2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [EPICS Base R3.14.x 0000029]: Access Security host names should be case insensitive
To: Ralph Lange <[email protected]>
Cc: [email protected], "Johnson, Andrew N." <[email protected]>, Jeff Hill <[email protected]>, Eric Norum <[email protected]>, "Anderson, Janet B." <[email protected]>
Date: Fri, 04 Apr 2003 14:31:54 -0600
A problem arose on vxWorks with conveting the host name to lower case.
On vxWorks the target name of the boot params is made the host name.
It is NOT converted to lower case.
Andrew suggests that aslibRoutines.c be changed to use
strcasecmp instead of strcmp when comparing host names.
Discussion:
I find strcasecmp on linux and solaris and is defined in header strings.h.
NOTE NOT string.c
vxWorks does not have it.
I dont know about win32 or darwin.
This if we do this it sounds like we should define
epicsStrings.h
and provide an implmentation for os/default and os/vxWorks.
thoughts anyone?
Marty
Prev: Re: record/device/driver support export Marty Kraimer
Next: Why we can't extend the DSET or DRVET Andrew Johnson
Index: 2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
