2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: views
To: Kay-Uwe Kasemir <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Wed, 29 Jun 2005 12:36:07 -0500
Kay-Uwe Kasemir wrote:
The current wiki calc example has a default "result" view,
other record types have "value" view.
It doesn't really matter what the name of the default view is, since the whole point of the default view is purely to determine which one you get when you just specify "fred". If you know you're pointing at a calc record you can still say "fred" or "fred.result" and you'll get the same data, but in general it's advisable to use just "fred" since it permits me to convert the record to some other type without it affecting your client (as long as it supports the same properties you're looking at).
Would it make sense to have all records support a "value" view?
No; in V3 every record type must have a VAL field, but it really doesn't make sense for some record types - the V3 transform record initializes its VAL field to 0.0 and then ignores it forever after. I want to avoid this kind of "got to do it even if I don't need it" requirement in V4, and I'm also encouraging the use of more descriptive names. The "value" of a calc record could arguably be either the expression itself or its result, so I thought it appropriate to not have a "value" view at all (although that particular example was more to demonstrate that the default view could be called something other than "value").
Should there be default views "value", "control", "display",...
similar to the existing DBR_.. types?
No. A record's default view should contain the union of all of the display, control and other properties that are appropriate for the record, so there should never be views called "control" and "display" that just mirror the existing DBR_ types. If an MEDM widget only wants the display properties of a channel it should subscribe with a property catalog that only contains those properties, which avoids their being sent over the wire unnecessarily.
There will probably be some common conventions we adopt for naming views -- maybe AI, BI and MBBI records should have "raw" and "engineering" views and no "value" view (the default views would be "engineering") -- but they should only be used where appropriate.
There is still a question in my head about the distinction between the terms View and Controller in the MVC model on which I'd appreciate some input from others - should we allow just any view to be used for a put, or do we want to have some way of defining which views and/or properties in a view are permitted? I believe that it's not possible to put a DBR_CTL_DOUBLE in V3, how should we convert that rule into V4 terms?
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
dataAccess V4 Ca client propertyId questions Marty Kraimer
Re: dataAccess V4 Ca client propertyId questions Kay-Uwe Kasemir
Re: dataAccess V4 Ca client propertyId questions Andrew Johnson
views Kay-Uwe Kasemir
Prev: Re: dataAccess V4 Ca client propertyId questions Marty Kraimer
Next: Record support and user-defined fields Benjamin Franksen
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: views Kay-Uwe Kasemir
Next: Re: dataAccess V4 Ca client propertyId questions Ralph Lange
