Andrew Johnson wrote:
Marty Kraimer wrote:
Thus all the IOC database needs is a:
1) nonmutable reference counted continguous string. When the
reference count goes to 0 the storage can be reclaimed
We might need more than one implementation of the nonmutable string;
one where the storage is obtained from the system (new/malloc), and a
second where the storage is a char* literal that must not be freed
when it's no longer referenced. Compiling DBD files generates
literals for record type names, field names and menu choice strings.
I think we should just store the char* pointer in these cases without
using any kind of string wrapper - if any reference count exists it
would have to apply to the descriptor as a whole, not just to the name
string.
I like the char * pointer for things like record type names, record
instance names, etc.(for java a regular String would accomplish the same
thing) This would take care of one main use of names
It does mean that we can not completely delete anything that has such
names because the storage for at least the name will remain. For example
we can not completely delete a record instance. I think this is OK.
In my design any const char* buffer or literal can be wrapped with a
ConstString at the point of use if it has to be passed to a routine
that takes a StringReader. Ownership would never be passed that way
though.
Can we accomplish the same thing without exposing the entire String class?
Something like:
interface DbInstance {
ConstString *getName();
- Re: data access structures, strings Andrew Johnson
- RE: data access structures, strings Jeff Hill
- Re: data access structures, strings Kay-Uwe Kasemir
- Re: data access structures, strings Marty Kraimer
Re: PP and MS Marty Kraimer
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
