On Wednesday 31 March 2010 11:00:30 you wrote:
> Ah, I see. So is this a better change to macExpandString?
> --- macCore.c.orig 2010-03-31 08:31:20.000000000 -0700
> +++ macCore.c 2010-03-31 08:58:32.000000000 -0700
> @@ -198,6 +198,10 @@
> if ( handle->debug & 1 )
> printf( "macExpandString( %s, maxlen = %ld )\n", src, maxlen );
> + /* Check size */
> + if (maxlen <= 1)
> + return -1;
> /* expand raw values if necessary */
> if ( expand( handle ) < 0 )
> errlogPrintf( "macExpandString: failed to expand raw values\n" );
> @@ -211,7 +215,7 @@
> s = src;
> d = dest;
> *d = '\0';
> - trans( handle, &entry, 0, "", &s, &d, d + maxlen );
> + trans( handle, &entry, 0, "", &s, &d, d + maxlen - 1 );
> /* return +/- #chars copied depending on successful expansion */
> length = d - dest;
Actually I think the real bugs only occur in macEnvExpand() and in the
function check() in macLibTest.c, but given the unusual definition of the
maxlen parameter I think it would be safest to change the parameter meaning as
you suggest (maybe rename maxlen to buflen?) *and* modify all the places where
it's currently used correctly.
If you generate a patch for this, please:
1. Also modify the comment describing the maxlen parameter, to clarify
2. Fix the length argument in the calls to macExpandString() in
db_yyinput() - dbStatic/dbLexRoutines.c
myInputFunction() - as/asLibRoutines.c
3. Attach it to a comment on the Launchpad bug report
https://bugs.launchpad.net/epics-base/+bug/551909
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Bug in macLib Mark Rivers
- Re: Bug in macLib Andrew Johnson
naming the operating system independence layer Jeff Hill
<2010>
2025
2026
RE: Bug in macLib Mark Rivers
<2010>
2025
2026
