Jeff Hill wrote:
I assume that the device and driver support would be handled the same way -
by adding a new routine at the end of the device and driver support entry
tables.
That's not possible because in reality the structure definition for the
DSET is not defined centrally - it can be (and usually is) different for
each record type, and is usually defined by the device support layer
itself. For example, in R3.13 src/dev/atDev/devAt5Vxi.c contains two
typedefs like this:
typedef struct {
long number;
DEVSUPFUN report;
DEVSUPFUN init;
DEVSUPFUN init_record;
DEVSUPFUN get_ioint_info;
DEVSUPFUN read_write;
DEVSUPFUN special_linconv;} AT5VXIDSET;
There are also several very commonly used device supports that have
already extended the entry tables to add routines for their own purposes.
One of the worst is devCommonGpib.h which contains this:
typedef struct {
long number;
DEVSUPFUN funPtr[20];
} gDset;
It would be impossible to insert a new routine into the struct dset
defined in devSup.h without causing major headaches for years to come.
Similarly the driver support entry table gets defined and extended by
individual drivers. This is the definition in drvBitBusInterface.h:
struct drvBitBusEt {
long number;
DRVSUPFUN report; /* Report status of Bit Bus links */
DRVSUPFUN init; /* Init the xvme card */
DRVSUPFUN qReq; /* Queue a transaction request */
I don't like the way these interfaces were designed, but there's not much
we can do about them now if we're going to keep to the principle that any
change we make in Base which breaks backwards comptibility must cause a
compiler error rather than a runtime fault, which might be very subtle and
hard to trace.
- Andrew
There are 10 types of people in the world:
Those who understand binary, and those who don't.
- RE: Why we can't extend the DSET or DRVET Jeff Hill
Re: [EPICS Base R3.14.x 0000029]: Access Security host names should be case insensitive Marty Kraimer
<2003>
2025
2026
<2003>
2025
2026
