EPICS Base  7.0.6.1
stateRecord.h
1
7 #ifndef INC_stateRecord_H
8 #define INC_stateRecord_H
9
10 #include "epicsTypes.h"
11 #include "link.h"
12 #include "epicsMutex.h"
13 #include "ellLib.h"
14 #include "devSup.h"
15 #include "epicsTime.h"
16
18 typedef struct stateRecord {
19  char name[61];
20  char desc[41];
21  char asg[29];
22  epicsEnum16 scan;
23  epicsEnum16 pini;
24  epicsInt16 phas;
25  char evnt[40];
26  epicsInt16 tse;
27  DBLINK tsel;
28  epicsEnum16 dtyp;
29  epicsInt16 disv;
30  epicsInt16 disa;
31  DBLINK sdis;
35  epicsUInt8 disp;
36  epicsUInt8 proc;
37  epicsEnum16 stat;
38  epicsEnum16 sevr;
39  char amsg[40];
40  epicsEnum16 nsta;
41  epicsEnum16 nsev;
42  char namsg[40];
43  epicsEnum16 acks;
44  epicsEnum16 ackt;
45  epicsEnum16 diss;
46  epicsUInt8 lcnt;
47  epicsUInt8 pact;
48  epicsUInt8 putf;
49  epicsUInt8 rpro;
50  struct asgMember *asp;
51  struct processNotify *ppn;
52  struct processNotifyRecord *ppnr;
53  struct scan_element *spvt;
54  struct typed_rset *rset;
56  void *dpvt;
57  struct dbRecordType *rdes;
58  struct lockRecord *lset;
59  epicsEnum16 prio;
60  epicsUInt8 tpro;
61  epicsUInt8 bkpt;
62  epicsUInt8 udf;
63  epicsEnum16 udfs;
65  epicsUInt64 utag;
66  DBLINK flnk;
67  char val[20];
68  char oval[20];
69 } stateRecord;
70
71 typedef enum {
72  stateRecordNAME = 0,
73  stateRecordDESC = 1,
74  stateRecordASG = 2,
75  stateRecordSCAN = 3,
76  stateRecordPINI = 4,
77  stateRecordPHAS = 5,
78  stateRecordEVNT = 6,
79  stateRecordTSE = 7,
80  stateRecordTSEL = 8,
81  stateRecordDTYP = 9,
82  stateRecordDISV = 10,
83  stateRecordDISA = 11,
84  stateRecordSDIS = 12,
85  stateRecordMLOK = 13,
86  stateRecordMLIS = 14,
87  stateRecordBKLNK = 15,
88  stateRecordDISP = 16,
89  stateRecordPROC = 17,
90  stateRecordSTAT = 18,
91  stateRecordSEVR = 19,
92  stateRecordAMSG = 20,
93  stateRecordNSTA = 21,
94  stateRecordNSEV = 22,
95  stateRecordNAMSG = 23,
96  stateRecordACKS = 24,
97  stateRecordACKT = 25,
98  stateRecordDISS = 26,
99  stateRecordLCNT = 27,
100  stateRecordPACT = 28,
101  stateRecordPUTF = 29,
102  stateRecordRPRO = 30,
103  stateRecordASP = 31,
104  stateRecordPPN = 32,
105  stateRecordPPNR = 33,
106  stateRecordSPVT = 34,
107  stateRecordRSET = 35,
108  stateRecordDSET = 36,
109  stateRecordDPVT = 37,
110  stateRecordRDES = 38,
111  stateRecordLSET = 39,
112  stateRecordPRIO = 40,
113  stateRecordTPRO = 41,
114  stateRecordBKPT = 42,
115  stateRecordUDF = 43,
116  stateRecordUDFS = 44,
117  stateRecordTIME = 45,
118  stateRecordUTAG = 46,
119  stateRecordFLNK = 47,
120  stateRecordVAL = 48,
121  stateRecordOVAL = 49
122 } stateFieldIndex;
123
124 #ifdef GEN_SIZE_OFFSET
125
126 #include <epicsExport.h>
127 #include <cantProceed.h>
128 #ifdef __cplusplus
129 extern "C" {
130 #endif
131 static int stateRecordSizeOffset(dbRecordType *prt)
132 {
133  stateRecord *prec = 0;
134
135  if (prt->no_fields != 50) {
136  cantProceed("IOC build or installation error:\n"
137  " The stateRecord defined in the DBD file has %d fields,\n"
138  " but the record support code was built with 50.\n",
139  prt->no_fields);
140  }
141  prt->papFldDes[stateRecordNAME]->size = sizeof(prec->name);
142  prt->papFldDes[stateRecordNAME]->offset = (unsigned short)((char *)&prec->name - (char *)prec);
143  prt->papFldDes[stateRecordDESC]->size = sizeof(prec->desc);
144  prt->papFldDes[stateRecordDESC]->offset = (unsigned short)((char *)&prec->desc - (char *)prec);
145  prt->papFldDes[stateRecordASG]->size = sizeof(prec->asg);
146  prt->papFldDes[stateRecordASG]->offset = (unsigned short)((char *)&prec->asg - (char *)prec);
147  prt->papFldDes[stateRecordSCAN]->size = sizeof(prec->scan);
148  prt->papFldDes[stateRecordSCAN]->offset = (unsigned short)((char *)&prec->scan - (char *)prec);
149  prt->papFldDes[stateRecordPINI]->size = sizeof(prec->pini);
150  prt->papFldDes[stateRecordPINI]->offset = (unsigned short)((char *)&prec->pini - (char *)prec);
151  prt->papFldDes[stateRecordPHAS]->size = sizeof(prec->phas);
152  prt->papFldDes[stateRecordPHAS]->offset = (unsigned short)((char *)&prec->phas - (char *)prec);
153  prt->papFldDes[stateRecordEVNT]->size = sizeof(prec->evnt);
154  prt->papFldDes[stateRecordEVNT]->offset = (unsigned short)((char *)&prec->evnt - (char *)prec);
155  prt->papFldDes[stateRecordTSE]->size = sizeof(prec->tse);
156  prt->papFldDes[stateRecordTSE]->offset = (unsigned short)((char *)&prec->tse - (char *)prec);
157  prt->papFldDes[stateRecordTSEL]->size = sizeof(prec->tsel);
158  prt->papFldDes[stateRecordTSEL]->offset = (unsigned short)((char *)&prec->tsel - (char *)prec);
159  prt->papFldDes[stateRecordDTYP]->size = sizeof(prec->dtyp);
160  prt->papFldDes[stateRecordDTYP]->offset = (unsigned short)((char *)&prec->dtyp - (char *)prec);
161  prt->papFldDes[stateRecordDISV]->size = sizeof(prec->disv);
162  prt->papFldDes[stateRecordDISV]->offset = (unsigned short)((char *)&prec->disv - (char *)prec);
163  prt->papFldDes[stateRecordDISA]->size = sizeof(prec->disa);
164  prt->papFldDes[stateRecordDISA]->offset = (unsigned short)((char *)&prec->disa - (char *)prec);
165  prt->papFldDes[stateRecordSDIS]->size = sizeof(prec->sdis);
166  prt->papFldDes[stateRecordSDIS]->offset = (unsigned short)((char *)&prec->sdis - (char *)prec);
167  prt->papFldDes[stateRecordMLOK]->size = sizeof(prec->mlok);
168  prt->papFldDes[stateRecordMLOK]->offset = (unsigned short)((char *)&prec->mlok - (char *)prec);
169  prt->papFldDes[stateRecordMLIS]->size = sizeof(prec->mlis);
170  prt->papFldDes[stateRecordMLIS]->offset = (unsigned short)((char *)&prec->mlis - (char *)prec);
171  prt->papFldDes[stateRecordBKLNK]->size = sizeof(prec->bklnk);
172  prt->papFldDes[stateRecordBKLNK]->offset = (unsigned short)((char *)&prec->bklnk - (char *)prec);
173  prt->papFldDes[stateRecordDISP]->size = sizeof(prec->disp);
174  prt->papFldDes[stateRecordDISP]->offset = (unsigned short)((char *)&prec->disp - (char *)prec);
175  prt->papFldDes[stateRecordPROC]->size = sizeof(prec->proc);
176  prt->papFldDes[stateRecordPROC]->offset = (unsigned short)((char *)&prec->proc - (char *)prec);
177  prt->papFldDes[stateRecordSTAT]->size = sizeof(prec->stat);
178  prt->papFldDes[stateRecordSTAT]->offset = (unsigned short)((char *)&prec->stat - (char *)prec);
179  prt->papFldDes[stateRecordSEVR]->size = sizeof(prec->sevr);
180  prt->papFldDes[stateRecordSEVR]->offset = (unsigned short)((char *)&prec->sevr - (char *)prec);
181  prt->papFldDes[stateRecordAMSG]->size = sizeof(prec->amsg);
182  prt->papFldDes[stateRecordAMSG]->offset = (unsigned short)((char *)&prec->amsg - (char *)prec);
183  prt->papFldDes[stateRecordNSTA]->size = sizeof(prec->nsta);
184  prt->papFldDes[stateRecordNSTA]->offset = (unsigned short)((char *)&prec->nsta - (char *)prec);
185  prt->papFldDes[stateRecordNSEV]->size = sizeof(prec->nsev);
186  prt->papFldDes[stateRecordNSEV]->offset = (unsigned short)((char *)&prec->nsev - (char *)prec);
187  prt->papFldDes[stateRecordNAMSG]->size = sizeof(prec->namsg);
188  prt->papFldDes[stateRecordNAMSG]->offset = (unsigned short)((char *)&prec->namsg - (char *)prec);
189  prt->papFldDes[stateRecordACKS]->size = sizeof(prec->acks);
190  prt->papFldDes[stateRecordACKS]->offset = (unsigned short)((char *)&prec->acks - (char *)prec);
191  prt->papFldDes[stateRecordACKT]->size = sizeof(prec->ackt);
192  prt->papFldDes[stateRecordACKT]->offset = (unsigned short)((char *)&prec->ackt - (char *)prec);
193  prt->papFldDes[stateRecordDISS]->size = sizeof(prec->diss);
194  prt->papFldDes[stateRecordDISS]->offset = (unsigned short)((char *)&prec->diss - (char *)prec);
195  prt->papFldDes[stateRecordLCNT]->size = sizeof(prec->lcnt);
196  prt->papFldDes[stateRecordLCNT]->offset = (unsigned short)((char *)&prec->lcnt - (char *)prec);
197  prt->papFldDes[stateRecordPACT]->size = sizeof(prec->pact);
198  prt->papFldDes[stateRecordPACT]->offset = (unsigned short)((char *)&prec->pact - (char *)prec);
199  prt->papFldDes[stateRecordPUTF]->size = sizeof(prec->putf);
200  prt->papFldDes[stateRecordPUTF]->offset = (unsigned short)((char *)&prec->putf - (char *)prec);
201  prt->papFldDes[stateRecordRPRO]->size = sizeof(prec->rpro);
202  prt->papFldDes[stateRecordRPRO]->offset = (unsigned short)((char *)&prec->rpro - (char *)prec);
203  prt->papFldDes[stateRecordASP]->size = sizeof(prec->asp);
204  prt->papFldDes[stateRecordASP]->offset = (unsigned short)((char *)&prec->asp - (char *)prec);
205  prt->papFldDes[stateRecordPPN]->size = sizeof(prec->ppn);
206  prt->papFldDes[stateRecordPPN]->offset = (unsigned short)((char *)&prec->ppn - (char *)prec);
207  prt->papFldDes[stateRecordPPNR]->size = sizeof(prec->ppnr);
208  prt->papFldDes[stateRecordPPNR]->offset = (unsigned short)((char *)&prec->ppnr - (char *)prec);
209  prt->papFldDes[stateRecordSPVT]->size = sizeof(prec->spvt);
210  prt->papFldDes[stateRecordSPVT]->offset = (unsigned short)((char *)&prec->spvt - (char *)prec);
211  prt->papFldDes[stateRecordRSET]->size = sizeof(prec->rset);
212  prt->papFldDes[stateRecordRSET]->offset = (unsigned short)((char *)&prec->rset - (char *)prec);
213  prt->papFldDes[stateRecordDSET]->size = sizeof(prec->dset);
214  prt->papFldDes[stateRecordDSET]->offset = (unsigned short)((char *)&prec->dset - (char *)prec);
215  prt->papFldDes[stateRecordDPVT]->size = sizeof(prec->dpvt);
216  prt->papFldDes[stateRecordDPVT]->offset = (unsigned short)((char *)&prec->dpvt - (char *)prec);
217  prt->papFldDes[stateRecordRDES]->size = sizeof(prec->rdes);
218  prt->papFldDes[stateRecordRDES]->offset = (unsigned short)((char *)&prec->rdes - (char *)prec);
219  prt->papFldDes[stateRecordLSET]->size = sizeof(prec->lset);
220  prt->papFldDes[stateRecordLSET]->offset = (unsigned short)((char *)&prec->lset - (char *)prec);
221  prt->papFldDes[stateRecordPRIO]->size = sizeof(prec->prio);
222  prt->papFldDes[stateRecordPRIO]->offset = (unsigned short)((char *)&prec->prio - (char *)prec);
223  prt->papFldDes[stateRecordTPRO]->size = sizeof(prec->tpro);
224  prt->papFldDes[stateRecordTPRO]->offset = (unsigned short)((char *)&prec->tpro - (char *)prec);
225  prt->papFldDes[stateRecordBKPT]->size = sizeof(prec->bkpt);
226  prt->papFldDes[stateRecordBKPT]->offset = (unsigned short)((char *)&prec->bkpt - (char *)prec);
227  prt->papFldDes[stateRecordUDF]->size = sizeof(prec->udf);
228  prt->papFldDes[stateRecordUDF]->offset = (unsigned short)((char *)&prec->udf - (char *)prec);
229  prt->papFldDes[stateRecordUDFS]->size = sizeof(prec->udfs);
230  prt->papFldDes[stateRecordUDFS]->offset = (unsigned short)((char *)&prec->udfs - (char *)prec);
231  prt->papFldDes[stateRecordTIME]->size = sizeof(prec->time);
232  prt->papFldDes[stateRecordTIME]->offset = (unsigned short)((char *)&prec->time - (char *)prec);
233  prt->papFldDes[stateRecordUTAG]->size = sizeof(prec->utag);
234  prt->papFldDes[stateRecordUTAG]->offset = (unsigned short)((char *)&prec->utag - (char *)prec);
235  prt->papFldDes[stateRecordFLNK]->size = sizeof(prec->flnk);
236  prt->papFldDes[stateRecordFLNK]->offset = (unsigned short)((char *)&prec->flnk - (char *)prec);
237  prt->papFldDes[stateRecordVAL]->size = sizeof(prec->val);
238  prt->papFldDes[stateRecordVAL]->offset = (unsigned short)((char *)&prec->val - (char *)prec);
239  prt->papFldDes[stateRecordOVAL]->size = sizeof(prec->oval);
240  prt->papFldDes[stateRecordOVAL]->offset = (unsigned short)((char *)&prec->oval - (char *)prec);
241  prt->rec_size = sizeof(*prec);
242  return 0;
243 }
244 epicsExportRegistrar(stateRecordSizeOffset);
245
246 #ifdef __cplusplus
247 }
248 #endif
249 #endif /* GEN_SIZE_OFFSET */
250
251 #endif /* INC_stateRecord_H */
char desc[41]
Descriptor.
Definition: stateRecord.h:20
epicsEnum16 scan
Scan Mechanism.
Definition: stateRecord.h:22
struct scan_element * spvt
Scan Private.
Definition: stateRecord.h:53
epicsEnum16 nsev
New Alarm Severity.
Definition: stateRecord.h:41
struct asgMember * asp
Access Security Pvt.
Definition: stateRecord.h:50
epicsMutexId mlok
Monitor lock.
Definition: stateRecord.h:32
epicsInt16 disa
Disable.
Definition: stateRecord.h:30
epicsUInt8 lcnt
Lock Count.
Definition: stateRecord.h:46
LIBCOM_API void cantProceed(const char *errorMessage,...) EPICS_PRINTF_STYLE(1
Suspend this thread, the caller cannot continue or return.
epicsUInt64 utag
Time Tag.
Definition: stateRecord.h:65
epicsEnum16 pini
Process at iocInit.
Definition: stateRecord.h:23
epicsUInt8 bkpt
Break Point.
Definition: stateRecord.h:61
The core data types used by epics.
epicsEnum16 acks
Alarm Ack Severity.
Definition: stateRecord.h:43
Exporting IOC objects.
ELLLIST mlis
Monitor List.
Definition: stateRecord.h:33
ELLLIST bklnk
Backwards link tracking.
Definition: stateRecord.h:34
DBLINK flnk
Forward Process Link.
Definition: stateRecord.h:66
epicsUInt8 proc
Force Processing.
Definition: stateRecord.h:36
DBLINK tsel
Time Stamp Link.
Definition: stateRecord.h:27
epicsInt16 disv
Disable Value.
Definition: stateRecord.h:29
Routines for code that can&#39;t continue or return after an error.
epicsUInt8 disp
Disable putField.
Definition: stateRecord.h:35
epicsEnum16 dtyp
Device Type.
Definition: stateRecord.h:28
Declaration of state record type.
Definition: stateRecord.h:18
epicsUInt8 tpro
Trace Processing.
Definition: stateRecord.h:60
epicsUInt8 udf
Undefined.
Definition: stateRecord.h:62
epicsEnum16 udfs
Undefined Alarm Sevrty.
Definition: stateRecord.h:63
struct processNotify * ppn
pprocessNotify
Definition: stateRecord.h:51
Definition: devSup.h:141
EPICS time stamp, for use from C code.
Definition: epicsTime.h:42
A doubly-linked list library.
char val[20]
Value.
Definition: stateRecord.h:67
epicsEnum16 sevr
Alarm Severity.
Definition: stateRecord.h:38
List header type.
Definition: ellLib.h:57
epicsTimeStamp time
Time.
Definition: stateRecord.h:64
char asg[29]
Access Security Group.
Definition: stateRecord.h:21
struct typed_rset * rset
Address of RSET.
Definition: stateRecord.h:54
epicsEnum16 diss
Disable Alarm Sevrty.
Definition: stateRecord.h:45
struct processNotifyRecord * ppnr
pprocessNotifyRecord
Definition: stateRecord.h:52
epicsEnum16 stat
Alarm Status.
Definition: stateRecord.h:37
APIs for the epicsMutex mutual exclusion semaphore.
Device support routines.
char evnt[40]
Event Name.
Definition: stateRecord.h:25
void * dpvt
Device Private.
Definition: stateRecord.h:56
epicsUInt8 pact
Record active.
Definition: stateRecord.h:47
char name[61]
Record Name.
Definition: stateRecord.h:19
#define epicsExportRegistrar(fun)
Declare a registrar function for exporting.
Definition: epicsExport.h:94
epicsEnum16 ackt
Alarm Ack Transient.
Definition: stateRecord.h:44
epicsInt16 tse
Time Stamp Event.
Definition: stateRecord.h:26
char amsg[40]
Alarm Message.
Definition: stateRecord.h:39
char oval[20]
Prev Value.
Definition: stateRecord.h:68
unambiguous_dset * dset
DSET address.
Definition: stateRecord.h:55
epicsUInt8 putf
dbPutField process
Definition: stateRecord.h:48
EPICS time-stamps (epicsTimeStamp), epicsTime C++ class and C functions for handling wall-clock times...
epicsEnum16 nsta
New Alarm Status.
Definition: stateRecord.h:40
epicsUInt8 rpro
Reprocess.
Definition: stateRecord.h:49
epicsInt16 phas
Scan Phase.
Definition: stateRecord.h:24
struct lockRecord * lset
Lock Set.
Definition: stateRecord.h:58
DBLINK sdis
Scanning Disable.
Definition: stateRecord.h:31
struct epicsMutexParm * epicsMutexId
An identifier for an epicsMutex for use with the C API.
Definition: epicsMutex.h:49
struct dbRecordType * rdes
Address of dbRecordType.
Definition: stateRecord.h:57
epicsEnum16 prio
Scheduling Priority.
Definition: stateRecord.h:59
char namsg[40]
New Alarm Message.
Definition: stateRecord.h:42
