2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mrkSoftTest doesn't compile
To: Janet Anderson <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Thu, 17 Nov 2005 16:46:42 +0100
Hi Janet,
Janet Anderson wrote:
Ralph Lange wrote:
Hi Janet,
I don't have any system with a gcc 4 running - it's all gcc 3.
I do *NOT* have 3.14.7 in my mrkSoftTest/configure/RELEASE.
Why does 3.14.7 base appear in the -L option of the link lines?
I don't know. That's why I'm asking.
It seems that things within the 3.14 build system set it that way.
I intentionally create 2 -Wl options, because here the location of Base differs between development and production systems. To be able to run the exe on both worlds, I'm compiling both paths into the binaries: the local - for development, and the generic - for the production systems.
Is it illegal to use two compiled-in paths? From first glance I wouldn't see why. Does the build system rely on just one path being defined? If so: Is that limitation justified?
When you say system do you mean subnet. If not how do you switch the .exe
between systems.
I mean system. And I don't switch exes.
There's one development machine within our office network.
There are multiple production machines in different subnets, including our office network. I'm compiling on the development machine, then distribute Base's bin, lib and include folders to all production machines, near and far. The location on all production machines is the generic one, on the development machine I have to use my development location, as the generic location does not exist. I want the exes to run in all places.
No, its not illegal and the build system does not rely on only 1 path.
Still the build system seems to create the -L location from what's defined for the compiled-in paths, obviously taking the first path that's mentioned there.
Clueless,
Ralph
Hi Ralph,
Is it possible that your R3.14.7 EPICS base on linux was built with gcc version 3 and you are now building with gcc version 4?
Why do you have R3.14.7 in your mrkSoftTest/configure/RELEASE file? You shouldn't have 2 -Wl options for EPICS base.
Janet
Ralph Lange wrote:
Marty,
mrkSoftTest doesn't compile aymore (neither on HP nor on Linux):
aCC -o access -L/opt/epics/R3.14.7/base/3-14-7-0/lib/hpux-parisc/ -AA -mt -Wl,+b/home/unix/lange/work/epics/APS/epics/base/3-14-X/lib/hpux-parisc:/home/unix/lange/work/epics/APS/epics/extensions/lib/hpux-parisc:/opt/epics/R3.14.7/base/3-14-7-0/lib/hpux-parisc,+s access_registerRecordDeviceDriver.o asinittest.o asTest.o asTrapWriteTest.o accessMain.o -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
/usr/ccs/bin/ld: Unsatisfied symbols:
pvar_int_dbRecordsOnceOnly (first referenced in access_registerRecordDeviceDriver.o) (data)
On Linux:
/usr/bin/g++ -o common -L/opt/epics/R3.14.7/support/base/3-14-7-0/lib/linux-x86/ -Wl,-rpath,/opt/epics/R3.14.7/support/base/3-14-7-0/lib/linux-x86 -Wl,-rpath,/home/unix/lange/work/epics/APS/epics/base/3-14-X/lib/linux-x86 -Wl,-rpath,/home/unix/lange/work/epics/APS/epics/extensions/lib/linux-x86 devAiAsyn.o common_registerRecordDeviceDriver.o commonMain.o -ltestDevIoc -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom common_registerRecordDeviceDriver.o(.text+0x4a1): In function `__static_initialization_and_destruction_0': /net/unix/mnt/csr-home/lange/work/epics/APS/epics/mrkSoftTest/common/src/O.linux-x86/common_registerRecordDeviceDriver.cpp:264: undefined reference to `pvar_int_dbRecordsOnceOnly'
I don't see any changes in mrkSoftTest, though. Strange. I'm pretty sure you know faster than me what's wrong ...
Ralph
mrkSoftTest doesn't compile Ralph Lange
Re: mrkSoftTest doesn't compile Ralph Lange
Prev: RE: R3.14.8 Status/logClient patch Jeff Hill
Next: Re: mrkSoftTest doesn't compile Ralph Lange
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mrkSoftTest doesn't compile Ralph Lange
Next: Mantis 207 Jeff Hill
