EPICS Base  7.0.6.1
eventRecord.h
1
7 #ifndef INC_eventRecord_H
8 #define INC_eventRecord_H
9
10 #include "epicsTypes.h"
11 #include "link.h"
12 #include "epicsMutex.h"
13 #include "ellLib.h"
14 #include "devSup.h"
15 #include "epicsTime.h"
16
17 /* Declare Device Support Entry Table */
18 struct eventRecord;
19 typedef struct eventdset {
20  dset common; /*init_record returns: (-1,0)=>(failure,success)*/
21  long (*read_event)(struct eventRecord *prec); /*(0)=> success */
22 } eventdset;
23 #define HAS_eventdset
24
25 #include "dbScan.h"
26 #include "callback.h"
27
29 typedef struct eventRecord {
30  char name[61];
31  char desc[41];
32  char asg[29];
33  epicsEnum16 scan;
34  epicsEnum16 pini;
35  epicsInt16 phas;
36  char evnt[40];
37  epicsInt16 tse;
38  DBLINK tsel;
39  epicsEnum16 dtyp;
40  epicsInt16 disv;
41  epicsInt16 disa;
42  DBLINK sdis;
46  epicsUInt8 disp;
47  epicsUInt8 proc;
48  epicsEnum16 stat;
49  epicsEnum16 sevr;
50  char amsg[40];
51  epicsEnum16 nsta;
52  epicsEnum16 nsev;
53  char namsg[40];
54  epicsEnum16 acks;
55  epicsEnum16 ackt;
56  epicsEnum16 diss;
57  epicsUInt8 lcnt;
58  epicsUInt8 pact;
59  epicsUInt8 putf;
60  epicsUInt8 rpro;
61  struct asgMember *asp;
62  struct processNotify *ppn;
63  struct processNotifyRecord *ppnr;
64  struct scan_element *spvt;
65  struct typed_rset *rset;
67  void *dpvt;
68  struct dbRecordType *rdes;
69  struct lockRecord *lset;
70  epicsEnum16 prio;
71  epicsUInt8 tpro;
72  epicsUInt8 bkpt;
73  epicsUInt8 udf;
74  epicsEnum16 udfs;
76  epicsUInt64 utag;
77  DBLINK flnk;
78  char val[40];
79  EVENTPVT epvt;
80  DBLINK inp;
81  DBLINK siol;
82  char sval[40];
83  DBLINK siml;
84  epicsEnum16 simm;
85  epicsEnum16 sims;
86  epicsEnum16 oldsimm;
87  epicsEnum16 sscn;
88  epicsFloat64 sdly;
90 } eventRecord;
91
92 typedef enum {
93  eventRecordNAME = 0,
94  eventRecordDESC = 1,
95  eventRecordASG = 2,
96  eventRecordSCAN = 3,
97  eventRecordPINI = 4,
98  eventRecordPHAS = 5,
99  eventRecordEVNT = 6,
100  eventRecordTSE = 7,
101  eventRecordTSEL = 8,
102  eventRecordDTYP = 9,
103  eventRecordDISV = 10,
104  eventRecordDISA = 11,
105  eventRecordSDIS = 12,
106  eventRecordMLOK = 13,
107  eventRecordMLIS = 14,
108  eventRecordBKLNK = 15,
109  eventRecordDISP = 16,
110  eventRecordPROC = 17,
111  eventRecordSTAT = 18,
112  eventRecordSEVR = 19,
113  eventRecordAMSG = 20,
114  eventRecordNSTA = 21,
115  eventRecordNSEV = 22,
116  eventRecordNAMSG = 23,
117  eventRecordACKS = 24,
118  eventRecordACKT = 25,
119  eventRecordDISS = 26,
120  eventRecordLCNT = 27,
121  eventRecordPACT = 28,
122  eventRecordPUTF = 29,
123  eventRecordRPRO = 30,
124  eventRecordASP = 31,
125  eventRecordPPN = 32,
126  eventRecordPPNR = 33,
127  eventRecordSPVT = 34,
128  eventRecordRSET = 35,
129  eventRecordDSET = 36,
130  eventRecordDPVT = 37,
131  eventRecordRDES = 38,
132  eventRecordLSET = 39,
133  eventRecordPRIO = 40,
134  eventRecordTPRO = 41,
135  eventRecordBKPT = 42,
136  eventRecordUDF = 43,
137  eventRecordUDFS = 44,
138  eventRecordTIME = 45,
139  eventRecordUTAG = 46,
140  eventRecordFLNK = 47,
141  eventRecordVAL = 48,
142  eventRecordEPVT = 49,
143  eventRecordINP = 50,
144  eventRecordSIOL = 51,
145  eventRecordSVAL = 52,
146  eventRecordSIML = 53,
147  eventRecordSIMM = 54,
148  eventRecordSIMS = 55,
149  eventRecordOLDSIMM = 56,
150  eventRecordSSCN = 57,
151  eventRecordSDLY = 58,
152  eventRecordSIMPVT = 59
153 } eventFieldIndex;
154
155 #ifdef GEN_SIZE_OFFSET
156
157 #include <epicsExport.h>
158 #include <cantProceed.h>
159 #ifdef __cplusplus
160 extern "C" {
161 #endif
162 static int eventRecordSizeOffset(dbRecordType *prt)
163 {
164  eventRecord *prec = 0;
165
166  if (prt->no_fields != 60) {
167  cantProceed("IOC build or installation error:\n"
168  " The eventRecord defined in the DBD file has %d fields,\n"
169  " but the record support code was built with 60.\n",
170  prt->no_fields);
171  }
172  prt->papFldDes[eventRecordNAME]->size = sizeof(prec->name);
173  prt->papFldDes[eventRecordNAME]->offset = (unsigned short)((char *)&prec->name - (char *)prec);
174  prt->papFldDes[eventRecordDESC]->size = sizeof(prec->desc);
175  prt->papFldDes[eventRecordDESC]->offset = (unsigned short)((char *)&prec->desc - (char *)prec);
176  prt->papFldDes[eventRecordASG]->size = sizeof(prec->asg);
177  prt->papFldDes[eventRecordASG]->offset = (unsigned short)((char *)&prec->asg - (char *)prec);
178  prt->papFldDes[eventRecordSCAN]->size = sizeof(prec->scan);
179  prt->papFldDes[eventRecordSCAN]->offset = (unsigned short)((char *)&prec->scan - (char *)prec);
180  prt->papFldDes[eventRecordPINI]->size = sizeof(prec->pini);
181  prt->papFldDes[eventRecordPINI]->offset = (unsigned short)((char *)&prec->pini - (char *)prec);
182  prt->papFldDes[eventRecordPHAS]->size = sizeof(prec->phas);
183  prt->papFldDes[eventRecordPHAS]->offset = (unsigned short)((char *)&prec->phas - (char *)prec);
184  prt->papFldDes[eventRecordEVNT]->size = sizeof(prec->evnt);
185  prt->papFldDes[eventRecordEVNT]->offset = (unsigned short)((char *)&prec->evnt - (char *)prec);
186  prt->papFldDes[eventRecordTSE]->size = sizeof(prec->tse);
187  prt->papFldDes[eventRecordTSE]->offset = (unsigned short)((char *)&prec->tse - (char *)prec);
188  prt->papFldDes[eventRecordTSEL]->size = sizeof(prec->tsel);
189  prt->papFldDes[eventRecordTSEL]->offset = (unsigned short)((char *)&prec->tsel - (char *)prec);
190  prt->papFldDes[eventRecordDTYP]->size = sizeof(prec->dtyp);
191  prt->papFldDes[eventRecordDTYP]->offset = (unsigned short)((char *)&prec->dtyp - (char *)prec);
192  prt->papFldDes[eventRecordDISV]->size = sizeof(prec->disv);
193  prt->papFldDes[eventRecordDISV]->offset = (unsigned short)((char *)&prec->disv - (char *)prec);
194  prt->papFldDes[eventRecordDISA]->size = sizeof(prec->disa);
195  prt->papFldDes[eventRecordDISA]->offset = (unsigned short)((char *)&prec->disa - (char *)prec);
196  prt->papFldDes[eventRecordSDIS]->size = sizeof(prec->sdis);
197  prt->papFldDes[eventRecordSDIS]->offset = (unsigned short)((char *)&prec->sdis - (char *)prec);
198  prt->papFldDes[eventRecordMLOK]->size = sizeof(prec->mlok);
199  prt->papFldDes[eventRecordMLOK]->offset = (unsigned short)((char *)&prec->mlok - (char *)prec);
200  prt->papFldDes[eventRecordMLIS]->size = sizeof(prec->mlis);
201  prt->papFldDes[eventRecordMLIS]->offset = (unsigned short)((char *)&prec->mlis - (char *)prec);
202  prt->papFldDes[eventRecordBKLNK]->size = sizeof(prec->bklnk);
203  prt->papFldDes[eventRecordBKLNK]->offset = (unsigned short)((char *)&prec->bklnk - (char *)prec);
204  prt->papFldDes[eventRecordDISP]->size = sizeof(prec->disp);
205  prt->papFldDes[eventRecordDISP]->offset = (unsigned short)((char *)&prec->disp - (char *)prec);
206  prt->papFldDes[eventRecordPROC]->size = sizeof(prec->proc);
207  prt->papFldDes[eventRecordPROC]->offset = (unsigned short)((char *)&prec->proc - (char *)prec);
208  prt->papFldDes[eventRecordSTAT]->size = sizeof(prec->stat);
209  prt->papFldDes[eventRecordSTAT]->offset = (unsigned short)((char *)&prec->stat - (char *)prec);
210  prt->papFldDes[eventRecordSEVR]->size = sizeof(prec->sevr);
211  prt->papFldDes[eventRecordSEVR]->offset = (unsigned short)((char *)&prec->sevr - (char *)prec);
212  prt->papFldDes[eventRecordAMSG]->size = sizeof(prec->amsg);
213  prt->papFldDes[eventRecordAMSG]->offset = (unsigned short)((char *)&prec->amsg - (char *)prec);
214  prt->papFldDes[eventRecordNSTA]->size = sizeof(prec->nsta);
215  prt->papFldDes[eventRecordNSTA]->offset = (unsigned short)((char *)&prec->nsta - (char *)prec);
216  prt->papFldDes[eventRecordNSEV]->size = sizeof(prec->nsev);
217  prt->papFldDes[eventRecordNSEV]->offset = (unsigned short)((char *)&prec->nsev - (char *)prec);
218  prt->papFldDes[eventRecordNAMSG]->size = sizeof(prec->namsg);
219  prt->papFldDes[eventRecordNAMSG]->offset = (unsigned short)((char *)&prec->namsg - (char *)prec);
220  prt->papFldDes[eventRecordACKS]->size = sizeof(prec->acks);
221  prt->papFldDes[eventRecordACKS]->offset = (unsigned short)((char *)&prec->acks - (char *)prec);
222  prt->papFldDes[eventRecordACKT]->size = sizeof(prec->ackt);
223  prt->papFldDes[eventRecordACKT]->offset = (unsigned short)((char *)&prec->ackt - (char *)prec);
224  prt->papFldDes[eventRecordDISS]->size = sizeof(prec->diss);
225  prt->papFldDes[eventRecordDISS]->offset = (unsigned short)((char *)&prec->diss - (char *)prec);
226  prt->papFldDes[eventRecordLCNT]->size = sizeof(prec->lcnt);
227  prt->papFldDes[eventRecordLCNT]->offset = (unsigned short)((char *)&prec->lcnt - (char *)prec);
228  prt->papFldDes[eventRecordPACT]->size = sizeof(prec->pact);
229  prt->papFldDes[eventRecordPACT]->offset = (unsigned short)((char *)&prec->pact - (char *)prec);
230  prt->papFldDes[eventRecordPUTF]->size = sizeof(prec->putf);
231  prt->papFldDes[eventRecordPUTF]->offset = (unsigned short)((char *)&prec->putf - (char *)prec);
232  prt->papFldDes[eventRecordRPRO]->size = sizeof(prec->rpro);
233  prt->papFldDes[eventRecordRPRO]->offset = (unsigned short)((char *)&prec->rpro - (char *)prec);
234  prt->papFldDes[eventRecordASP]->size = sizeof(prec->asp);
235  prt->papFldDes[eventRecordASP]->offset = (unsigned short)((char *)&prec->asp - (char *)prec);
236  prt->papFldDes[eventRecordPPN]->size = sizeof(prec->ppn);
237  prt->papFldDes[eventRecordPPN]->offset = (unsigned short)((char *)&prec->ppn - (char *)prec);
238  prt->papFldDes[eventRecordPPNR]->size = sizeof(prec->ppnr);
239  prt->papFldDes[eventRecordPPNR]->offset = (unsigned short)((char *)&prec->ppnr - (char *)prec);
240  prt->papFldDes[eventRecordSPVT]->size = sizeof(prec->spvt);
241  prt->papFldDes[eventRecordSPVT]->offset = (unsigned short)((char *)&prec->spvt - (char *)prec);
242  prt->papFldDes[eventRecordRSET]->size = sizeof(prec->rset);
243  prt->papFldDes[eventRecordRSET]->offset = (unsigned short)((char *)&prec->rset - (char *)prec);
244  prt->papFldDes[eventRecordDSET]->size = sizeof(prec->dset);
245  prt->papFldDes[eventRecordDSET]->offset = (unsigned short)((char *)&prec->dset - (char *)prec);
246  prt->papFldDes[eventRecordDPVT]->size = sizeof(prec->dpvt);
247  prt->papFldDes[eventRecordDPVT]->offset = (unsigned short)((char *)&prec->dpvt - (char *)prec);
248  prt->papFldDes[eventRecordRDES]->size = sizeof(prec->rdes);
249  prt->papFldDes[eventRecordRDES]->offset = (unsigned short)((char *)&prec->rdes - (char *)prec);
250  prt->papFldDes[eventRecordLSET]->size = sizeof(prec->lset);
251  prt->papFldDes[eventRecordLSET]->offset = (unsigned short)((char *)&prec->lset - (char *)prec);
252  prt->papFldDes[eventRecordPRIO]->size = sizeof(prec->prio);
253  prt->papFldDes[eventRecordPRIO]->offset = (unsigned short)((char *)&prec->prio - (char *)prec);
254  prt->papFldDes[eventRecordTPRO]->size = sizeof(prec->tpro);
255  prt->papFldDes[eventRecordTPRO]->offset = (unsigned short)((char *)&prec->tpro - (char *)prec);
256  prt->papFldDes[eventRecordBKPT]->size = sizeof(prec->bkpt);
257  prt->papFldDes[eventRecordBKPT]->offset = (unsigned short)((char *)&prec->bkpt - (char *)prec);
258  prt->papFldDes[eventRecordUDF]->size = sizeof(prec->udf);
259  prt->papFldDes[eventRecordUDF]->offset = (unsigned short)((char *)&prec->udf - (char *)prec);
260  prt->papFldDes[eventRecordUDFS]->size = sizeof(prec->udfs);
261  prt->papFldDes[eventRecordUDFS]->offset = (unsigned short)((char *)&prec->udfs - (char *)prec);
262  prt->papFldDes[eventRecordTIME]->size = sizeof(prec->time);
263  prt->papFldDes[eventRecordTIME]->offset = (unsigned short)((char *)&prec->time - (char *)prec);
264  prt->papFldDes[eventRecordUTAG]->size = sizeof(prec->utag);
265  prt->papFldDes[eventRecordUTAG]->offset = (unsigned short)((char *)&prec->utag - (char *)prec);
266  prt->papFldDes[eventRecordFLNK]->size = sizeof(prec->flnk);
267  prt->papFldDes[eventRecordFLNK]->offset = (unsigned short)((char *)&prec->flnk - (char *)prec);
268  prt->papFldDes[eventRecordVAL]->size = sizeof(prec->val);
269  prt->papFldDes[eventRecordVAL]->offset = (unsigned short)((char *)&prec->val - (char *)prec);
270  prt->papFldDes[eventRecordEPVT]->size = sizeof(prec->epvt);
271  prt->papFldDes[eventRecordEPVT]->offset = (unsigned short)((char *)&prec->epvt - (char *)prec);
272  prt->papFldDes[eventRecordINP]->size = sizeof(prec->inp);
273  prt->papFldDes[eventRecordINP]->offset = (unsigned short)((char *)&prec->inp - (char *)prec);
274  prt->papFldDes[eventRecordSIOL]->size = sizeof(prec->siol);
275  prt->papFldDes[eventRecordSIOL]->offset = (unsigned short)((char *)&prec->siol - (char *)prec);
276  prt->papFldDes[eventRecordSVAL]->size = sizeof(prec->sval);
277  prt->papFldDes[eventRecordSVAL]->offset = (unsigned short)((char *)&prec->sval - (char *)prec);
278  prt->papFldDes[eventRecordSIML]->size = sizeof(prec->siml);
279  prt->papFldDes[eventRecordSIML]->offset = (unsigned short)((char *)&prec->siml - (char *)prec);
280  prt->papFldDes[eventRecordSIMM]->size = sizeof(prec->simm);
281  prt->papFldDes[eventRecordSIMM]->offset = (unsigned short)((char *)&prec->simm - (char *)prec);
282  prt->papFldDes[eventRecordSIMS]->size = sizeof(prec->sims);
283  prt->papFldDes[eventRecordSIMS]->offset = (unsigned short)((char *)&prec->sims - (char *)prec);
284  prt->papFldDes[eventRecordOLDSIMM]->size = sizeof(prec->oldsimm);
285  prt->papFldDes[eventRecordOLDSIMM]->offset = (unsigned short)((char *)&prec->oldsimm - (char *)prec);
286  prt->papFldDes[eventRecordSSCN]->size = sizeof(prec->sscn);
287  prt->papFldDes[eventRecordSSCN]->offset = (unsigned short)((char *)&prec->sscn - (char *)prec);
288  prt->papFldDes[eventRecordSDLY]->size = sizeof(prec->sdly);
289  prt->papFldDes[eventRecordSDLY]->offset = (unsigned short)((char *)&prec->sdly - (char *)prec);
290  prt->papFldDes[eventRecordSIMPVT]->size = sizeof(prec->simpvt);
291  prt->papFldDes[eventRecordSIMPVT]->offset = (unsigned short)((char *)&prec->simpvt - (char *)prec);
292  prt->rec_size = sizeof(*prec);
293  return 0;
294 }
295 epicsExportRegistrar(eventRecordSizeOffset);
296
297 #ifdef __cplusplus
298 }
299 #endif
300 #endif /* GEN_SIZE_OFFSET */
301
302 #endif /* INC_eventRecord_H */
epicsUInt8 udf
Undefined.
Definition: eventRecord.h:73
EVENTPVT epvt
Event private.
Definition: eventRecord.h:79
char name[61]
Record Name.
Definition: eventRecord.h:30
epicsEnum16 sims
Sim mode Alarm Svrty.
Definition: eventRecord.h:85
epicsUInt8 pact
Record active.
Definition: eventRecord.h:58
ELLLIST bklnk
Backwards link tracking.
Definition: eventRecord.h:45
char val[40]
Event Name To Post.
Definition: eventRecord.h:78
LIBCOM_API void cantProceed(const char *errorMessage,...) EPICS_PRINTF_STYLE(1
Suspend this thread, the caller cannot continue or return.
epicsEnum16 nsev
New Alarm Severity.
Definition: eventRecord.h:52
epicsUInt8 bkpt
Break Point.
Definition: eventRecord.h:72
struct typed_rset * rset
Address of RSET.
Definition: eventRecord.h:65
DBLINK siol
Sim Input Specifctn.
Definition: eventRecord.h:81
struct scan_element * spvt
Scan Private.
Definition: eventRecord.h:64
The core data types used by epics.
epicsEnum16 sevr
Alarm Severity.
Definition: eventRecord.h:49
epicsInt16 disa
Disable.
Definition: eventRecord.h:41
Exporting IOC objects.
Declaration of event record type.
Definition: eventRecord.h:29
char sval[40]
Simulation Value.
Definition: eventRecord.h:82
epicsEnum16 acks
Alarm Ack Severity.
Definition: eventRecord.h:54
char desc[41]
Descriptor.
Definition: eventRecord.h:31
epicsCallback * simpvt
Sim. Mode Private.
Definition: eventRecord.h:89
Routines for code that can&#39;t continue or return after an error.
epicsUInt8 tpro
Trace Processing.
Definition: eventRecord.h:71
epicsEnum16 prio
Scheduling Priority.
Definition: eventRecord.h:70
char asg[29]
Access Security Group.
Definition: eventRecord.h:32
ELLLIST mlis
Monitor List.
Definition: eventRecord.h:44
char evnt[40]
Event Name.
Definition: eventRecord.h:36
epicsEnum16 sscn
Sim. Mode Scan.
Definition: eventRecord.h:87
struct lockRecord * lset
Lock Set.
Definition: eventRecord.h:69
epicsEnum16 stat
Alarm Status.
Definition: eventRecord.h:48
epicsUInt8 rpro
Reprocess.
Definition: eventRecord.h:60
struct processNotifyRecord * ppnr
pprocessNotifyRecord
Definition: eventRecord.h:63
void * dpvt
Device Private.
Definition: eventRecord.h:67
epicsInt16 tse
Time Stamp Event.
Definition: eventRecord.h:37
Definition: devSup.h:141
DBLINK sdis
Scanning Disable.
Definition: eventRecord.h:42
DBLINK tsel
Time Stamp Link.
Definition: eventRecord.h:38
EPICS time stamp, for use from C code.
Definition: epicsTime.h:42
A doubly-linked list library.
char namsg[40]
New Alarm Message.
Definition: eventRecord.h:53
unambiguous_dset * dset
DSET address.
Definition: eventRecord.h:66
List header type.
Definition: ellLib.h:57
epicsTimeStamp time
Time.
Definition: eventRecord.h:75
epicsEnum16 nsta
New Alarm Status.
Definition: eventRecord.h:51
epicsUInt8 putf
dbPutField process
Definition: eventRecord.h:59
epicsEnum16 dtyp
Device Type.
Definition: eventRecord.h:39
DBLINK siml
Sim Mode Location.
Definition: eventRecord.h:83
epicsInt16 phas
Scan Phase.
Definition: eventRecord.h:35
epicsUInt8 lcnt
Lock Count.
Definition: eventRecord.h:57
epicsMutexId mlok
Monitor lock.
Definition: eventRecord.h:43
APIs for the epicsMutex mutual exclusion semaphore.
Device support routines.
char amsg[40]
Alarm Message.
Definition: eventRecord.h:50
struct asgMember * asp
Access Security Pvt.
Definition: eventRecord.h:61
epicsEnum16 scan
Scan Mechanism.
Definition: eventRecord.h:33
epicsFloat64 sdly
Sim. Mode Async Delay.
Definition: eventRecord.h:88
epicsEnum16 pini
Process at iocInit.
Definition: eventRecord.h:34
epicsEnum16 oldsimm
Prev. Simulation Mode.
Definition: eventRecord.h:86
#define epicsExportRegistrar(fun)
Declare a registrar function for exporting.
Definition: epicsExport.h:94
DBLINK inp
Input Specification.
Definition: eventRecord.h:80
DBLINK flnk
Forward Process Link.
Definition: eventRecord.h:77
struct processNotify * ppn
pprocessNotify
Definition: eventRecord.h:62
epicsInt16 disv
Disable Value.
Definition: eventRecord.h:40
epicsEnum16 ackt
Alarm Ack Transient.
Definition: eventRecord.h:55
epicsUInt8 proc
Force Processing.
Definition: eventRecord.h:47
EPICS time-stamps (epicsTimeStamp), epicsTime C++ class and C functions for handling wall-clock times...
epicsEnum16 udfs
Undefined Alarm Sevrty.
Definition: eventRecord.h:74
epicsUInt64 utag
Time Tag.
Definition: eventRecord.h:76
struct dbRecordType * rdes
Address of dbRecordType.
Definition: eventRecord.h:68
epicsUInt8 disp
Disable putField.
Definition: eventRecord.h:46
epicsEnum16 simm
Simulation Mode.
Definition: eventRecord.h:84
epicsEnum16 diss
Disable Alarm Sevrty.
Definition: eventRecord.h:56
struct epicsMutexParm * epicsMutexId
An identifier for an epicsMutex for use with the C API.
Definition: epicsMutex.h:49
