All,
I have discovered that a PCAS hang can occur when clients
are fetching very large arrays as strings. Just to convert the number of
elements that fit in a very large EPICS_CA_MAX_ARRAY_SIZE buffer with
epicsSnPrintf can take a very long time. It appears that this required about 33
seconds during testing with EPICS_CA_MAX_ARRAY_SIZE of 10,000,000. Based on
that I calculate 33 / ( 10,000,000 / MAX_STRING_SIZE ) is 0.000132 seconds per
conversion. Is epicsSnPrintf() really that slow?
The solution appears to be to use the cvtFast library where
it is in range in GDD’s aitConvert.cc. The cvtFast functions are a bit scary
in today’s world - because a buffer size isn’t passed in –
BTW. The current workaround is to just not use them for buffer sizes below some
threshold.
Jeff
______________________________________________________
Jeffrey O. Hill
Email [email protected]
LANL MS
H820
Voice 505 665 1831
Los Alamos NM 87545 USA
FAX 505 665 5107
Message content:
TSPA
RE: CA Priority for PV Gateway Jeff Hill
Re: Base R3.14.11-pre1 available for testing J. Lewis Muir
<2009>
2025
2026
RE: epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc Jeff Hill
<2009>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
