2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.14.8 Status/logClient patch
To: [email protected]
Date: Wed, 16 Nov 2005 22:11:51 +0100
On Wednesday 16 November 2005 21:56, Jeff Hill wrote:
> Ben,
> I did think of one issue. This is using non blocking IO after the
> connect completes. It appears that a delta is that the logRestart
> thread is now doing the periodic flush for *multiple* logging
> circuits. Therefore, if one of the log circuits isnt flowing for
> whatever reason (disk full, marginal circuit, server system power
> off, etc), then all of the other log circuits will not be flushed
> untill logClientSend is called and the specified message will not fit
> (the buffers capacity is exceeded). Since the internal IP kernel
> timeouts for circuit disconnect can be quite long this might prove to
> be problematic.
I see. I need to think about a solution. Thanks for the hint.
Cheers,
Ben
RE: R3.14.8 Status/logClient patch Jeff Hill
Prev: Re: epicsAtExit Andrew Johnson
Next: Re: epicsAtExit Kay-Uwe Kasemir
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: R3.14.8 Status/logClient patch Jeff Hill
Next: Re: R3.14.8 Status/logClient patch Benjamin Franksen
