2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record support and user-defined fields
To: EPICS Core Talk <[email protected]>
Date: Mon, 11 Jul 2005 07:55:28 -0500
Andrew Johnson wrote:
I like Ben's idea of introducing type parameters into the DBD file, but I want to make some changes to his struct support. I'd like to distinguish between a struct (which should only contain plain data) and a class (which also has methods that have to be implemented in C++ code). It would obviously save effort if we only have to write the alarm limits checking code once as a template, which can then be instanciated for all types as needed, and this starts to break up a record into smaller modules that have a defined functionality. The parent record type code would still be responsible for connecting all of the modules together into a cohesive whole record.
I think the DBD files should only define structs, i.e. only describe data.
I do not see why implementing "record fragment" support like alarm checking requires class definitions in DBD files. The only thing that should appear in the DBD file is the struct containing the data.
Also templates should not appear in the DBD files. This can be done by properly defining interfaces which are implemented by "record fragment".
There should not be ANY language specific definitions in DBD or DB files.
I also wonder how much C++ STL we should allow into record support.
Marty
Re: Record support and user-defined fields Benjamin Franksen
V4 iocRecord: forward linking Ralph Lange
Re: Record support and user-defined fields Kay-Uwe Kasemir
Re: Record support and user-defined fields Andrew Johnson
Prev: Re: V4 EpicsString Benjamin Franksen
Next: Re: Record support and user-defined fields Benjamin Franksen
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Record support and user-defined fields Benjamin Franksen
