2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base
To: [email protected]
Date: Wed, 26 May 2010 16:16:26 -0000
In Ronaldo's defence, much of this code came from the 'capr' program that John Maclean wrote and which is in use at APS.  It has already been converted from using EZCA via the Extensions version of caget, hence the strings you see.  They do need changing though, and should probably be replaced with the native DBF_* strings.
Please make sure you test on record types that have a DBF_ULONG field, which CA will report as having a native type of DBF_DOUBLE.
https://code.launchpad.net/~ronaldo-mercado/epics-base/capr/+merge/26037
Your team EPICS Core Developers is requested to review the proposed merge of lp:~ronaldo-mercado/epics-base/capr into lp:epics-base.
RE: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Ronaldo Mercado
Prev: Re: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Ralph Lange
Next: Re: [Merge] lp:~khkim/epics-base/fix-timestamp into lp:epics-base Kim, Kukhee
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Ronaldo Mercado
