2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: V4 DB RecordCommon: Suggestion for alarmAckTransient (ACKT replacement)
To: EPICS Core Talk <[email protected]>
Date: Thu, 20 Oct 2005 11:34:52 +0200
The following just became obvious in BESSY real life:
There are channels where the attached hardware latches the error status. The operator has to actively "error reset" the device to make the error bits go back to green. In such cases, you don't want to have to acknowledge those alarms additionally in the Alarm Handler. So we set ACKT to false for such error bits. BUT: In cases of transiently failing connections (such as loose field bus plugs or short hangup states followed by quick reboots of the remote hardware) we are losing this failure information because also the resulting transient INVALID status doesn't need to be acknowledged.
Suggestion:
Change the type of alarmAckTransient from boolean to menu(menuAlarmSevr) and redefine it as "highest level of alarm that does not have to be acknowledged". Doesn't need more space in the DB and allows for nice and subtle configuration options: e.g. warnings that don't have to be ack'ed while errors do.
What do you think?
Cheers,
Ralph
Re: V4 DB RecordCommon: Suggestion for alarmAckTransient (ACKT replacement) Marty Kraimer
Prev: Re: Link arrays / syntax Andrew Johnson
Next: [Fwd: EPICS V4 requirement ?] Marty Kraimer
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: FW: Ice GPL based Licensing Jeff Hill
Next: Re: V4 DB RecordCommon: Suggestion for alarmAckTransient (ACKT replacement) Marty Kraimer
