Jeff, In your first option, you mentioned two ideas: (1) Remove reference counting from gdd's public interface (2) Add a factory method to gdd If I understand right, the purpose of (1) is to give compile-time error if users try to compile existing code, and the purpose of (2) is to return a smartGDDPointer with correct reference count. Also, the factory method in gdd class is a static function to create gdd instances, inside the factory function unreference() is called immediately after a new gdd instance is created. But if we provide a factory method in gdd class, shall we also provide the same method in gdd's two subclasses: gddScalar and gddArray. gddScalar has 4 constructors and gddArray has 6 constructors. So there are 16 constructors to handle in total. Here is one thing comes into my mind, is it better to introduce an independent factory class which is responsible for creating gdd and its subclass instances and returning smartGDDPointers? Thanks, Alex
> Why not add a gdd factory method to the smartGDDPointer API, so the user > never needs to do a 'new gdd' themselves? > > smartGDDPointer pDD1; // Empty > pDD1.newGdd(); // Create one I did mention, in my message, that a factory was the first option. I suspect that we can all agree (based on the advantage of hindsight) that a factory producing a smart pointer would have been a better design. The controversy arises when considering what to do about the reference and un-reference interface in gdd, which appears to be somewhat broken by modern convention. In Jim's defense - some time has passed since he implemented the gdd interface, and I added a smart pointer a few years after gdd was written. The controversy arises, of course, surrounding changing the gdd interface which is in use. Unfortunately, unless one removes referencing, and also new, from the gdd interface, then this still does not prevent someone from inadvertently doing this. This type of unfortunate pitfall is what Alex and others have experienced - and complained about. gdd * pGDD = new gdd(); ... smartGDDPointer pDD1; // Empty pDD1.newGdd(); //create 1st one ... smartGDDPointer pDD1 = pGDD; // replace with 2nd, woops forgot to call pGDD->unreferenced() Admittedly, adding the factory, but not amending the gdd interface (maybe in sum what you are advocating) might be slightly safer because the user would be better guided into a mainstream usage pattern. BTW: Is there a reason why you have a preference: // this smartGDDPointer pDD1; // Empty pDD1.newGdd(); // Create one // versus this (what I would probably implement lacking further input) smartGDDPointer pDD1 = gdd :: factory (); // Create one A messy aspect of factories is that one must replicate all of the various ctor signatures for the various modes of the target. I think that there are six of them with gdd. Maybe not so bad. Jeff ______________________________________________________ Jeffrey O. Hill Email [email protected] LANL MS H820 Voice 505 665 1831 Los Alamos NM 87545 USA FAX 505 665 5107 Message content: TSPA > -----Original Message----- > From: Andrew Johnson [mailto:[email protected]] > Sent: Friday, August 28, 2009 11:56 AM > To: Jeff Hill > Cc: [email protected]; Core-Talk > Subject: Re: About the reference counting in GDD smart pointer > > Hi Jeff, > > On Friday 28 August 2009 10:55:04 Jeff Hill wrote: > > > > Some options > > ------------ > > Why not add a gdd factory method to the smartGDDPointer API, so the user > never needs to do a 'new gdd' themselves? > > smartGDDPointer pDD1; // Empty > pDD1.newGdd(); // Create one > > > // the smart pointer maintains the ref count > > smartGDDPointer pDD2 = pDD1; > > smartGDDPointer pDD3 = pDD2; > > pDD2 = pDD3; > > - Andrew > -- > The best FOSS code is written to be read by other humans -- Harold Welte
| ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
