EPICS Base  7.0.6.1
stringoutRecord.h
1
7 #ifndef INC_stringoutRecord_H
8 #define INC_stringoutRecord_H
9
10 #include "epicsTypes.h"
11 #include "link.h"
12 #include "epicsMutex.h"
13 #include "ellLib.h"
14 #include "devSup.h"
15 #include "epicsTime.h"
16
17 /* Declare Device Support Entry Table */
18 struct stringoutRecord;
19 typedef struct stringoutdset {
20  dset common; /*init_record returns: (-1,0)=>(failure,success)*/
21  long (*write_stringout)(struct stringoutRecord *prec); /*(-1,0)=>(failure,success)*/
23 #define HAS_stringoutdset
24
25 #include "callback.h"
26
27 #ifndef stringoutPOST_NUM_CHOICES
28
29 typedef enum {
34 #define stringoutPOST_NUM_CHOICES 2
35 #endif
36
38 typedef struct stringoutRecord {
39  char name[61];
40  char desc[41];
41  char asg[29];
42  epicsEnum16 scan;
43  epicsEnum16 pini;
44  epicsInt16 phas;
45  char evnt[40];
46  epicsInt16 tse;
47  DBLINK tsel;
48  epicsEnum16 dtyp;
49  epicsInt16 disv;
50  epicsInt16 disa;
51  DBLINK sdis;
55  epicsUInt8 disp;
56  epicsUInt8 proc;
57  epicsEnum16 stat;
58  epicsEnum16 sevr;
59  char amsg[40];
60  epicsEnum16 nsta;
61  epicsEnum16 nsev;
62  char namsg[40];
63  epicsEnum16 acks;
64  epicsEnum16 ackt;
65  epicsEnum16 diss;
66  epicsUInt8 lcnt;
67  epicsUInt8 pact;
68  epicsUInt8 putf;
69  epicsUInt8 rpro;
70  struct asgMember *asp;
71  struct processNotify *ppn;
72  struct processNotifyRecord *ppnr;
73  struct scan_element *spvt;
74  struct typed_rset *rset;
76  void *dpvt;
77  struct dbRecordType *rdes;
78  struct lockRecord *lset;
79  epicsEnum16 prio;
80  epicsUInt8 tpro;
81  epicsUInt8 bkpt;
82  epicsUInt8 udf;
83  epicsEnum16 udfs;
85  epicsUInt64 utag;
86  DBLINK flnk;
87  char val[40];
88  char oval[40];
89  DBLINK dol;
90  epicsEnum16 omsl;
91  DBLINK out;
92  epicsEnum16 mpst;
93  epicsEnum16 apst;
94  DBLINK siol;
95  DBLINK siml;
96  epicsEnum16 simm;
97  epicsEnum16 sims;
98  epicsEnum16 oldsimm;
99  epicsEnum16 sscn;
100  epicsFloat64 sdly;
102  epicsEnum16 ivoa;
103  char ivov[40];
105
106 typedef enum {
107  stringoutRecordNAME = 0,
108  stringoutRecordDESC = 1,
109  stringoutRecordASG = 2,
110  stringoutRecordSCAN = 3,
111  stringoutRecordPINI = 4,
112  stringoutRecordPHAS = 5,
113  stringoutRecordEVNT = 6,
114  stringoutRecordTSE = 7,
115  stringoutRecordTSEL = 8,
116  stringoutRecordDTYP = 9,
117  stringoutRecordDISV = 10,
118  stringoutRecordDISA = 11,
119  stringoutRecordSDIS = 12,
120  stringoutRecordMLOK = 13,
121  stringoutRecordMLIS = 14,
122  stringoutRecordBKLNK = 15,
123  stringoutRecordDISP = 16,
124  stringoutRecordPROC = 17,
125  stringoutRecordSTAT = 18,
126  stringoutRecordSEVR = 19,
127  stringoutRecordAMSG = 20,
128  stringoutRecordNSTA = 21,
129  stringoutRecordNSEV = 22,
130  stringoutRecordNAMSG = 23,
131  stringoutRecordACKS = 24,
132  stringoutRecordACKT = 25,
133  stringoutRecordDISS = 26,
134  stringoutRecordLCNT = 27,
135  stringoutRecordPACT = 28,
136  stringoutRecordPUTF = 29,
137  stringoutRecordRPRO = 30,
138  stringoutRecordASP = 31,
139  stringoutRecordPPN = 32,
140  stringoutRecordPPNR = 33,
141  stringoutRecordSPVT = 34,
142  stringoutRecordRSET = 35,
143  stringoutRecordDSET = 36,
144  stringoutRecordDPVT = 37,
145  stringoutRecordRDES = 38,
146  stringoutRecordLSET = 39,
147  stringoutRecordPRIO = 40,
148  stringoutRecordTPRO = 41,
149  stringoutRecordBKPT = 42,
150  stringoutRecordUDF = 43,
151  stringoutRecordUDFS = 44,
152  stringoutRecordTIME = 45,
153  stringoutRecordUTAG = 46,
154  stringoutRecordFLNK = 47,
155  stringoutRecordVAL = 48,
156  stringoutRecordOVAL = 49,
157  stringoutRecordDOL = 50,
158  stringoutRecordOMSL = 51,
159  stringoutRecordOUT = 52,
160  stringoutRecordMPST = 53,
161  stringoutRecordAPST = 54,
162  stringoutRecordSIOL = 55,
163  stringoutRecordSIML = 56,
164  stringoutRecordSIMM = 57,
165  stringoutRecordSIMS = 58,
166  stringoutRecordOLDSIMM = 59,
167  stringoutRecordSSCN = 60,
168  stringoutRecordSDLY = 61,
169  stringoutRecordSIMPVT = 62,
170  stringoutRecordIVOA = 63,
171  stringoutRecordIVOV = 64
172 } stringoutFieldIndex;
173
174 #ifdef GEN_SIZE_OFFSET
175
176 #include <epicsExport.h>
177 #include <cantProceed.h>
178 #ifdef __cplusplus
179 extern "C" {
180 #endif
181 static int stringoutRecordSizeOffset(dbRecordType *prt)
182 {
183  stringoutRecord *prec = 0;
184
185  if (prt->no_fields != 65) {
186  cantProceed("IOC build or installation error:\n"
187  " The stringoutRecord defined in the DBD file has %d fields,\n"
188  " but the record support code was built with 65.\n",
189  prt->no_fields);
190  }
191  prt->papFldDes[stringoutRecordNAME]->size = sizeof(prec->name);
192  prt->papFldDes[stringoutRecordNAME]->offset = (unsigned short)((char *)&prec->name - (char *)prec);
193  prt->papFldDes[stringoutRecordDESC]->size = sizeof(prec->desc);
194  prt->papFldDes[stringoutRecordDESC]->offset = (unsigned short)((char *)&prec->desc - (char *)prec);
195  prt->papFldDes[stringoutRecordASG]->size = sizeof(prec->asg);
196  prt->papFldDes[stringoutRecordASG]->offset = (unsigned short)((char *)&prec->asg - (char *)prec);
197  prt->papFldDes[stringoutRecordSCAN]->size = sizeof(prec->scan);
198  prt->papFldDes[stringoutRecordSCAN]->offset = (unsigned short)((char *)&prec->scan - (char *)prec);
199  prt->papFldDes[stringoutRecordPINI]->size = sizeof(prec->pini);
200  prt->papFldDes[stringoutRecordPINI]->offset = (unsigned short)((char *)&prec->pini - (char *)prec);
201  prt->papFldDes[stringoutRecordPHAS]->size = sizeof(prec->phas);
202  prt->papFldDes[stringoutRecordPHAS]->offset = (unsigned short)((char *)&prec->phas - (char *)prec);
203  prt->papFldDes[stringoutRecordEVNT]->size = sizeof(prec->evnt);
204  prt->papFldDes[stringoutRecordEVNT]->offset = (unsigned short)((char *)&prec->evnt - (char *)prec);
205  prt->papFldDes[stringoutRecordTSE]->size = sizeof(prec->tse);
206  prt->papFldDes[stringoutRecordTSE]->offset = (unsigned short)((char *)&prec->tse - (char *)prec);
207  prt->papFldDes[stringoutRecordTSEL]->size = sizeof(prec->tsel);
208  prt->papFldDes[stringoutRecordTSEL]->offset = (unsigned short)((char *)&prec->tsel - (char *)prec);
209  prt->papFldDes[stringoutRecordDTYP]->size = sizeof(prec->dtyp);
210  prt->papFldDes[stringoutRecordDTYP]->offset = (unsigned short)((char *)&prec->dtyp - (char *)prec);
211  prt->papFldDes[stringoutRecordDISV]->size = sizeof(prec->disv);
212  prt->papFldDes[stringoutRecordDISV]->offset = (unsigned short)((char *)&prec->disv - (char *)prec);
213  prt->papFldDes[stringoutRecordDISA]->size = sizeof(prec->disa);
214  prt->papFldDes[stringoutRecordDISA]->offset = (unsigned short)((char *)&prec->disa - (char *)prec);
215  prt->papFldDes[stringoutRecordSDIS]->size = sizeof(prec->sdis);
216  prt->papFldDes[stringoutRecordSDIS]->offset = (unsigned short)((char *)&prec->sdis - (char *)prec);
217  prt->papFldDes[stringoutRecordMLOK]->size = sizeof(prec->mlok);
218  prt->papFldDes[stringoutRecordMLOK]->offset = (unsigned short)((char *)&prec->mlok - (char *)prec);
219  prt->papFldDes[stringoutRecordMLIS]->size = sizeof(prec->mlis);
220  prt->papFldDes[stringoutRecordMLIS]->offset = (unsigned short)((char *)&prec->mlis - (char *)prec);
221  prt->papFldDes[stringoutRecordBKLNK]->size = sizeof(prec->bklnk);
222  prt->papFldDes[stringoutRecordBKLNK]->offset = (unsigned short)((char *)&prec->bklnk - (char *)prec);
223  prt->papFldDes[stringoutRecordDISP]->size = sizeof(prec->disp);
224  prt->papFldDes[stringoutRecordDISP]->offset = (unsigned short)((char *)&prec->disp - (char *)prec);
225  prt->papFldDes[stringoutRecordPROC]->size = sizeof(prec->proc);
226  prt->papFldDes[stringoutRecordPROC]->offset = (unsigned short)((char *)&prec->proc - (char *)prec);
227  prt->papFldDes[stringoutRecordSTAT]->size = sizeof(prec->stat);
228  prt->papFldDes[stringoutRecordSTAT]->offset = (unsigned short)((char *)&prec->stat - (char *)prec);
229  prt->papFldDes[stringoutRecordSEVR]->size = sizeof(prec->sevr);
230  prt->papFldDes[stringoutRecordSEVR]->offset = (unsigned short)((char *)&prec->sevr - (char *)prec);
231  prt->papFldDes[stringoutRecordAMSG]->size = sizeof(prec->amsg);
232  prt->papFldDes[stringoutRecordAMSG]->offset = (unsigned short)((char *)&prec->amsg - (char *)prec);
233  prt->papFldDes[stringoutRecordNSTA]->size = sizeof(prec->nsta);
234  prt->papFldDes[stringoutRecordNSTA]->offset = (unsigned short)((char *)&prec->nsta - (char *)prec);
235  prt->papFldDes[stringoutRecordNSEV]->size = sizeof(prec->nsev);
236  prt->papFldDes[stringoutRecordNSEV]->offset = (unsigned short)((char *)&prec->nsev - (char *)prec);
237  prt->papFldDes[stringoutRecordNAMSG]->size = sizeof(prec->namsg);
238  prt->papFldDes[stringoutRecordNAMSG]->offset = (unsigned short)((char *)&prec->namsg - (char *)prec);
239  prt->papFldDes[stringoutRecordACKS]->size = sizeof(prec->acks);
240  prt->papFldDes[stringoutRecordACKS]->offset = (unsigned short)((char *)&prec->acks - (char *)prec);
241  prt->papFldDes[stringoutRecordACKT]->size = sizeof(prec->ackt);
242  prt->papFldDes[stringoutRecordACKT]->offset = (unsigned short)((char *)&prec->ackt - (char *)prec);
243  prt->papFldDes[stringoutRecordDISS]->size = sizeof(prec->diss);
244  prt->papFldDes[stringoutRecordDISS]->offset = (unsigned short)((char *)&prec->diss - (char *)prec);
245  prt->papFldDes[stringoutRecordLCNT]->size = sizeof(prec->lcnt);
246  prt->papFldDes[stringoutRecordLCNT]->offset = (unsigned short)((char *)&prec->lcnt - (char *)prec);
247  prt->papFldDes[stringoutRecordPACT]->size = sizeof(prec->pact);
248  prt->papFldDes[stringoutRecordPACT]->offset = (unsigned short)((char *)&prec->pact - (char *)prec);
249  prt->papFldDes[stringoutRecordPUTF]->size = sizeof(prec->putf);
250  prt->papFldDes[stringoutRecordPUTF]->offset = (unsigned short)((char *)&prec->putf - (char *)prec);
251  prt->papFldDes[stringoutRecordRPRO]->size = sizeof(prec->rpro);
252  prt->papFldDes[stringoutRecordRPRO]->offset = (unsigned short)((char *)&prec->rpro - (char *)prec);
253  prt->papFldDes[stringoutRecordASP]->size = sizeof(prec->asp);
254  prt->papFldDes[stringoutRecordASP]->offset = (unsigned short)((char *)&prec->asp - (char *)prec);
255  prt->papFldDes[stringoutRecordPPN]->size = sizeof(prec->ppn);
256  prt->papFldDes[stringoutRecordPPN]->offset = (unsigned short)((char *)&prec->ppn - (char *)prec);
257  prt->papFldDes[stringoutRecordPPNR]->size = sizeof(prec->ppnr);
258  prt->papFldDes[stringoutRecordPPNR]->offset = (unsigned short)((char *)&prec->ppnr - (char *)prec);
259  prt->papFldDes[stringoutRecordSPVT]->size = sizeof(prec->spvt);
260  prt->papFldDes[stringoutRecordSPVT]->offset = (unsigned short)((char *)&prec->spvt - (char *)prec);
261  prt->papFldDes[stringoutRecordRSET]->size = sizeof(prec->rset);
262  prt->papFldDes[stringoutRecordRSET]->offset = (unsigned short)((char *)&prec->rset - (char *)prec);
263  prt->papFldDes[stringoutRecordDSET]->size = sizeof(prec->dset);
264  prt->papFldDes[stringoutRecordDSET]->offset = (unsigned short)((char *)&prec->dset - (char *)prec);
265  prt->papFldDes[stringoutRecordDPVT]->size = sizeof(prec->dpvt);
266  prt->papFldDes[stringoutRecordDPVT]->offset = (unsigned short)((char *)&prec->dpvt - (char *)prec);
267  prt->papFldDes[stringoutRecordRDES]->size = sizeof(prec->rdes);
268  prt->papFldDes[stringoutRecordRDES]->offset = (unsigned short)((char *)&prec->rdes - (char *)prec);
269  prt->papFldDes[stringoutRecordLSET]->size = sizeof(prec->lset);
270  prt->papFldDes[stringoutRecordLSET]->offset = (unsigned short)((char *)&prec->lset - (char *)prec);
271  prt->papFldDes[stringoutRecordPRIO]->size = sizeof(prec->prio);
272  prt->papFldDes[stringoutRecordPRIO]->offset = (unsigned short)((char *)&prec->prio - (char *)prec);
273  prt->papFldDes[stringoutRecordTPRO]->size = sizeof(prec->tpro);
274  prt->papFldDes[stringoutRecordTPRO]->offset = (unsigned short)((char *)&prec->tpro - (char *)prec);
275  prt->papFldDes[stringoutRecordBKPT]->size = sizeof(prec->bkpt);
276  prt->papFldDes[stringoutRecordBKPT]->offset = (unsigned short)((char *)&prec->bkpt - (char *)prec);
277  prt->papFldDes[stringoutRecordUDF]->size = sizeof(prec->udf);
278  prt->papFldDes[stringoutRecordUDF]->offset = (unsigned short)((char *)&prec->udf - (char *)prec);
279  prt->papFldDes[stringoutRecordUDFS]->size = sizeof(prec->udfs);
280  prt->papFldDes[stringoutRecordUDFS]->offset = (unsigned short)((char *)&prec->udfs - (char *)prec);
281  prt->papFldDes[stringoutRecordTIME]->size = sizeof(prec->time);
282  prt->papFldDes[stringoutRecordTIME]->offset = (unsigned short)((char *)&prec->time - (char *)prec);
283  prt->papFldDes[stringoutRecordUTAG]->size = sizeof(prec->utag);
284  prt->papFldDes[stringoutRecordUTAG]->offset = (unsigned short)((char *)&prec->utag - (char *)prec);
285  prt->papFldDes[stringoutRecordFLNK]->size = sizeof(prec->flnk);
286  prt->papFldDes[stringoutRecordFLNK]->offset = (unsigned short)((char *)&prec->flnk - (char *)prec);
287  prt->papFldDes[stringoutRecordVAL]->size = sizeof(prec->val);
288  prt->papFldDes[stringoutRecordVAL]->offset = (unsigned short)((char *)&prec->val - (char *)prec);
289  prt->papFldDes[stringoutRecordOVAL]->size = sizeof(prec->oval);
290  prt->papFldDes[stringoutRecordOVAL]->offset = (unsigned short)((char *)&prec->oval - (char *)prec);
291  prt->papFldDes[stringoutRecordDOL]->size = sizeof(prec->dol);
292  prt->papFldDes[stringoutRecordDOL]->offset = (unsigned short)((char *)&prec->dol - (char *)prec);
293  prt->papFldDes[stringoutRecordOMSL]->size = sizeof(prec->omsl);
294  prt->papFldDes[stringoutRecordOMSL]->offset = (unsigned short)((char *)&prec->omsl - (char *)prec);
295  prt->papFldDes[stringoutRecordOUT]->size = sizeof(prec->out);
296  prt->papFldDes[stringoutRecordOUT]->offset = (unsigned short)((char *)&prec->out - (char *)prec);
297  prt->papFldDes[stringoutRecordMPST]->size = sizeof(prec->mpst);
298  prt->papFldDes[stringoutRecordMPST]->offset = (unsigned short)((char *)&prec->mpst - (char *)prec);
299  prt->papFldDes[stringoutRecordAPST]->size = sizeof(prec->apst);
300  prt->papFldDes[stringoutRecordAPST]->offset = (unsigned short)((char *)&prec->apst - (char *)prec);
301  prt->papFldDes[stringoutRecordSIOL]->size = sizeof(prec->siol);
302  prt->papFldDes[stringoutRecordSIOL]->offset = (unsigned short)((char *)&prec->siol - (char *)prec);
303  prt->papFldDes[stringoutRecordSIML]->size = sizeof(prec->siml);
304  prt->papFldDes[stringoutRecordSIML]->offset = (unsigned short)((char *)&prec->siml - (char *)prec);
305  prt->papFldDes[stringoutRecordSIMM]->size = sizeof(prec->simm);
306  prt->papFldDes[stringoutRecordSIMM]->offset = (unsigned short)((char *)&prec->simm - (char *)prec);
307  prt->papFldDes[stringoutRecordSIMS]->size = sizeof(prec->sims);
308  prt->papFldDes[stringoutRecordSIMS]->offset = (unsigned short)((char *)&prec->sims - (char *)prec);
309  prt->papFldDes[stringoutRecordOLDSIMM]->size = sizeof(prec->oldsimm);
310  prt->papFldDes[stringoutRecordOLDSIMM]->offset = (unsigned short)((char *)&prec->oldsimm - (char *)prec);
311  prt->papFldDes[stringoutRecordSSCN]->size = sizeof(prec->sscn);
312  prt->papFldDes[stringoutRecordSSCN]->offset = (unsigned short)((char *)&prec->sscn - (char *)prec);
313  prt->papFldDes[stringoutRecordSDLY]->size = sizeof(prec->sdly);
314  prt->papFldDes[stringoutRecordSDLY]->offset = (unsigned short)((char *)&prec->sdly - (char *)prec);
315  prt->papFldDes[stringoutRecordSIMPVT]->size = sizeof(prec->simpvt);
316  prt->papFldDes[stringoutRecordSIMPVT]->offset = (unsigned short)((char *)&prec->simpvt - (char *)prec);
317  prt->papFldDes[stringoutRecordIVOA]->size = sizeof(prec->ivoa);
318  prt->papFldDes[stringoutRecordIVOA]->offset = (unsigned short)((char *)&prec->ivoa - (char *)prec);
319  prt->papFldDes[stringoutRecordIVOV]->size = sizeof(prec->ivov);
320  prt->papFldDes[stringoutRecordIVOV]->offset = (unsigned short)((char *)&prec->ivov - (char *)prec);
321  prt->rec_size = sizeof(*prec);
322  return 0;
323 }
324 epicsExportRegistrar(stringoutRecordSizeOffset);
325
326 #ifdef __cplusplus
327 }
328 #endif
329 #endif /* GEN_SIZE_OFFSET */
330
331 #endif /* INC_stringoutRecord_H */
char name[61]
Record Name.
struct processNotifyRecord * ppnr
pprocessNotifyRecord
epicsUInt8 rpro
Reprocess.
epicsUInt8 putf
dbPutField process
epicsUInt8 bkpt
Break Point.
ELLLIST mlis
Monitor List.
epicsCallback * simpvt
Sim. Mode Private.
DBLINK out
Output Specification.
epicsEnum16 stat
Alarm Status.
epicsEnum16 sevr
Alarm Severity.
char namsg[40]
New Alarm Message.
char amsg[40]
Alarm Message.
epicsEnum16 simm
Simulation Mode.
char oval[40]
Previous Value.
char ivov[40]
INVALID output value.
epicsMutexId mlok
Monitor lock.
epicsEnum16 acks
Alarm Ack Severity.
Declaration of stringout record type.
LIBCOM_API void cantProceed(const char *errorMessage,...) EPICS_PRINTF_STYLE(1
Suspend this thread, the caller cannot continue or return.
DBLINK flnk
Forward Process Link.
The core data types used by epics.
epicsEnum16 oldsimm
Prev. Simulation Mode.
Exporting IOC objects.
epicsEnum16 pini
Process at iocInit.
epicsUInt8 tpro
Trace Processing.
struct processNotify * ppn
pprocessNotify
ELLLIST bklnk
Backwards link tracking.
epicsUInt64 utag
Time Tag.
char evnt[40]
Event Name.
epicsInt16 disa
Disable.
epicsEnum16 nsta
New Alarm Status.
epicsInt16 disv
Disable Value.
Routines for code that can&#39;t continue or return after an error.
struct lockRecord * lset
Lock Set.
epicsEnum16 nsev
New Alarm Severity.
epicsEnum16 udfs
Undefined Alarm Sevrty.
epicsFloat64 sdly
Sim. Mode Async Delay.
State string &quot;Always&quot;.
DBLINK siol
Simulation Output Link.
void * dpvt
Device Private.
epicsUInt8 udf
Undefined.
DBLINK sdis
Scanning Disable.
Definition: devSup.h:141
epicsEnum16 diss
Disable Alarm Sevrty.
epicsUInt8 pact
Record active.
EPICS time stamp, for use from C code.
Definition: epicsTime.h:42
A doubly-linked list library.
DBLINK dol
Desired Output Link.
epicsUInt8 proc
Force Processing.
List header type.
Definition: ellLib.h:57
epicsTimeStamp time
Time.
struct asgMember * asp
Access Security Pvt.
epicsEnum16 apst
Post Archive Monitors.
epicsEnum16 sims
Simulation Mode Severity.
char asg[29]
Access Security Group.
DBLINK siml
Simulation Mode Link.
epicsUInt8 disp
Disable putField.
DBLINK tsel
Time Stamp Link.
epicsEnum16 scan
Scan Mechanism.
APIs for the epicsMutex mutual exclusion semaphore.
Device support routines.
epicsEnum16 dtyp
Device Type.
struct dbRecordType * rdes
Address of dbRecordType.
char val[40]
Current Value.
#define epicsExportRegistrar(fun)
Declare a registrar function for exporting.
Definition: epicsExport.h:94
epicsEnum16 ivoa
INVALID output action.
char desc[41]
Descriptor.
stringoutPOST
Enumerated type from menu stringoutPOST.
epicsUInt8 lcnt
Lock Count.
unambiguous_dset * dset
DSET address.
struct typed_rset * rset
Address of RSET.
epicsEnum16 prio
Scheduling Priority.
EPICS time-stamps (epicsTimeStamp), epicsTime C++ class and C functions for handling wall-clock times...
epicsEnum16 sscn
Sim. Mode Scan.
struct scan_element * spvt
Scan Private.
epicsEnum16 omsl
Output Mode Select.
epicsInt16 phas
Scan Phase.
epicsEnum16 mpst
Post Value Monitors.
epicsInt16 tse
Time Stamp Event.
struct epicsMutexParm * epicsMutexId
An identifier for an epicsMutex for use with the C API.
Definition: epicsMutex.h:49
epicsEnum16 ackt
Alarm Ack Transient.
State string &quot;On Change&quot;.
