2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Redundancy Patch: iocsh
Cc: EPICS core-talk <[email protected]>
Date: Mon, 19 Nov 2007 18:28:38 +0100
Hi, Andrew,
Thank you for quick response. I compile the base with your patch just now. But the error messages are same, the details see below.
Gongfa
Andrew Johnson wrote:
Liu, Gongfa wrote:
The following is the email copied from [email protected]. The compiler error is same in our case. Maybe this compiler error can be ignored here since it is not related to the redundancy patch.
 > From: Graham Waters [mailto:[email protected]]
 > /usr2/tornado/release/2.2.1/x86/host/sun4-solaris2/bin/ccpentium -c
 > -D_POSIX_SOURCE       -DCPU=PENTIUM -D_X86_   -DvxWorks -include
 > /usr2/tornado/release/2.2.1/x86/target/h/vxWorks.h  -ansi  -O3  -Wall
 >    -mpentium -fno-defer-pop -x 'c++'  -fno-implicit-templates
> -fno-builtin -I. -I.. -I../../../include/os/vxWorks -I../../../include
 >        -I/usr2/tornado/release/2.2.1/x86/target/h  ../iocsh.cpp
 > ..../iocsh.cpp: In function `void iocshRegisterVariable (const
 > iocshVarDef
 > ..../iocsh.cpp:133: Internal compiler error in `expand_expr', at
 > expr.c:5996
Ok, we think that the Pentium compiler may have an internally defined macro called 'varArgs', which is the name of the variable at the error location. Please try this patch (the diff is against the original R3.14.9 file), which instead renames that group of variables:
gmake[3]: Entering directory `/import/epicsf2/user/group/mks/gliu/EpicsR3.14.9/base-3.14.9/src/iocsh/O.vxWorks-pentium' /u1/wind/2.2.1_Pentium/host/sun4-solaris2/bin/ccpentium -c -DCPU=PENTIUM -D_X86_ -DvxWorks -include /u1/wind/2.2.1_Pentium/target/h/vxWorks.h -ansi -O2 -Wall -mpentium -fno-defer-pop -x 'c++' -fno-implicit-templates -fno-builtin -I. -I.. -I../../../include/os/vxWorks -I../../../include -I/u1/wind/2.2.1_Pentium/target/h ../iocsh.cpp ../iocsh.cpp: In function `void iocshRegisterVariable (const iocshVarDef *)':
../iocsh.cpp:158: Internal compiler error in `expand_expr', at expr.c:5996
gmake[3]: *** [iocsh.o] Error 1
Index: iocsh.cpp
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/iocsh/Attic/iocsh.cpp,v
retrieving revision 1.9.2.35
diff -u -b -r1.9.2.35 iocsh.cpp
--- iocsh.cpp   12 Dec 2006 21:04:19 -0000      1.9.2.35
+++ iocsh.cpp   19 Nov 2007 16:53:58 -0000
@@ -147,10 +147,10 @@
     struct iocshVariable *l, *p, *n;
     int i;
     int found;
-    static const iocshArg varArg0 = { "[variable",iocshArgString};
-    static const iocshArg varArg1 = { "[value]]",iocshArgString};
-    static const iocshArg *varArgs[2] = {&varArg0, &varArg1};
-    static const iocshFuncDef varFuncDef = {"var",2,varArgs};
+    static const iocshArg varCmdArg0 = { "[variable",iocshArgString};
+    static const iocshArg varCmdArg1 = { "[value]]",iocshArgString};
+    static const iocshArg *varCmdArgs[2] = {&varCmdArg0, &varCmdArg1};
+    static const iocshFuncDef varFuncDef = {"var",2,varCmdArgs};
     iocshTableLock ();
     while ((piocshVarDef != NULL)
- Andrew
Gongfa Liu                         MKS-2, DESY
phone:  +49-40-8998-1642           Notkestr. 85
fax:    +49-40-8998-4388           22607 Hamburg
e-mail: [email protected]         Germany
Re: Redundancy Patch: iocsh Andrew Johnson
Re: Redundancy Patch: iocsh Liu, Gongfa
Prev: Re: Redundancy Patch: iocsh Andrew Johnson
Next: Re: Redundancy Patch: iocsh Andrew Johnson
Index: 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
