value Alarmed.
epicsEnum16 scan
Scan Mechanism.
epicsFloat64 ivov
INVALID output value.
epicsCallback * simpvt
Sim. Mode Private.
epicsEnum16 diss
Disable Alarm Sevrty.
DBLINK tsel
Time Stamp Link.
DBLINK dol
Desired Output Link.
epicsFloat64 low
Low Alarm Limit.
char amsg[40]
Alarm Message.
epicsEnum16 llsv
Lolo Severity.
LIBCOM_API void cantProceed(const char *errorMessage,...) EPICS_PRINTF_STYLE(1
Suspend this thread, the caller cannot continue or return.
epicsEnum16 lsv
Low Severity.
The core data types used by epics.
epicsUInt8 disp
Disable putField.
State string "Full".
epicsUInt8 omod
Was OVAL modified?
epicsEnum16 nsev
New Alarm Severity.
epicsEnum16 ivoa
INVALID output action.
epicsFloat64 aslo
Adjustment Slope.
char asg[29]
Access Security Group.
epicsFloat64 drvh
Drive High Limit.
State string "Incremental".
epicsMutexId mlok
Monitor lock.
epicsFloat64 eoff
EGU to Raw Offset.
void * dpvt
Device Private.
Declaration of ao record type.
epicsFloat64 drvl
Drive Low Limit.
epicsUInt8 lcnt
Lock Count.
Routines for code that can't continue or return after an error.
char egu[16]
Engineering Units.
struct processNotify * ppn
pprocessNotify
epicsEnum16 acks
Alarm Ack Severity.
struct scan_element * spvt
Scan Private.
epicsEnum16 sevr
Alarm Severity.
struct typed_rset * rset
Address of RSET.
struct asgMember * asp
Access Security Pvt.
epicsUInt8 putf
dbPutField process
epicsEnum16 udfs
Undefined Alarm Sevrty.
void * pbrk
Ptrto brkTable.
epicsEnum16 omsl
Output Mode Select.
unambiguous_dset * dset
DSET address.
EPICS time stamp, for use from C code.
A doubly-linked list library.
char namsg[40]
New Alarm Message.
epicsEnum16 ackt
Alarm Ack Transient.
epicsInt32 rbv
Readback Value.
epicsEnum16 simm
Simulation Mode.
epicsUInt8 bkpt
Break Point.
ELLLIST bklnk
Backwards link tracking.
epicsFloat64 lolo
Lolo Alarm Limit.
epicsFloat64 adel
Archive Deadband.
char name[61]
Record Name.
DBLINK flnk
Forward Process Link.
epicsEnum16 oldsimm
Prev. Simulation Mode.
epicsFloat64 egul
Eng Units Low.
epicsFloat64 hopr
High Operating Range.
epicsInt16 tse
Time Stamp Event.
epicsFloat64 hihi
Hihi Alarm Limit.
epicsFloat64 oval
Output Value.
epicsEnum16 hhsv
Hihi Severity.
struct lockRecord * lset
Lock Set.
epicsInt16 lbrk
LastBreak Point.
APIs for the epicsMutex mutual exclusion semaphore.
epicsEnum16 linr
Linearization.
epicsFloat64 high
High Alarm Limit.
epicsInt16 disv
Disable Value.
epicsEnum16 oif
Out Full/Incremental.
epicsEnum16 hsv
High Severity.
epicsFloat64 aoff
Adjustment Offset.
epicsUInt64 utag
Time Tag.
aoOIF
Enumerated type from menu aoOIF.
epicsFloat64 hyst
Alarm Deadband.
epicsUInt8 proc
Force Processing.
DBLINK sdis
Scanning Disable.
epicsEnum16 pini
Process at iocInit.
DBLINK out
Output Specification.
epicsFloat64 pval
Previous value.
epicsFloat64 alst
Last Value Archived.
#define epicsExportRegistrar(fun)
Declare a registrar function for exporting.
epicsUInt8 tpro
Trace Processing.
struct dbRecordType * rdes
Address of dbRecordType.
epicsFloat64 mdel
Monitor Deadband.
epicsFloat64 sdly
Sim. Mode Async Delay.
epicsFloat64 eslo
EGU to Raw Slope.
epicsEnum16 nsta
New Alarm Status.
DBLINK siml
Simulation Mode Link.
struct processNotifyRecord * ppnr
pprocessNotifyRecord
epicsInt16 phas
Scan Phase.
epicsInt16 init
Initialized?
EPICS time-stamps (epicsTimeStamp), epicsTime C++ class and C functions for handling wall-clock times...
epicsInt32 oraw
Previous Raw Value.
epicsFloat64 mlst
Last Val Monitored.
epicsUInt32 roff
Raw Offset.
epicsUInt8 rpro
Reprocess.
epicsInt32 rval
Current Raw Value.
epicsEnum16 sscn
Sim. Mode Scan.
epicsEnum16 prio
Scheduling Priority.
ELLLIST mlis
Monitor List.
epicsUInt8 pact
Record active.
DBLINK siol
Simulation Output Link.
struct epicsMutexParm * epicsMutexId
An identifier for an epicsMutex for use with the C API.
epicsFloat64 val
Desired Output.
epicsFloat64 lopr
Low Operating Range.
