2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.14.8 Status/logClient patch
To: [email protected]
Date: Thu, 17 Nov 2005 01:06:30 +0100
On Wednesday 16 November 2005 21:56, Jeff Hill wrote:
> I did think of one issue. This is using non blocking IO after the
> connect completes. It appears that a delta is that the logRestart
> thread is now doing the periodic flush for *multiple* logging
> circuits. Therefore, if one of the log circuits isnt flowing for
> whatever reason (disk full, marginal circuit, server system power
> off, etc), then all of the other log circuits will not be flushed
> untill logClientSend is called and the specified message will not fit
> (the buffers capacity is exceeded). Since the internal IP kernel
> timeouts for circuit disconnect can be quite long this might prove to
> be problematic.
Hi Jeff,
the simplest way out is to use multiple restart/flush threads, one for
each log client. It appears that this has the side-advantage of
somewhat simplifying the code since global variables are no longer
needed.
Caveat: I don't know what applications (beside the standard ioc log) use
the logClient facility. If there exist applications that create a lot
of such clients this would unduly increase IOC load. I don't believe
that this is the case, though, it doesn't make much sense. At the
moment I am aware of only one custom application that will use the
feature at all, namely caPutLog, although others are conceivable.
Ben
PS: One could also use non-blocking send and multiplex clients with a
select call. This would probably be more complex and also harder to do
in a portable manner, thorough testing on different platforms etc. No
way to get this into R3.14.8.
RE: R3.14.8 Status/logClient patch Jeff Hill
Prev: converging Jeff Hill
Next: RE: R3.14.8 Status/logClient patch Jeff Hill
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: R3.14.8 Status/logClient patch Benjamin Franksen
