Hi Jeff,
Here is an example of some the large arrays we have running around at
SLAC --LCLS:
FEE system
DIAG:FEE1:481:DISPLAYWF.NELM 262144
DIAG:FEE1:482:DISPLAYWF.NELM 262144
CAMR:FEE1:455:IMAGE.NELM 307200
E- system
YAGS:DMP1:500:IMAGE.NELM 1.44768e+06
CAMR:IN20:186:IMAGE.NELM 307200
By the way, why don't we suffer from these issues with the IOC core implementation of the CA Server (i.e. rsrv)?
Or maybe, there are some subtle issues with large arrays even for iocCore?
One of the work-arounds we are considering for the purposes of IOC-Load balancing is to use a softIOC
in front of the source IOC. Then most of our CA clients would make a connection to the softIOC
for a subscription to large arrays such as camera images.
What do you think?
Ernest
Jeff Hill wrote:
Ø 0.000132 seconds per conversion - is epicsSnPrintf() really that slow?
To answer my own question; no. I just finished adding
cvtFastPerform.cpp to libCom/tests and it looks like double to string
conversion take more like 3 uSec worst case which is about 44 times
faster than calculated.
Nevertheless, I am curious. What is the largest array size being
communicated via the gateways at SLAC and at PSI? This might become a
big issue for arrays exceeding say one million elements (that are
converted to strings by the gateway).
Still bug hunting.
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected] <mailto:[email protected]>
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
*Sent:* Wednesday, July 22, 2009 6:13 PM
*To:* 'Dirk Zimoch'; 'Ralph Lange'; 'Ernest L. Williams Jr.'; 'Amedeo
Perazzo'
*Cc:* 'Core-Talk'
*Subject:* epicsSnPrintf is very slow when converting string arrays in
GDD's aitConvert.cc
All,
I have discovered that a PCAS hang can occur when clients are fetching
very large arrays as strings. Just to convert the number of elements
that fit in a very large EPICS_CA_MAX_ARRAY_SIZE buffer with
epicsSnPrintf can take a very long time. It appears that this required
about 33 seconds during testing with EPICS_CA_MAX_ARRAY_SIZE of
10,000,000. Based on that I calculate 33 / ( 10,000,000 /
MAX_STRING_SIZE ) is 0.000132 seconds per conversion. Is
The solution appears to be to use the cvtFast library where it is in
range in GDD’s aitConvert.cc. The cvtFast functions are a bit scary in
today’s world - because a buffer size isn’t passed in – BTW. The
current workaround is to just not use them for buffer sizes below some
threshold.
Jeff
- RE: epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc Jeff Hill
<2009>
2025
2026
<2009>
2025
2026
