2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mrkSoftTest doesn't compile
To: Janet Anderson <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Thu, 17 Nov 2005 18:28:16 +0100
Wow! That actually did the job!
Thanks a lot!!!!
Seems I missed to patch the CONFIG_SITE stuff for hpux and Linux to reflect subtle changes in the build system that were introduced last year. So probably I was actually compiling my mrkSoftTest against an older version of the libraries while using the current version when running the exe.
Geee, what a mess. I'm glad that it broke at some time, so it's fixed now. THANKS!
Ralph
Janet Anderson wrote:
Try renaming SHRLIB_SEARCH_DIRS to  SHRLIB_SEARCH_FULLPATHDIRS in
CONFIG_SITE.Common.hpux-parisc
and CONFIG_SITE.Common.linux-x86.
Janet
Ralph Lange wrote:
Don't think so. The -Wl options are correct, it's the -L stuff that uses the wrong location.
Ralph
You may need to remove the sort from the following line.
CONFIG.Common.hpux-parisc:RUNTIME_LDFLAGS = -Wl,+b$(subst $(space),:,$(sort $(SHRLIB_SEARCH_FULLPATHDIRS))),+s
Janet
Ralph Lange               [email protected]     Tel: +49 30 6392-2117
BESSY Controls Group      www.bessy.de             Fax:      ...   -4859
mrkSoftTest doesn't compile Ralph Lange
Re: mrkSoftTest doesn't compile Ralph Lange
Re: mrkSoftTest doesn't compile Andrew Johnson
Prev: Re: [Fwd: R3.14.8 testing: epicsMessageQueueTestHost fails on linux-x86] Ernest L. Williams Jr.
Next: RE: dbEvent.c line 665 Jeff Hill
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mrkSoftTest doesn't compile Ralph Lange
Next: Re: mrkSoftTest doesn't compile Ralph Lange
