2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc
To: Jeff Hill <[email protected]>
Cc: "'Amedeo Perazzo'" <[email protected]>, "'Core-Talk'" <[email protected]>, "'Ernest L. Williams Jr.'" <[email protected]>
Date: Fri, 24 Jul 2009 09:11:58 +0200
At the moment, I have EPICS_CA_MAX_ARRAY_BYTES=4000000 on the gateway.
But I found that the gateway already became slow with about 10 arrays of 2000 double each, processing with 10 Hertz. So it's probably not a question of the array length but of the total array elements per second.
But why should the gateway convert doubles to strings? A client that requests numeric arrays as strings instead of the native format is quite stupid.
Dirk
Jeff Hill wrote:
Ø  0.000132 seconds per conversion  - is epicsSnPrintf() really that slow?
To answer my own question; no. I just finished adding cvtFastPerform.cpp to libCom/tests and it looks like double to string conversion take more like 3 uSec worst case which is about 44 times faster than calculated.
Nevertheless, I am curious. What is the largest array size being communicated via the gateways at SLAC and at PSI? This might become a big issue for arrays exceeding say one million elements (that are converted to strings by the gateway).
Still bug hunting.
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected] <mailto:[email protected]>
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
*Sent:* Wednesday, July 22, 2009 6:13 PM
*To:* 'Dirk Zimoch'; 'Ralph Lange'; 'Ernest L. Williams Jr.'; 'Amedeo Perazzo'
*Cc:* 'Core-Talk'
*Subject:* epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc
All,
I have discovered that a PCAS hang can occur when clients are fetching very large arrays as strings. Just to convert the number of elements that fit in a very large EPICS_CA_MAX_ARRAY_SIZE buffer with epicsSnPrintf can take a very long time. It appears that this required about 33 seconds during testing with EPICS_CA_MAX_ARRAY_SIZE of 10,000,000. Based on that I calculate 33 / ( 10,000,000 / MAX_STRING_SIZE ) is 0.000132 seconds per conversion. Is epicsSnPrintf() really that slow?
The solution appears to be to use the cvtFast library where it is in range in GDD’s aitConvert.cc. The cvtFast functions are a bit scary in today’s world - because a buffer size isn’t passed in – BTW. The current workaround is to just not use them for buffer sizes below some threshold.
Jeff
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
RE: epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc Jeff Hill
Prev: RE: epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc Jeff Hill
Next: RE: epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
