OK - here are our latest findings:
First - the Bottom line: The RTEMS network code does not work as
expected. Calling socket_ioctl() with SIOCGIFCONF does return also
AF_LINK structures, not just AF_INET interfaces, as the linux man page says.
Here's some debugging output of what's coming up. The AF_LINK structures
have a length of 54 (0x36), which adds up to 70 adding the 16 characters
for the name. 70 is not divisable by 4, so the ARM crashes when the BSD
net code gets called with a pointer to the following structure.
rtems-4.6.99.3/cpukit/libnetworking/net/if.c :
(hex code shows sockaddr.sa_data)
ifconf() eth0 (IFACE 1)
ifnetdebuginfo() Flags: IFF_UP IFF_BROADCAST IFF_RUNNING
ifconf() ifa->ifa_addr
socketdebuginfo() adress len: 0x36
socketdebuginfo() AF_LINK
01 00 06 04 06 00 65 74 68 30 00 01 af 14 cd 5b 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ifconf() sa_len doesn't fit into struct sockaddr
socketdebuginfo() adress len: 0x10
socketdebuginfo() AF_INET
00 00 c1 95 0c cd 00 00 00 00 00 00 00 00 10 02
ifconf() sa_len fits into struct sockaddr
ifconf() lo0 (IFACE 2)
ifnetdebuginfo() Flags: IFF_UP IFF_LOOPBACK IFF_RUNNING IFF_MULTICAST
02 00 18 03 00 00 6c 6f 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 7f 00 00 01 00 00 00 00 00 00 00 00 00 00
ifconf() space: 2996, ifc_len: 3200
The linux manpage for netdevice says:
SIOCGIFCONF
Return a list of interface (transport layer) addresses.
This currently means only addresses of the AF_INET (IPv4)
family for compatibility. The user passes a ifconf struc-
ture as argument to the ioctl. It contains a pointer to an
array of ifreq structures in ifc_req and its length in
bytes in ifc_len. The kernel fills the ifreqs with all
current L3 interface addresses that are running: ifr_name
contains the interface name (eth0:1 etc.), ifr_addr the
address. The kernel returns with the actual length in
ifc_len. If ifc_len is equal to the original length the
buffer probably has overflowed and you should retry with a
bigger buffer to get all addresses. When no error occurs
the ioctl returns 0; otherwise -1. Overflow is no error.
So - what to do?
We are suggesting to keep the double buffer: memcpy()ing whatever is
coming up into a local buffer which is word-aligned, and handing a
pointer to that copy down in subsequent socket_ioctl() calls. This
doesn't use much space and time and should be safe - no matter what is
coming up in the ifreq array. osiSockDiscoverBroadcastAddresses() isn't
called much anyway.
Jeff: should I commit that patch to the APS repository for 3.14 and the
trunk? Or send it to you first?
The CA data garble issue was solved by applying the patch from Peter
Denison. Do you want me to commit that, too?
Thanks again to both of you for your valuable help!!
Ralph & Ralf
- Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Eric Norum
- RE: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Jeff Hill
- Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Ralph Lange
<2006>
2025
2026
<2006>
2025
2026
