Hi Eric,
I may be missing something, but this code actually looks OK to me. Note
that valend is a pointer, not a counter. So if valend actually points
to the last character in the buffer then the statement
if ( v <= valend ) *v = '\0';
should be OK, right?
But it's certainly possible that valend has not been set correctly, and
that it is pointing to one character past the end of the buffer. I have
not looked into that.
-----Original Message-----
Sent: Tuesday, March 30, 2010 6:46 PM
To: Andrew Johnson
Cc: Mark Rivers; Core-Talk
Subject: Re: Bug in macLib
Hmm.....
Check the last 'if' statement in mcaCore.c: trans....
static void trans( MAC_HANDLE *handle, MAC_ENTRY *entry, int level,
const char *term, const char **rawval, char **value,
char *valend )
char quote;
const char *r;
char *v;
int discard;
int macRef;
/* return immediately if raw value is NULL */
if ( *rawval == NULL ) return;
/* discard quotes and escapes if level is > 0 (i.e. if these aren't
the user's quotes and escapes) */
discard = ( level > 0 );
/* debug output */
if ( handle->debug & 2 )
printf( "trans-> entry = %p, level = %d, maxlen = %u, discard =
%s, "
"rawval = %s\n", entry, level, (unsigned int)(valend - *value),
discard ? "T" : "F", *rawval );
/* initially not in quotes */
quote = 0;
/* scan characters until hit terminator or end of string */
for ( r = *rawval, v = *value; strchr( term, *r ) == NULL; r++ ) {
/* handle quoted characters (quotes are discarded if in name) */
if ( quote ) {
if ( *r == quote ) {
quote = 0;
if ( discard ) continue;
else if ( *r == '"' || *r == '\'' ) {
quote = *r;
/* macro reference if '$' followed by '(' or '{' */
macRef = ( *r == '$' &&
*( r + 1 ) != '\0' &&
strchr( "({", *( r + 1 ) ) != NULL );
/* macros are not expanded in single quotes */
if ( macRef && quote != '\'' ) {
/* Handle macro reference */
refer ( handle, entry, level, &r, &v, valend );
else {
/* handle escaped characters (escape is discarded if in
name) */
if ( *r == '\\' && *( r + 1 ) != '\0' ) {
if ( v < valend && !discard ) *v++ = '\\';
if ( v < valend ) *v++ = *++r;
/* copy character to output */
else {
if ( v < valend ) *v++ = *r;
/* ensure string remains properly terminated */
Eric Norum
[email protected]
- Re: Bug in macLib Eric Norum
- Bug in macLib Mark Rivers
- Re: Bug in macLib Andrew Johnson
<2010>
2025
2026
<2010>
2025
2026
