2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: strings
To: [email protected]
Date: Tue, 4 Oct 2005 13:49:41 +0200
On Thursday 29 September 2005 17:06, Kay-Uwe Kasemir wrote:
> On Sep 29, 2005, at 10:13 , Andrew Johnson wrote:
> > I am not providing cast operators, and to some extent I agree about
> > the difficulty reading code that uses them.  However the assignment
> > operator= is an integral part of C++ that the compiler will create
> > for you (usually wrongly) if you don't explicitly tell it not to.
> .. right, which makes it more of a C--
Careful, "C--" is an already existing language. It was intended as a
replacement for C when used as a portable assembler for high-level
languages. See http://www.cminusminus.org/ for details.
Ben
RE: data access structures, strings Jeff Hill
Re: strings Andrew Johnson
Re: strings Kay-Uwe Kasemir
Prev: Re: data access structures, strings Andrew Johnson
Next: Re: strings Benjamin Franksen
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: strings Benjamin Franksen
Next: Re: data access structures, strings Marty Kraimer
