2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: strings
To: Kay-Uwe Kasemir <[email protected]>
Cc: [email protected]
Date: Thu, 29 Sep 2005 09:13:18 -0500
Kay-Uwe Kasemir wrote:
On Sep 27, 2005, at 13:04 , Andrew Johnson wrote:
I agree that it's initially more convenient to be able to
use the operators.
But in the long run, it causes the C++ and e.g. Java sources
differ, and in C++ I also find it difficult to understand what's
called when everything has cast and assignment operators.
I am not providing cast operators, and to some extent I agree about the difficulty reading code that uses them. However the assignment operator= is an integral part of C++ that the compiler will create for you (usually wrongly) if you don't explicitly tell it not to. I believe it makes more sense to make use of the facilities provided by the language than to try and suppress them, so I'm providing the convenience operators. If you want your code to be easily translated into Java you're not forced to use them to manipulate strings.
operator[] is not currently implemented in that fashion, but I am willing to do that too (although I don't like your name so I will probably change it).
class StringReader {
public:
    // Individual byte access
    virtual char at(size_t pos) const = 0;
    // Overloaded operator, not virtual
    char operator[] (size_t pos) const;
I'm now using the std::string name at() which will throw some kind of out_of_range exception if pos points beyond the end of the string. The inline overloaded operator[] is now just an inline synonym for at(), which is different to std::string but safer - std::string::operator[] does no checking of pos.
- Andrew
English probably arose from Normans trying to pick up Saxon girls.
Re: strings Kay-Uwe Kasemir
RE: data access structures, strings Jeff Hill
Re: data access structures, strings Kay-Uwe Kasemir
Re: data access structures, strings Andrew Johnson
Prev: Re: EPICS Meeting agenda Marty Kraimer
Next: RE: EPICS Meeting agenda Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: strings Kay-Uwe Kasemir
Next: Re: strings Kay-Uwe Kasemir
