2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: devLib ruminations
To: "Andrew Johnson" <[email protected]>, <[email protected]>
Date: Fri, 13 Nov 2009 08:40:50 -0500
Hi Andrew,
Thanks for the comments.
> On Tuesday 10 November 2009 14:13:18 Davidsaver, Michael wrote:
> > 1) No 'virtual os' table behind the devLib PCI api.
> I think a virtual table would still be useful for the multiple platforms that
> devLib has to be able to support - the plug-in defines the boundary between
> the generic API and the platform-specific code.  If you don't do that, you
> either have to define a platform interface separately, or implement the devLib
> PCI code separately for each platform.
Instead of function pointers I would just use the usual osi+osd function pairs.  User calls osiFoo() which does some common operations, then osiFoo() calls osdFoo() which is specialized for the target.
> We have discovered that in practice it makes life much simpler to be able to
> compile and create libraries containing our device support code for all our
> IOC platforms, even though there is no actual devLib VME implementation
> available for Solaris or Darwin (yet).  The place where an error should be
> reported would be when trying to link an IOC executable on a platform that has
> no plug-in; I'd prefer that it not be quite as late as run-time if possible
> though.
In an expanded devLib PCI code needs to be able to work for targets which have no VME support, and vice versa.
While I would agree that run-time is too late, I think that link-time is also too late.  Missing symbols are not a very friendly way to find out.  Compile time is better since more informative error messages can be given with the #error directive.
I would make 2 changes.  First, osi/os/default/devLib*.c would contain a stub implementation to give something to link against.  Second, create a header called osi/os/*/devLibConfig.h which would #define HAVE_DEVLIBVME and HAVE_DEVLIBPCI.  Trying to include 'devLibPCI.h' when HAVE_DEVLIBPCI is not defined would be an #error.
Call this the 'autoconf' approach.
> <snip>
> > 3) Add callback hooks for some specific operations.  This could be used
> > for BSP specific quirks.  Before and after read/write probing would be
> > one example.
> Can't the BSP wrap its own probe routine if necessary?  VxWorks allow its BSPs
> to do that: vxMemProbe() vectors through the _func_vxMemProbeHook function
> pointer which the BSP usually sets.  I'm not sure this should be part of
> devLib.
Fine.  I just wanted to put this out as a possibility.
> > So far I have been working with the 'virtual os' table concept.  I have
> > been in contact with Graham Waters of TRIUMF about their use of Linux
> > with devLib.  It looks like a straight forward piece of code which wraps
> > a vendor provided library for the Universe2.  It is not designed to
> > insert itself at runtime.
> Right, but it doesn't require any changes to Base to use it; when you compile
> Base for Linux you don't know whether you're going to be using the TRIUMF
> plugin or not.  I don't want there to be a configuration switch, because we
> need to be able to use the same build of Base to create both kinds of IOC.  If
> there's an alternative to the 'virtual os' table though I'd like to hear it
> (some vxWorks targets don't support weak symbols by the way, so they won't
> help).
I think what you mean is that you don't want a single global configuration switch.  You are correct that this wouldn't work.
> > I have begun to wonder about the wisdom of maintaining the 'virtual os'
> > plugin interface when there is only one plugin for it.  This is
> > especially true for the PCI interface.  Both RTEMS and VxWorks have one
> > uniform complete interface for PCI access, and Linux has none (for
> > userspace).
> I don't follow your statement that "there is only one plugin for it."  Both
> RTEMS and vxWorks provide plug-ins for the interface.  The issue that I have
> with it is that a number of routines were added to devLib that don't go
> through the function table, duplicating existing functionality in some cases.
Yes, they each provide _A_ plugin.  There is _A_ plugin for Linux.  The plugin functionality is not being used.
I agree that if we use the pointer table it should be all or nothing.  I have a patch set from the code-a-thon which corrects the current situation, which I will post later today.
> <snip>
> > However, most people will only deal with systems having a single VME
> > bridge (bus #0).  The question is if it is worthwhile to change the api
> > for a corner case?
> I like Ralph's idea, which also gives you more flexibility to change the API
> if you need to.
The question was: Should devLibVME handle multiple VME bridges?  This sounds like a yes.
If so then the above only applies to the purposed new PCI part of devLib.  The VME part would still use a pointer table, or rather tables.
Michael
Re: devLib ruminations Andrew Johnson
RE: devLib ruminations Davidsaver, Michael
Prev: Re: devLib ruminations Andrew Johnson
Next: Re: devLib ruminations Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
