<20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: base max thread priority
To: Till Straumann <[email protected]>
Cc: Marty Kraimer <[email protected]>, Jeff Hill <[email protected]>, "'Johnson, Andrew N.'" <[email protected]>
Date: Wed, 27 Nov 2002 18:51:05 -0600
On Wednesday, November 27, 2002, at 03:17  PM, Till Straumann wrote:
Again: IMO, EPICS should have the _full_ range of OS priorities available.
Part of the job of porting EPICS to a particular OS would be assigning
the actual values of basic EPICS priorities (like epicsThreadPriorityIocsh, epicsThreadPriorityBaseMin, epicsThreadPriorityBaseMax...).
It's absurd: I use EPICS on a real-time OS but have no access to the
priorities needed to get real-time performance when I use the epicsThread API ;-)
Is 100 levels not enough? If priorities 91-99 were reserved for application threads only would it not be possible to do what you need?
I think that it's better to coerce other system tasks into the EPICS range if appropriate since it makes moving a given EPICS application from one processor to another so much easier. I think that the 'base max' (I'm still hoping that someone can come up with a good name for this) priority level (90, right???) should be added to epicsThread.h. Once it's there I'll set up the RTEMS initialization to run the iocsh at that priority. As well, if there's no opposition, I'm going to change the default priority for the RTEMS network and error logging daemons to be one less than epicsThreadPriorityScanLow, the lowest-priority scan task. I think that this may be the last chance to make these changes without a lot of input from the entire EPICS community.
Eric Norum <[email protected]>
Department of Electrical Engineering
University of Saskatchewan
Saskatoon, Canada.
Phone: (306) 966-5394   FAX:   (306) 966-5407
Re: base max thread priority Marty Kraimer
Re: base max thread priority Till Straumann
Prev: Re: base max thread priority Till Straumann
Next: [no subject] Jeff Hill
Index: <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: base max thread priority Marty Kraimer
