<20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
To: "'Ken Evans'" <[email protected]>
Cc: <[email protected]>, "Bob Dalesio" <[email protected]>, "'Andrew Johnson'" <[email protected]>, "'Ralph Lange'" <[email protected]>
Date: Wed, 27 Nov 2002 22:03:28 -0700
Ken,
I am getting a better handle on how to get meaningful data out of
quantify. One of my quantify runs this afternoon reported that the
example portable server was spending a whopping 55% of its total CPU
time in the CRTL pool management routines. Closer inspection revealed
that this was nearly all related to new and delete (malloc and free) for
the data structure that gets queued for each monitor update. In R3.14 I
have a template for creating free lists in C++, but didn't when I wrote
the portable server and therefore none of its data structures were
originally obtained from free lists. Clearly this needs to change. Note
however that this is fixing an issue that existed also in the R3.13
portable ca server, and all previous versions. So this does not explain
the performance slow down of the gateway in R3.14, but still it is an
encouraging result and I expect that we can make a big improvement based
on this alone.
Jeff
__________________________________________________________
Jeff Hill                     Internet     [email protected]
LANL MS H820                  Voice        505 665 1831
Los Alamos NM 87545 USA       FAX          505 665 5107
Prev: Re: base max thread priority Eric Norum
Next: Re: base max thread priority Marty Kraimer
Index: <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Gateway Ned D. Arnold
Next: CROSS_COMPILER_TARGET_ARCHS default change Janet Anderson
