2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: data access structures, strings
To: Marty Kraimer <[email protected]>
Cc: [email protected]
Date: Thu, 29 Sep 2005 14:19:24 -0500
Marty Kraimer wrote:
Thus all the IOC database needs is a:
1) nonmutable reference counted continguous string. When the reference count goes to 0 the storage can be reclaimed
Since you're writing thread-safe code, the reference count also has to have an associated mutex to protect it from simultaneous updates from two threads. Each string might have its own mutex, or we might rely on a single central mutex to protect all reference counts - there are advantages and disadvantages to either choice, although the former is probably better for performance since there will be many fewer clashes.
Note that a published study has shown that in a threaded environment the time to take and release the mutex around every increment/decrement operation completely nullifies the speed advantage of using reference counting over copying for a string implementation. I'm not claiming this definitely applies in our case since their usage of the strings differed from ours, but the performance hit from that mutex is something to bear in mind. I'm also not convinced that the string itself is the right place for the reference count when it's embedded in a larger data structure like a field descriptor or record type descriptor.
We might need more than one implementation of the nonmutable string; one where the storage is obtained from the system (new/malloc), and a second where the storage is a char* literal that must not be freed when it's no longer referenced. Compiling DBD files generates literals for record type names, field names and menu choice strings. I think we should just store the char* pointer in these cases without using any kind of string wrapper - if any reference count exists it would have to apply to the descriptor as a whole, not just to the name string.
In my design any const char* buffer or literal can be wrapped with a ConstString at the point of use if it has to be passed to a routine that takes a StringReader. Ownership would never be passed that way though.
What the IOC database needs for strings is very different than what dataAccess requires.
However if we can agree on a common string API it will make the iocCore code much easier to understand overall, and will probably save us from duplication of common tasks. I believe that my current design is an acceptable compromise, and so far nobody has raised any significant objections to it.
- Andrew
English probably arose from Normans trying to pick up Saxon girls.
RE: data access structures, strings Jeff Hill
Re: data access structures, strings Marty Kraimer
Re: data access structures, strings Kay-Uwe Kasemir
Re: data access structures, strings Andrew Johnson
Prev: RE: data access structures, strings Jeff Hill
Next: RE: data access structures, strings Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
