2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: record/device/driver support export
To: Marty Kraimer <[email protected]>
Cc: "Anderson, Janet B." <[email protected]>, "Johnson, Andrew N." <[email protected]>, Eric Norum <[email protected]>, Jeff Hill <[email protected]>, [email protected]
Date: Tue, 01 Apr 2003 15:10:58 -0600
The only change from the previous message is the epicsShareExport => epicsExport.
I have made the changes and checked that exampleApp works on linux.
I have committed the changes.
Marty
Marty Kraimer wrote:
Yesterday Janet and I finally got exampleApp to work on win32 with the simplified build rules. This required that record/device/driver support be built as shared libraries just like other components of base.
Currently record and device support are handled differently. Driver support is not handled.
I thought of way to accomplish the goal via a more generic method.
A new header epicsShareExport.h will be created. It will define two macros.
epicsShareExportAddress(type,obj)
and
epicsShareExportRegistrar(func)
epicsShareExportAddress can be used to export the address of any object to a sgared library. It will be used for record/device/driver support and also for other stuff users think of.
devAiSoft.c will contain the definitions
#include        "epicsShareExport.h"
epicsShareExportAddress(dset,devAiSoft);
aiRecord.c will contain the definitions
epicsShareExportAddress(rset,aiRSET);
epicsShareExportRegistrar is used to export the address of a function with no arguments and that returns void. Such a function will normally perform other registration. Thus the name Registrar.
For example dbSubExample.c in exampleApp will be
#include <stdio.h>
#include <dbDefs.h>
#include <registryFunction.h>
#include <subRecord.h>
#include <epicsShareExport.h>
typedef long (*processMethod)(subRecord *precord);
static long mySubInit(subRecord *precord,processMethod process)
    printf("Record %s called mySubInit(%p, %p)\n",
           precord->name, (void*) precord, (void*) process);
    return(0);
static long mySubProcess(subRecord *precord)
    printf("Record %s called mySubProcess(%p)\n",
           precord->name, (void*) precord);
    return(0);
static registryFunctionRef mySubRef[] = {
    {"mySubInit",(REGISTRYFUNCTION)mySubInit},
    {"mySubProcess",(REGISTRYFUNCTION)mySubProcess}
static void mySub(void)
    registryFunctionRefAdd(mySubRef,NELEMENTS(mySubRef));
epicsShareExportRegistrar(mySub);
The actual definition for epicsShareExport.h is
#ifndef INCepicsShareExporth
#define INCepicsShareExporth
#ifdef __cplusplus
extern "C" {
#endif
#define epicsExportSharedSymbols
#include <shareLib.h>
#define EPICS_SHARE_POBJ(obj) p ## obj
#define epicsShareExportAddress(typ,obj) \
epicsShareExtern typ *EPICS_SHARE_POBJ(obj); \
epicsShareDef typ *EPICS_SHARE_POBJ(obj) = (typ *)&obj
#define epicsShareExportRegistrar(func) \
epicsShareFunc REGISTRYFUNCTION EPICS_SHARE_POBJ(func) = &func
#ifdef __cplusplus
#endif
#endif /* epicsShareExporth */
record/device/driver support export Marty Kraimer
Prev: record/device/driver support export Marty Kraimer
Next: Re: [EPICS Base R3.14.x 0000029]: Access Security host names should be case insensitive Marty Kraimer
Index: 2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
