2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS base V4: iocCore database
To: Jeff Hill <[email protected]>
Cc: 'Marty Kraimer' <[email protected]>, 'Andrew Johnson' <[email protected]>, 'Bob Dalesio' <[email protected]>, 'Ralph Lange' <[email protected]>, 'Eric Norum' <[email protected]>, 'Ken Evans' <[email protected]>, 'Ned Arnold' <[email protected]>, 'Matej Sekoranja' <[email protected]>
Date: Wed, 23 Feb 2005 17:10:02 +0100
On Wednesday 23 February 2005 16:48, Jeff Hill wrote:
> > The bottom line is that unsigned types should be used only in
> > the very few cases where they are essential to
> > faithfully represent raw hardware values.
> I find that unsigned types are quite useful for situations where
> the operand must never be negative. For example, with array
> indexes this improves performance and simplifies the code when
> range checking because only one side of the range check need be
> done. Of course, I can't expect that everyone will agree :-)
I thought it was obvious from the context (but maybe I should have stated it
explicitly) that I was only talking about record field and corresponding CA
data types, not programming in general. Record field values are rarely used
directly as indices into arrays and even if they would be, the overhead
involved in using them would be orders of magnitude larger than any overhead
due to additional range checks.
Ben
RE: EPICS base V4: iocCore database Jeff Hill
Prev: Re: EPICS base V4: iocCore database Marty Kraimer
Next: RE: EPICS base V4: iocCore database Kenneth Evans, Jr.
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS base V4: iocCore database Jeff Hill
Next: RE: EPICS base V4: iocCore database Jeff Hill
