Marty Kraimer wrote:
I like the char * pointer for things like record type names, record
instance names, etc.(for java a regular String would accomplish the same
thing) This would take care of one main use of names
It does mean that we can not completely delete anything that has such
names because the storage for at least the name will remain. For example
we can not completely delete a record instance. I think this is OK.
Record instance names will have to be taken off the heap, and thus can
be returned to it when records are deleted. The distinction between the
strings that will be in the code segment and those that come from the
heap is relatively simple: anything named in a DBD file will be
compiled, so these names are not changable; anything named on the
command line or in a DB file is read at runtime and will thus have the
storage for the string allocated off the heap.
I think this is actually exactly what we want anyway, since items that
are compiled in are stongly related to source code and may even come
from an extension that might even be linked in from a DLL/shared
library; the code will often have some dependency on the string text
anyway (field names etc). To change those kinds of things at runtime
would mean unloading the DLL/library and reloading a different version,
which is probably rather dangerous; these strings would use just char*
pointers, and can be wrapped with a ConstString if necessary.
Record names and other things that get configured on the command line
are something that we're more likly to want to be able to change at
runtime, and thus those items should probably use some kind of mutable
string to store them.
In my design any const char* buffer or literal can be wrapped with a
ConstString at the point of use if it has to be passed to a routine
that takes a StringReader. Ownership would never be passed that way
though.
Can we accomplish the same thing without exposing the entire String class?
Why would you want that?
Something like:
interface DbInstance {
ConstString *getName();
You're better off just returning a const StringReader*, which has fewer
methods than ConstString (but doesn't support the c_str() method). Note
that even if internally you use a mutable string type to implement the
name, you should return a const StringReader* if you're only giving out
read access to the string, or even (if you're Jeff) require the caller
to pass in a StringEditor which you copy the name into.
In C++ your example might be:
class DbInstance {
virtual const StringReader* getName() const = 0;
or even:
class DbInstance {
virtual void getName(StringEditor& name) const = 0;
In Java though, we should use the native String class:
public interface DbInstance {
public abstract String getName();
or:
public abstract void getName(String name);
- Andrew
English probably arose from Normans trying to pick up Saxon girls.
- RE: data access structures, strings Jeff Hill
- Re: data access structures, strings Kay-Uwe Kasemir
- Re: data access structures, strings Andrew Johnson
- Re: data access structures, strings Marty Kraimer
RE: core meeting possible on wednesday 20:00 Dalesio, Leo `Bob`
Re: strings Benjamin Franksen
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
