Hmm...
You're mixing granularity levels: Nowadays every PV name that doesn't
contain a dot is regarded as a record name.
EPICS V4
So, when you're aliasing [particular_device].Setpoint to [particular_record].VAL
any generic or display tool will soon start asking for things like [particular_device].Setpoint.EGU
.RTYP .DRVH .DRVL .STAT .SEVR
and
so on and so on.
Do you want to create explicit alias definitions for all (pseudo)
fields of that (pseudo) device record? You will end up with zillions of
alias definitions on a single IOC.
If you try to escape by aliasing only on the same (record) level, you
don't gain as much. Simply having other names for records just creates
ambiguity - which of the many names for the same record do you use for
archiving? For snapshots? For the alarms? How do you compare snapshots
that contain the same record under different names?
Guess this needs more thought - maybe too simple?!
Ralph
Marty Kraimer wrote:
If I
read this correctly it is just asking for the CA server to support
aliases.
Marty
[email protected] wrote:
Hmmm, a clever and simple idea.
� Ned
- Re: Control System Data Access API Claude Saunders
- Re: Fwd: Control System Data Access API Marty Kraimer
Re: V4 DB RecordCommon: Suggestion for alarmAckTransient (ACKT replacement) Marty Kraimer
Re: Link arrays / syntax Ralph Lange
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
