EPICS Base  7.0.6.1
histogramRecord.h
1
7 #ifndef INC_histogramRecord_H
8 #define INC_histogramRecord_H
9
10 #include "epicsTypes.h"
11 #include "link.h"
12 #include "epicsMutex.h"
13 #include "ellLib.h"
14 #include "devSup.h"
15 #include "epicsTime.h"
16
17 /* Declare Device Support Entry Table */
18 struct histogramRecord;
19 typedef struct histogramdset {
20  dset common; /*init_record returns: (-1,0)=>(failure,success)*/
21  long (*read_histogram)(struct histogramRecord *prec); /*(0,2)=> success and add_count, don't add_count); if add_count then sgnl added to array*/
22  long (*special_linconv)(struct histogramRecord *prec, int after);
24 #define HAS_histogramdset
25
26 #include "callback.h"
27
28 #ifndef histogramCMD_NUM_CHOICES
29
30 typedef enum {
35 } histogramCMD;
37 #define histogramCMD_NUM_CHOICES 4
38 #endif
39
41 typedef struct histogramRecord {
42  char name[61];
43  char desc[41];
44  char asg[29];
45  epicsEnum16 scan;
46  epicsEnum16 pini;
47  epicsInt16 phas;
48  char evnt[40];
49  epicsInt16 tse;
50  DBLINK tsel;
51  epicsEnum16 dtyp;
52  epicsInt16 disv;
53  epicsInt16 disa;
54  DBLINK sdis;
58  epicsUInt8 disp;
59  epicsUInt8 proc;
60  epicsEnum16 stat;
61  epicsEnum16 sevr;
62  char amsg[40];
63  epicsEnum16 nsta;
64  epicsEnum16 nsev;
65  char namsg[40];
66  epicsEnum16 acks;
67  epicsEnum16 ackt;
68  epicsEnum16 diss;
69  epicsUInt8 lcnt;
70  epicsUInt8 pact;
71  epicsUInt8 putf;
72  epicsUInt8 rpro;
73  struct asgMember *asp;
74  struct processNotify *ppn;
75  struct processNotifyRecord *ppnr;
76  struct scan_element *spvt;
77  struct typed_rset *rset;
79  void *dpvt;
80  struct dbRecordType *rdes;
81  struct lockRecord *lset;
82  epicsEnum16 prio;
83  epicsUInt8 tpro;
84  epicsUInt8 bkpt;
85  epicsUInt8 udf;
86  epicsEnum16 udfs;
88  epicsUInt64 utag;
89  DBLINK flnk;
90  void * val;
91  epicsUInt16 nelm;
92  epicsInt16 csta;
93  epicsEnum16 cmd;
94  epicsFloat64 ulim;
95  epicsFloat64 llim;
96  epicsFloat64 wdth;
97  epicsFloat64 sgnl;
98  epicsInt16 prec;
99  DBLINK svl;
100  epicsUInt32 *bptr;
101  void * wdog;
102  epicsInt16 mdel;
103  epicsInt16 mcnt;
104  epicsFloat64 sdel;
105  DBLINK siol;
106  epicsFloat64 sval;
107  DBLINK siml;
108  epicsEnum16 simm;
109  epicsEnum16 sims;
110  epicsEnum16 oldsimm;
111  epicsEnum16 sscn;
112  epicsFloat64 sdly;
114  epicsUInt32 hopr;
115  epicsUInt32 lopr;
117
118 typedef enum {
119  histogramRecordNAME = 0,
120  histogramRecordDESC = 1,
121  histogramRecordASG = 2,
122  histogramRecordSCAN = 3,
123  histogramRecordPINI = 4,
124  histogramRecordPHAS = 5,
125  histogramRecordEVNT = 6,
126  histogramRecordTSE = 7,
127  histogramRecordTSEL = 8,
128  histogramRecordDTYP = 9,
129  histogramRecordDISV = 10,
130  histogramRecordDISA = 11,
131  histogramRecordSDIS = 12,
132  histogramRecordMLOK = 13,
133  histogramRecordMLIS = 14,
134  histogramRecordBKLNK = 15,
135  histogramRecordDISP = 16,
136  histogramRecordPROC = 17,
137  histogramRecordSTAT = 18,
138  histogramRecordSEVR = 19,
139  histogramRecordAMSG = 20,
140  histogramRecordNSTA = 21,
141  histogramRecordNSEV = 22,
142  histogramRecordNAMSG = 23,
143  histogramRecordACKS = 24,
144  histogramRecordACKT = 25,
145  histogramRecordDISS = 26,
146  histogramRecordLCNT = 27,
147  histogramRecordPACT = 28,
148  histogramRecordPUTF = 29,
149  histogramRecordRPRO = 30,
150  histogramRecordASP = 31,
151  histogramRecordPPN = 32,
152  histogramRecordPPNR = 33,
153  histogramRecordSPVT = 34,
154  histogramRecordRSET = 35,
155  histogramRecordDSET = 36,
156  histogramRecordDPVT = 37,
157  histogramRecordRDES = 38,
158  histogramRecordLSET = 39,
159  histogramRecordPRIO = 40,
160  histogramRecordTPRO = 41,
161  histogramRecordBKPT = 42,
162  histogramRecordUDF = 43,
163  histogramRecordUDFS = 44,
164  histogramRecordTIME = 45,
165  histogramRecordUTAG = 46,
166  histogramRecordFLNK = 47,
167  histogramRecordVAL = 48,
168  histogramRecordNELM = 49,
169  histogramRecordCSTA = 50,
170  histogramRecordCMD = 51,
171  histogramRecordULIM = 52,
172  histogramRecordLLIM = 53,
173  histogramRecordWDTH = 54,
174  histogramRecordSGNL = 55,
175  histogramRecordPREC = 56,
176  histogramRecordSVL = 57,
177  histogramRecordBPTR = 58,
178  histogramRecordWDOG = 59,
179  histogramRecordMDEL = 60,
180  histogramRecordMCNT = 61,
181  histogramRecordSDEL = 62,
182  histogramRecordSIOL = 63,
183  histogramRecordSVAL = 64,
184  histogramRecordSIML = 65,
185  histogramRecordSIMM = 66,
186  histogramRecordSIMS = 67,
187  histogramRecordOLDSIMM = 68,
188  histogramRecordSSCN = 69,
189  histogramRecordSDLY = 70,
190  histogramRecordSIMPVT = 71,
191  histogramRecordHOPR = 72,
192  histogramRecordLOPR = 73
193 } histogramFieldIndex;
194
195 #ifdef GEN_SIZE_OFFSET
196
197 #include <epicsExport.h>
198 #include <cantProceed.h>
199 #ifdef __cplusplus
200 extern "C" {
201 #endif
202 static int histogramRecordSizeOffset(dbRecordType *prt)
203 {
204  histogramRecord *prec = 0;
205
206  if (prt->no_fields != 74) {
207  cantProceed("IOC build or installation error:\n"
208  " The histogramRecord defined in the DBD file has %d fields,\n"
209  " but the record support code was built with 74.\n",
210  prt->no_fields);
211  }
212  prt->papFldDes[histogramRecordNAME]->size = sizeof(prec->name);
213  prt->papFldDes[histogramRecordNAME]->offset = (unsigned short)((char *)&prec->name - (char *)prec);
214  prt->papFldDes[histogramRecordDESC]->size = sizeof(prec->desc);
215  prt->papFldDes[histogramRecordDESC]->offset = (unsigned short)((char *)&prec->desc - (char *)prec);
216  prt->papFldDes[histogramRecordASG]->size = sizeof(prec->asg);
217  prt->papFldDes[histogramRecordASG]->offset = (unsigned short)((char *)&prec->asg - (char *)prec);
218  prt->papFldDes[histogramRecordSCAN]->size = sizeof(prec->scan);
219  prt->papFldDes[histogramRecordSCAN]->offset = (unsigned short)((char *)&prec->scan - (char *)prec);
220  prt->papFldDes[histogramRecordPINI]->size = sizeof(prec->pini);
221  prt->papFldDes[histogramRecordPINI]->offset = (unsigned short)((char *)&prec->pini - (char *)prec);
222  prt->papFldDes[histogramRecordPHAS]->size = sizeof(prec->phas);
223  prt->papFldDes[histogramRecordPHAS]->offset = (unsigned short)((char *)&prec->phas - (char *)prec);
224  prt->papFldDes[histogramRecordEVNT]->size = sizeof(prec->evnt);
225  prt->papFldDes[histogramRecordEVNT]->offset = (unsigned short)((char *)&prec->evnt - (char *)prec);
226  prt->papFldDes[histogramRecordTSE]->size = sizeof(prec->tse);
227  prt->papFldDes[histogramRecordTSE]->offset = (unsigned short)((char *)&prec->tse - (char *)prec);
228  prt->papFldDes[histogramRecordTSEL]->size = sizeof(prec->tsel);
229  prt->papFldDes[histogramRecordTSEL]->offset = (unsigned short)((char *)&prec->tsel - (char *)prec);
230  prt->papFldDes[histogramRecordDTYP]->size = sizeof(prec->dtyp);
231  prt->papFldDes[histogramRecordDTYP]->offset = (unsigned short)((char *)&prec->dtyp - (char *)prec);
232  prt->papFldDes[histogramRecordDISV]->size = sizeof(prec->disv);
233  prt->papFldDes[histogramRecordDISV]->offset = (unsigned short)((char *)&prec->disv - (char *)prec);
234  prt->papFldDes[histogramRecordDISA]->size = sizeof(prec->disa);
235  prt->papFldDes[histogramRecordDISA]->offset = (unsigned short)((char *)&prec->disa - (char *)prec);
236  prt->papFldDes[histogramRecordSDIS]->size = sizeof(prec->sdis);
237  prt->papFldDes[histogramRecordSDIS]->offset = (unsigned short)((char *)&prec->sdis - (char *)prec);
238  prt->papFldDes[histogramRecordMLOK]->size = sizeof(prec->mlok);
239  prt->papFldDes[histogramRecordMLOK]->offset = (unsigned short)((char *)&prec->mlok - (char *)prec);
240  prt->papFldDes[histogramRecordMLIS]->size = sizeof(prec->mlis);
241  prt->papFldDes[histogramRecordMLIS]->offset = (unsigned short)((char *)&prec->mlis - (char *)prec);
242  prt->papFldDes[histogramRecordBKLNK]->size = sizeof(prec->bklnk);
243  prt->papFldDes[histogramRecordBKLNK]->offset = (unsigned short)((char *)&prec->bklnk - (char *)prec);
244  prt->papFldDes[histogramRecordDISP]->size = sizeof(prec->disp);
245  prt->papFldDes[histogramRecordDISP]->offset = (unsigned short)((char *)&prec->disp - (char *)prec);
246  prt->papFldDes[histogramRecordPROC]->size = sizeof(prec->proc);
247  prt->papFldDes[histogramRecordPROC]->offset = (unsigned short)((char *)&prec->proc - (char *)prec);
248  prt->papFldDes[histogramRecordSTAT]->size = sizeof(prec->stat);
249  prt->papFldDes[histogramRecordSTAT]->offset = (unsigned short)((char *)&prec->stat - (char *)prec);
250  prt->papFldDes[histogramRecordSEVR]->size = sizeof(prec->sevr);
251  prt->papFldDes[histogramRecordSEVR]->offset = (unsigned short)((char *)&prec->sevr - (char *)prec);
252  prt->papFldDes[histogramRecordAMSG]->size = sizeof(prec->amsg);
253  prt->papFldDes[histogramRecordAMSG]->offset = (unsigned short)((char *)&prec->amsg - (char *)prec);
254  prt->papFldDes[histogramRecordNSTA]->size = sizeof(prec->nsta);
255  prt->papFldDes[histogramRecordNSTA]->offset = (unsigned short)((char *)&prec->nsta - (char *)prec);
256  prt->papFldDes[histogramRecordNSEV]->size = sizeof(prec->nsev);
257  prt->papFldDes[histogramRecordNSEV]->offset = (unsigned short)((char *)&prec->nsev - (char *)prec);
258  prt->papFldDes[histogramRecordNAMSG]->size = sizeof(prec->namsg);
259  prt->papFldDes[histogramRecordNAMSG]->offset = (unsigned short)((char *)&prec->namsg - (char *)prec);
260  prt->papFldDes[histogramRecordACKS]->size = sizeof(prec->acks);
261  prt->papFldDes[histogramRecordACKS]->offset = (unsigned short)((char *)&prec->acks - (char *)prec);
262  prt->papFldDes[histogramRecordACKT]->size = sizeof(prec->ackt);
263  prt->papFldDes[histogramRecordACKT]->offset = (unsigned short)((char *)&prec->ackt - (char *)prec);
264  prt->papFldDes[histogramRecordDISS]->size = sizeof(prec->diss);
265  prt->papFldDes[histogramRecordDISS]->offset = (unsigned short)((char *)&prec->diss - (char *)prec);
266  prt->papFldDes[histogramRecordLCNT]->size = sizeof(prec->lcnt);
267  prt->papFldDes[histogramRecordLCNT]->offset = (unsigned short)((char *)&prec->lcnt - (char *)prec);
268  prt->papFldDes[histogramRecordPACT]->size = sizeof(prec->pact);
269  prt->papFldDes[histogramRecordPACT]->offset = (unsigned short)((char *)&prec->pact - (char *)prec);
270  prt->papFldDes[histogramRecordPUTF]->size = sizeof(prec->putf);
271  prt->papFldDes[histogramRecordPUTF]->offset = (unsigned short)((char *)&prec->putf - (char *)prec);
272  prt->papFldDes[histogramRecordRPRO]->size = sizeof(prec->rpro);
273  prt->papFldDes[histogramRecordRPRO]->offset = (unsigned short)((char *)&prec->rpro - (char *)prec);
274  prt->papFldDes[histogramRecordASP]->size = sizeof(prec->asp);
275  prt->papFldDes[histogramRecordASP]->offset = (unsigned short)((char *)&prec->asp - (char *)prec);
276  prt->papFldDes[histogramRecordPPN]->size = sizeof(prec->ppn);
277  prt->papFldDes[histogramRecordPPN]->offset = (unsigned short)((char *)&prec->ppn - (char *)prec);
278  prt->papFldDes[histogramRecordPPNR]->size = sizeof(prec->ppnr);
279  prt->papFldDes[histogramRecordPPNR]->offset = (unsigned short)((char *)&prec->ppnr - (char *)prec);
280  prt->papFldDes[histogramRecordSPVT]->size = sizeof(prec->spvt);
281  prt->papFldDes[histogramRecordSPVT]->offset = (unsigned short)((char *)&prec->spvt - (char *)prec);
282  prt->papFldDes[histogramRecordRSET]->size = sizeof(prec->rset);
283  prt->papFldDes[histogramRecordRSET]->offset = (unsigned short)((char *)&prec->rset - (char *)prec);
284  prt->papFldDes[histogramRecordDSET]->size = sizeof(prec->dset);
285  prt->papFldDes[histogramRecordDSET]->offset = (unsigned short)((char *)&prec->dset - (char *)prec);
286  prt->papFldDes[histogramRecordDPVT]->size = sizeof(prec->dpvt);
287  prt->papFldDes[histogramRecordDPVT]->offset = (unsigned short)((char *)&prec->dpvt - (char *)prec);
288  prt->papFldDes[histogramRecordRDES]->size = sizeof(prec->rdes);
289  prt->papFldDes[histogramRecordRDES]->offset = (unsigned short)((char *)&prec->rdes - (char *)prec);
290  prt->papFldDes[histogramRecordLSET]->size = sizeof(prec->lset);
291  prt->papFldDes[histogramRecordLSET]->offset = (unsigned short)((char *)&prec->lset - (char *)prec);
292  prt->papFldDes[histogramRecordPRIO]->size = sizeof(prec->prio);
293  prt->papFldDes[histogramRecordPRIO]->offset = (unsigned short)((char *)&prec->prio - (char *)prec);
294  prt->papFldDes[histogramRecordTPRO]->size = sizeof(prec->tpro);
295  prt->papFldDes[histogramRecordTPRO]->offset = (unsigned short)((char *)&prec->tpro - (char *)prec);
296  prt->papFldDes[histogramRecordBKPT]->size = sizeof(prec->bkpt);
297  prt->papFldDes[histogramRecordBKPT]->offset = (unsigned short)((char *)&prec->bkpt - (char *)prec);
298  prt->papFldDes[histogramRecordUDF]->size = sizeof(prec->udf);
299  prt->papFldDes[histogramRecordUDF]->offset = (unsigned short)((char *)&prec->udf - (char *)prec);
300  prt->papFldDes[histogramRecordUDFS]->size = sizeof(prec->udfs);
301  prt->papFldDes[histogramRecordUDFS]->offset = (unsigned short)((char *)&prec->udfs - (char *)prec);
302  prt->papFldDes[histogramRecordTIME]->size = sizeof(prec->time);
303  prt->papFldDes[histogramRecordTIME]->offset = (unsigned short)((char *)&prec->time - (char *)prec);
304  prt->papFldDes[histogramRecordUTAG]->size = sizeof(prec->utag);
305  prt->papFldDes[histogramRecordUTAG]->offset = (unsigned short)((char *)&prec->utag - (char *)prec);
306  prt->papFldDes[histogramRecordFLNK]->size = sizeof(prec->flnk);
307  prt->papFldDes[histogramRecordFLNK]->offset = (unsigned short)((char *)&prec->flnk - (char *)prec);
308  prt->papFldDes[histogramRecordVAL]->size = sizeof(prec->val);
309  prt->papFldDes[histogramRecordVAL]->offset = (unsigned short)((char *)&prec->val - (char *)prec);
310  prt->papFldDes[histogramRecordNELM]->size = sizeof(prec->nelm);
311  prt->papFldDes[histogramRecordNELM]->offset = (unsigned short)((char *)&prec->nelm - (char *)prec);
312  prt->papFldDes[histogramRecordCSTA]->size = sizeof(prec->csta);
313  prt->papFldDes[histogramRecordCSTA]->offset = (unsigned short)((char *)&prec->csta - (char *)prec);
314  prt->papFldDes[histogramRecordCMD]->size = sizeof(prec->cmd);
315  prt->papFldDes[histogramRecordCMD]->offset = (unsigned short)((char *)&prec->cmd - (char *)prec);
316  prt->papFldDes[histogramRecordULIM]->size = sizeof(prec->ulim);
317  prt->papFldDes[histogramRecordULIM]->offset = (unsigned short)((char *)&prec->ulim - (char *)prec);
318  prt->papFldDes[histogramRecordLLIM]->size = sizeof(prec->llim);
319  prt->papFldDes[histogramRecordLLIM]->offset = (unsigned short)((char *)&prec->llim - (char *)prec);
320  prt->papFldDes[histogramRecordWDTH]->size = sizeof(prec->wdth);
321  prt->papFldDes[histogramRecordWDTH]->offset = (unsigned short)((char *)&prec->wdth - (char *)prec);
322  prt->papFldDes[histogramRecordSGNL]->size = sizeof(prec->sgnl);
323  prt->papFldDes[histogramRecordSGNL]->offset = (unsigned short)((char *)&prec->sgnl - (char *)prec);
324  prt->papFldDes[histogramRecordPREC]->size = sizeof(prec->prec);
325  prt->papFldDes[histogramRecordPREC]->offset = (unsigned short)((char *)&prec->prec - (char *)prec);
326  prt->papFldDes[histogramRecordSVL]->size = sizeof(prec->svl);
327  prt->papFldDes[histogramRecordSVL]->offset = (unsigned short)((char *)&prec->svl - (char *)prec);
328  prt->papFldDes[histogramRecordBPTR]->size = sizeof(prec->bptr);
329  prt->papFldDes[histogramRecordBPTR]->offset = (unsigned short)((char *)&prec->bptr - (char *)prec);
330  prt->papFldDes[histogramRecordWDOG]->size = sizeof(prec->wdog);
331  prt->papFldDes[histogramRecordWDOG]->offset = (unsigned short)((char *)&prec->wdog - (char *)prec);
332  prt->papFldDes[histogramRecordMDEL]->size = sizeof(prec->mdel);
333  prt->papFldDes[histogramRecordMDEL]->offset = (unsigned short)((char *)&prec->mdel - (char *)prec);
334  prt->papFldDes[histogramRecordMCNT]->size = sizeof(prec->mcnt);
335  prt->papFldDes[histogramRecordMCNT]->offset = (unsigned short)((char *)&prec->mcnt - (char *)prec);
336  prt->papFldDes[histogramRecordSDEL]->size = sizeof(prec->sdel);
337  prt->papFldDes[histogramRecordSDEL]->offset = (unsigned short)((char *)&prec->sdel - (char *)prec);
338  prt->papFldDes[histogramRecordSIOL]->size = sizeof(prec->siol);
339  prt->papFldDes[histogramRecordSIOL]->offset = (unsigned short)((char *)&prec->siol - (char *)prec);
340  prt->papFldDes[histogramRecordSVAL]->size = sizeof(prec->sval);
341  prt->papFldDes[histogramRecordSVAL]->offset = (unsigned short)((char *)&prec->sval - (char *)prec);
342  prt->papFldDes[histogramRecordSIML]->size = sizeof(prec->siml);
343  prt->papFldDes[histogramRecordSIML]->offset = (unsigned short)((char *)&prec->siml - (char *)prec);
344  prt->papFldDes[histogramRecordSIMM]->size = sizeof(prec->simm);
345  prt->papFldDes[histogramRecordSIMM]->offset = (unsigned short)((char *)&prec->simm - (char *)prec);
346  prt->papFldDes[histogramRecordSIMS]->size = sizeof(prec->sims);
347  prt->papFldDes[histogramRecordSIMS]->offset = (unsigned short)((char *)&prec->sims - (char *)prec);
348  prt->papFldDes[histogramRecordOLDSIMM]->size = sizeof(prec->oldsimm);
349  prt->papFldDes[histogramRecordOLDSIMM]->offset = (unsigned short)((char *)&prec->oldsimm - (char *)prec);
350  prt->papFldDes[histogramRecordSSCN]->size = sizeof(prec->sscn);
351  prt->papFldDes[histogramRecordSSCN]->offset = (unsigned short)((char *)&prec->sscn - (char *)prec);
352  prt->papFldDes[histogramRecordSDLY]->size = sizeof(prec->sdly);
353  prt->papFldDes[histogramRecordSDLY]->offset = (unsigned short)((char *)&prec->sdly - (char *)prec);
354  prt->papFldDes[histogramRecordSIMPVT]->size = sizeof(prec->simpvt);
355  prt->papFldDes[histogramRecordSIMPVT]->offset = (unsigned short)((char *)&prec->simpvt - (char *)prec);
356  prt->papFldDes[histogramRecordHOPR]->size = sizeof(prec->hopr);
357  prt->papFldDes[histogramRecordHOPR]->offset = (unsigned short)((char *)&prec->hopr - (char *)prec);
358  prt->papFldDes[histogramRecordLOPR]->size = sizeof(prec->lopr);
359  prt->papFldDes[histogramRecordLOPR]->offset = (unsigned short)((char *)&prec->lopr - (char *)prec);
360  prt->rec_size = sizeof(*prec);
361  return 0;
362 }
363 epicsExportRegistrar(histogramRecordSizeOffset);
364
365 #ifdef __cplusplus
366 }
367 #endif
368 #endif /* GEN_SIZE_OFFSET */
369
370 #endif /* INC_histogramRecord_H */
struct asgMember * asp
Access Security Pvt.
epicsInt16 csta
Collection Status.
epicsUInt8 lcnt
Lock Count.
DBLINK siol
Simulation Input Link.
epicsUInt8 rpro
Reprocess.
void * val
Value.
epicsUInt8 disp
Disable putField.
epicsEnum16 oldsimm
Prev. Simulation Mode.
epicsUInt8 tpro
Trace Processing.
DBLINK tsel
Time Stamp Link.
struct typed_rset * rset
Address of RSET.
LIBCOM_API void cantProceed(const char *errorMessage,...) EPICS_PRINTF_STYLE(1
Suspend this thread, the caller cannot continue or return.
epicsFloat64 sdly
Sim. Mode Async Delay.
The core data types used by epics.
epicsInt16 phas
Scan Phase.
epicsFloat64 ulim
Upper Signal Limit.
Exporting IOC objects.
unambiguous_dset * dset
DSET address.
struct lockRecord * lset
Lock Set.
struct processNotify * ppn
pprocessNotify
epicsEnum16 diss
Disable Alarm Sevrty.
DBLINK flnk
Forward Process Link.
char amsg[40]
Alarm Message.
epicsFloat64 llim
Lower Signal Limit.
epicsEnum16 stat
Alarm Status.
epicsUInt8 proc
Force Processing.
epicsTimeStamp time
Time.
epicsInt16 mcnt
Counts Since Monitor.
Routines for code that can&#39;t continue or return after an error.
epicsEnum16 sims
Simulation Mode Severity.
epicsFloat64 sdel
Monitor Seconds Dband.
char evnt[40]
Event Name.
State string &quot;Clear&quot;.
epicsFloat64 sgnl
Signal Value.
epicsUInt8 putf
dbPutField process
epicsEnum16 sscn
Sim. Mode Scan.
State string &quot;Read&quot;.
epicsUInt64 utag
Time Tag.
char namsg[40]
New Alarm Message.
Definition: devSup.h:141
epicsEnum16 acks
Alarm Ack Severity.
EPICS time stamp, for use from C code.
Definition: epicsTime.h:42
A doubly-linked list library.
epicsEnum16 nsta
New Alarm Status.
List header type.
Definition: ellLib.h:57
State string &quot;Stop&quot;.
epicsEnum16 simm
Simulation Mode.
epicsUInt32 lopr
Low Operating Range.
epicsEnum16 sevr
Alarm Severity.
DBLINK siml
Simulation Mode Link.
epicsFloat64 wdth
Element Width.
epicsFloat64 sval
Simulation Value.
epicsEnum16 ackt
Alarm Ack Transient.
epicsInt16 mdel
Monitor Count Deadband.
struct scan_element * spvt
Scan Private.
epicsUInt32 * bptr
Buffer Pointer.
epicsEnum16 prio
Scheduling Priority.
ELLLIST mlis
Monitor List.
epicsEnum16 pini
Process at iocInit.
APIs for the epicsMutex mutual exclusion semaphore.
Device support routines.
epicsInt16 disa
Disable.
epicsUInt8 pact
Record active.
struct dbRecordType * rdes
Address of dbRecordType.
epicsEnum16 dtyp
Device Type.
epicsCallback * simpvt
Sim. Mode Private.
#define epicsExportRegistrar(fun)
Declare a registrar function for exporting.
Definition: epicsExport.h:94
void * wdog
Watchdog callback.
histogramCMD
Enumerated type from menu histogramCMD.
epicsMutexId mlok
Monitor lock.
epicsUInt8 udf
Undefined.
epicsUInt8 bkpt
Break Point.
epicsInt16 prec
Display Precision.
epicsUInt16 nelm
Num of Array Elements.
char name[61]
Record Name.
Declaration of histogram record type.
char asg[29]
Access Security Group.
struct processNotifyRecord * ppnr
pprocessNotifyRecord
DBLINK svl
Signal Value Location.
EPICS time-stamps (epicsTimeStamp), epicsTime C++ class and C functions for handling wall-clock times...
epicsEnum16 nsev
New Alarm Severity.
ELLLIST bklnk
Backwards link tracking.
epicsInt16 tse
Time Stamp Event.
epicsEnum16 udfs
Undefined Alarm Sevrty.
epicsUInt32 hopr
High Operating Range.
char desc[41]
Descriptor.
epicsEnum16 cmd
Collection Control.
epicsInt16 disv
Disable Value.
void * dpvt
Device Private.
DBLINK sdis
Scanning Disable.
struct epicsMutexParm * epicsMutexId
An identifier for an epicsMutex for use with the C API.
Definition: epicsMutex.h:49
epicsEnum16 scan
Scan Mechanism.
State string &quot;Start&quot;.
