I'm of the opinion that a device layer needs to be a separate namespace
entirely, not just aliasing within the same (CA) namespace (for the same
reasons Ralph raised). That's not to say it still can't be a part of CA
server, or a separate gateway. Aliasing within the same namespace is
mainly useful for protecting applications from changing underlying
implementations (as in the set of linked records to provide a single
value). We have such aliasing now with the gateway.
Secondly, I think one of the big benefits of a "device layer" is the
ability to bring to bear other resources such as a relational database.
So an atomic write to a [particular device].setpoint would actually wind
up kicking off a write to data access and a relational database (for
whatever reason).
Of course, what I'm suggesting is more complicated .... :)
- Claude
Ralph Lange wrote:
Hmm...
You're mixing granularity levels: Nowadays every PV name that doesn't
contain a dot is regarded as a record name.
So, when you're aliasing [particular_device].Setpoint to
[particular_record].VAL any generic or display tool will soon start
asking for things like [particular_device].Setpoint.EGU .RTYP .DRVH
.DRVL .STAT .SEVR and so on and so on.
Do you want to create explicit alias definitions for all (pseudo)
fields of that (pseudo) device record? You will end up with zillions
of alias definitions on a single IOC.
If you try to escape by aliasing only on the same (record) level, you
don't gain as much. Simply having other names for records just creates
ambiguity - which of the many names for the same record do you use for
archiving? For snapshots? For the alarms? How do you compare snapshots
that contain the same record under different names?
Guess this needs more thought - maybe too simple?!
Ralph
Marty Kraimer wrote:
If I read this correctly it is just asking for the CA server to
support aliases.
Marty
[email protected] wrote:
Hmmm, a clever and simple idea.
Ned
- Re: Fwd: Control System Data Access API Marty Kraimer
- Re: Control System Data Access API Ralph Lange
Re: Control System Data Access API Kay-Uwe Kasemir
alarm/severity Kay-Uwe Kasemir
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
