Ø 0.000132
seconds per conversion - is epicsSnPrintf() really that slow?
To answer my own question; no. I
just finished adding cvtFastPerform.cpp to libCom/tests and it looks like double
to string conversion take more like 3 uSec worst case which is about 44 times
faster than calculated.
Nevertheless, I am curious. What
is the largest array size being communicated via the gateways at SLAC and at
PSI? This might become a big issue for arrays exceeding say one million
elements (that are converted to strings by the gateway).
Still bug hunting.
Jeff
______________________________________________________
Jeffrey O. Hill
Email [email protected]
LANL
MS
H820
Voice 505 665 1831
Los Alamos NM 87545 USA
FAX 505 665 5107
Message
content: TSPA
[mailto:[email protected]]
Sent: Wednesday, July 22, 2009 6:13 PM
To: 'Dirk Zimoch'; 'Ralph Lange'; 'Ernest L. Williams Jr.'; 'Amedeo
Perazzo'
Cc: 'Core-Talk'
Subject: epicsSnPrintf is very slow when converting string arrays in
GDD's aitConvert.cc
All,
I have discovered that a PCAS hang can occur when clients
are fetching very large arrays as strings. Just to convert the number of
elements that fit in a very large EPICS_CA_MAX_ARRAY_SIZE buffer with
epicsSnPrintf can take a very long time. It appears that this required about 33
seconds during testing with EPICS_CA_MAX_ARRAY_SIZE of 10,000,000. Based on
that I calculate 33 / ( 10,000,000 / MAX_STRING_SIZE ) is 0.000132 seconds per
conversion. Is epicsSnPrintf() really that slow?
The solution appears to be to use the cvtFast library where
it is in range in GDD’s aitConvert.cc. The cvtFast functions are a bit
scary in today’s world - because a buffer size isn’t passed in
– BTW. The current workaround is to just not use them for buffer sizes
below some threshold.
Jeff
Jeffrey O. Hill
LANL MS
H820
Voice 505 665 1831
FAX 505 665 5107
Message content:
TSPA
- Re: epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc Ernest L. Williams Jr.
- Re: epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc Dirk Zimoch
Re: Base R3.14.11-pre1 available for testing J. Lewis Muir
<2009>
2025
2026
epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc Jeff Hill
<2009>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
