2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: R3.14.8 Status/logClient patch
To: "'Benjamin Franksen'" <[email protected]>
Cc: <[email protected]>
Date: Wed, 16 Nov 2005 13:56:04 -0700
Ben,
I did think of one issue. This is using non blocking IO after the connect
completes. It appears that a delta is that the logRestart thread is now
doing the periodic flush for *multiple* logging circuits. Therefore, if one
of the log circuits isnt flowing for whatever reason (disk full, marginal
circuit, server system power off, etc), then all of the other log circuits
will not be flushed untill logClientSend is called and the specified message
will not fit (the buffers capacity is exceeded). Since the internal IP
kernel timeouts for circuit disconnect can be quite long this might prove to
be problematic.
Jeff
> -----Original Message-----
> From: Benjamin Franksen [mailto:[email protected]]
> Sent: Wednesday, November 16, 2005 10:17 AM
> To: [email protected]
> Subject: Re: R3.14.8 Status/logClient patch
> On Wednesday 16 November 2005 14:03, Benjamin Franksen wrote:
> > What should I do?
> Ok, problem solved. Everything is completely backward compatible now.
> See release notes snippet for details. The relevant section for the
> AppDevGuide is not yet done (it didn't contain anything until now).
> BTW, what is the source format for that, or is plain text ok?
> Ben
> PS: Attached tar file can be unpacked inside
> /path/to/base/src/libCom.
> It contains a patched Makefile and a snippet for the release notes.
Re: R3.14.8 Status/logClient patch Benjamin Franksen
Prev: epicsAtExit Marty Kraimer
Next: Re: epicsAtExit Andrew Johnson
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: R3.14.8 Status/logClient patch Benjamin Franksen
Next: Re: R3.14.8 Status/logClient patch Benjamin Franksen
