Subject: |
[Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base |
Ronaldo Mercado <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 26 May 2010 11:17:25 -0000 |
Ronaldo Mercado has proposed merging lp:~ronaldo-mercado/epics-base/capr into lp:epics-base.
Requested reviews:
EPICS Core Developers (epics-core)
>From "Rewrite capr and add to Base" at
http://www.aps.anl.gov/epics/wiki/index.php/Future_Development_Ideas
Modified capr to use perl-CA library. Still using John Maclean's parser which seems
good enough for the task.
Added capr.pl under src/cap5 and marked for installation along other perl scripts.
It uses the perl-CA library doing simultaneous pull of the several fields needed.
Removed the default dbd file because there is no sensible default across facilities.
https://code.launchpad.net/~ronaldo-mercado/epics-base/capr/+merge/26037
Your team EPICS Core Developers is requested to review the proposed merge of lp:~ronaldo-mercado/epics-base/capr into lp:epics-base.
=== modified file 'src/cap5/Makefile'
--- src/cap5/Makefile 2009-11-25 18:24:09 +0000
+++ src/cap5/Makefile 2010-05-26 11:17:24 +0000
@@ -29,6 +29,7 @@
PERL_SCRIPTS += cainfo.pl
PERL_SCRIPTS += caput.pl
PERL_SCRIPTS += caget.pl
+ PERL_SCRIPTS += capr.pl
PERL_SCRIPTS += camonitor.pl
PERL_MODULES += CA.pm
=== added file 'src/cap5/capr.pl'
--- src/cap5/capr.pl 1970-01-01 00:00:00 +0000
+++ src/cap5/capr.pl 2010-05-26 11:17:24 +0000
@@ -0,0 +1,455 @@
+#!/usr/bin/perl -w
+# capr: A program that attempts to do a "dbpr" command via channel
+# access.
+use strict;
+use FindBin qw($Bin);
+use lib "$Bin/../../lib/perl";
+use Getopt::Std;
+use CA;
+######### Globals ##########
+my $hostArch;
+if ( defined $ENV{"EPICS_HOST_ARCH"} ) {
+ $hostArch = $ENV{"EPICS_HOST_ARCH"} ;
+} else {
+ $hostArch="solaris-sparc";
+our( $opt_h, $opt_d, $opt_f, $opt_r);
+my $theDbdFile;
+my %record = (); # Empty hash to put dbd data in
+my $iIdx = 0; # Array indexes for interest, data type and base
+my $tIdx = 1;
+my $bIdx = 2;
+my %device = (); # Empty hash to record which rec types have device support
+my $DEBUG=0; # DEBUG
+# EPICS field types referenced to their equivalent EZCA types
+my %fieldType = (
+ DBF_STRING => "ezcaString",
+ DBF_BYTE => "ezcaByte",
+ DBF_CHAR => "ezcaByte",
+ DBF_UCHAR => "ezcaChar",
+ DBF_SHORT => "ezcaShort",
+ DBF_USHORT => "ezcaLong",
+ DBF_LONG => "ezcaLong",
+ DBF_ULONG => "ezcaDouble",
+ DBF_FLOAT => "ezcaFloat",
+ DBF_DOUBLE => "ezcaDouble",
+ DBF_ENUM => "ezcaString",
+ DBF_MENU => "ezcaString",
+ DBF_DEVICE => "ezcaString",
+ DBF_INLINK => "ezcaString",
+ DBF_OUTLINK => "ezcaString",
+ DBF_FWDLINK => "ezcaString",
+ DBF_NOACCESS => "ezcaNoAccess"
+# globals for sub caget
+my %callback_data;
+my $callback_incomplete;
+my $cadebug = 0;
+######### Main program ############
+HELP_MESSAGE() unless getopts('hd:f:r');
+HELP_MESSAGE() if $opt_h;
+# Select the dbd file to use
+if($opt_d) { # command line has highest priority
+ $theDbdFile = $opt_d;
+elsif (exists $ENV{CAPR_DBD_FILE}) { # Use the env var if it exists
+ $theDbdFile = $ENV{CAPR_DBD_FILE};
+} # Otherwise use the default set above
+else {
+ die "No dbd file defined. ('capr.pl -h' gives help)\n";
+parseDbd($theDbdFile);
+print "Using $theDbdFile\n\n";
+# Print a list of record types
+if($opt_r) {
+ print ("Record types defined in $theDbdFile\n");
+ printList(0);
+ exit;
+# Print the fields defined for given record
+if($opt_f) {
+ printRecordList($opt_f);
+ exit;
+# Do the business
+# Allow commas between arguments as in vxWorks dbpr
+HELP_MESSAGE() unless defined $ARGV[0];
+$ARGV[0] =~ s/,/ /; # Get rid of pesky comma if it's there
+if($ARGV[0] =~ m/\s+\d/) { # If we replace comma with a space,
+ ($ARGV[0], $ARGV[1]) = split(/ /, $ARGV[0]); #split it
+$ARGV[0] =~ s/\s+//; # Remove any spaces
+$ARGV[0] =~ s/\..*//; # Get rid of field name if it's there
+$ARGV[1] = 0 unless defined $ARGV[1]; # default interest level is 0
+$ARGV[1] =~ s/\D//g; # Make sure we only use digits
+$ARGV[1] = $ARGV[1] || 0; # interest defaults to 0
+printRecord($ARGV[0], $ARGV[1]); # Do the do
+########## End of main ###########
+# parseDbd
+# takes given dbd file and parses it to produce a hash table of record types
+# giving their fields, and for each field its interest level and data type
+# usage: void parseDbd("fileName");
+# Output is in the hash %record. This is a hash of (references to) another.
+# hash containing the fields of this record, as keys. The value keyed by
+# the field names are (references to) arrays. Each of these arrays contains
+# the interest level, data type and base of the field
+sub parseDbd {
+ my $dbdFile = $_[0];
+ my @dbd;
+ my $length;
+ my $level = 0;
+ my $i = 0;
+ my $isArecord = 0;
+ my $isAfield;
+ my $thisRecord;
+ my $thisField;
+ my $thisType;
+ my %field = ();
+ my @params = ();
+ my $interest = 0;
+ my $thisBase = "DECIMAL";
+ my $item;
+ my $newDevice;
+ open(DBD, "< $dbdFile") || die "Can't open dbd file $dbdFile --";
+ @dbd = <DBD>;
+ $length = @dbd;
+ close(DBD) || die "Can't close $dbdFile --";
+ while ($i < $length) {
+ $_ = $dbd[$i];
+ chomp;
+ print("line $i - level $level\n") if ($DEBUG);
+ #$line = $dbd[$i] || die "Unexpected end of file: $dbdFile, line $.";
+ if( m/recordtype/ ) {
+ ($level == 0) || die "dbd file format error in or before line $i --";
+ m/\((.*)\)/; #get record type
+ #@records = (@records, $1);
+ $isArecord = 1;
+ $thisRecord = $1;
+ if( m/field/ ) {
+ ($level == 1 && $isArecord) || die "dbd file format error in or before line $i --";
+ m/\((.*),/; # get field name
+ $thisField = $1;
+ m/,(.*)\)/; # get field type
+ $thisType = $1;
+ $isAfield = 1;
+ #print("$1 , line $i ");
+ if( m/interest/ ) {
+ ($level == 2 && $isAfield) || die "dbd file format error in or before line $i --";
+ m/\((.*)\)/ ; # get interest level, default = 0
+ $interest = $1;
+ if( m/base/ ) {
+ m/\((.*)\)/ ; # get base, default = DECIMAL
+ $thisBase = $1;
+ if( m/\{/ ) { $level++ };
+ if( m/\}/ ) {
+ if( $level == 2 && $isAfield) {
+ $isAfield = 0;
+ $params[$iIdx] = $interest;
+ $params[$tIdx] = $thisType;
+ $params[$bIdx] = $thisBase;
+ $field{$thisField} = [@params];
+ #print("interest $interest\n");
+ $interest = 0; # set up default for next time
+ $thisBase = "DECIMAL"; # set up default for next time
+ if( $level == 1 && $isArecord) {
+ $isArecord = 0;
+ $record{$thisRecord} = { %field };
+ #print("record type $thisRecord ");
+ #foreach $key (keys(%field)) {
+ # print("Field $key - interest $field{$key}\n");
+ %field = (); # set up for next time
+ $level--;
+ # Parse for record types with device support
+ if( m/device/ ) {
+ m/\((.*?),/;
+ if(!exists($device{$1})) {
+ # Use a hash to make a list of record types with device support
+ $device{$1} = 1;
+ $i++;
+# Given a record name attempts to find the record and its type.
+# Usage: getRecType(recordName) - returns ($error, $recordType)
+sub getRecType {
+ my $name = $_[0] . ".RTYP";
+ my $type;
+ my $data;
+ my $fields_read = caget( $name );
+ if ( $fields_read != 1 ) { die "Record \"$_[0]\" not found\n"; }
+ $data = $callback_data{ $name };
+ chomp $data;
+ $data =~ s/\s+//;
+ #print("$name is a \"$data\"type\n");
+ return($data);
+# Given the record type and the field returns the interest level, data type
+# and base for the field
+# Usage: ($dataType, $interest, $base) getFieldParams( $recType, $field)
+sub getFieldParams {
+ my $recType = $_[0];
+ my $field = $_[1];
+ my ($fType, $fInterest, $fBase);
+ exists($fieldType{$record{$recType}{$field}[$tIdx]}) ||
+ die "Field data type $field for $recType not found in dbd file --";
+ exists($record{$recType}{$field}[$iIdx]) ||
+ die "Interest level for $field in $recType not found in dbd file --";
+ $fType = $fieldType{$record{$recType}{$field}[$tIdx]};
+ $fInterest = $record{$recType}{$field}[$iIdx];
+ $fBase = $record{$recType}{$field}[$bIdx];
+ return($fType, $fInterest, $fBase);
+# Prints field name and data for given field. Formats output so
+# that fields align in to 4 columns. Tries to imitate dbpf format
+# Usage: printField( $fieldName, $data, $dataType, $base, $firstColumnPosn)
+sub printField {
+ my $fieldName = $_[0];
+ my $fieldData = $_[1];
+ my $dataType = $_[2];
+ my $base = $_[3]; # base to display numeric data in
+ my $col = $_[4]; # first column to print in
+ my $screenWidth = 80;
+ my ($outStr, $len, $wide, $pad, $field);
+ $field = $fieldName . ":";
+ if( $dataType eq "ezcaString" ) {
+ $outStr = sprintf("%-5s %s", $field, $fieldData);
+ } elsif ( $base eq "HEX" ) {
+ $outStr = sprintf("%-5s %x", $field, $fieldData);
+ } elsif ( $dataType eq "ezcaDouble" || $dataType eq "ezcaFloat" ) {
+ $outStr = sprintf("%-5s %.8f", $field, $fieldData);
+ } elsif ( $dataType eq "ezcaChar" ) {
+ $outStr = sprintf("%-5s %d", $field, ord($fieldData));
+ }else {
+ # ezcaByte, ezcaShort, ezcaLong
+ $outStr = sprintf("%-5s %d", $field, $fieldData);
+ $len = length($outStr);
+ if($len <= 20) { $wide = 20; }
+ elsif( $len <= 40 ) { $wide = 40; }
+ elsif( $len <= 60 ) { $wide = 60; }
+ else { $wide = 80;}
+ $pad = $wide - $len;
+ if( $col + $wide > $screenWidth ) {
+ print("\n");
+ $col = 0;
+ print sprintf("$outStr%*s",$pad," ");
+ $col = $col + $wide;
+ return($col);
+# Query for a list of fields simultaneously.
+# The results are filled in the the %callback_data global hash
+# and the result of the operation is the number of read pvs
+# NOTE: Not re-entrant because results are written to global hash
+# %callback_data
+# Usage: $fields_read = caget( @pvlist )
+sub caget {
+ my @chans = map { CA->new($_); } @_;
+ my $wait = 1;
+ #clear results;
+ %callback_data = ();
+ eval { CA->pend_io($wait); };
+ if ($@) {
+ if ($@ =~ m/^ECA_TIMEOUT/) {
+ my $err = (@chans > 1) ? 'some PV(s)' : "'" . $chans[0]->name . "'";
+ print "Channel connect timed out: $err not found.\n";
+ foreach my $chan (@chans) {
+ $callback_data{$chan->name} = "<timeout>"
+ unless $chan->is_connected;
+ @chans = grep { $_->is_connected } @chans;
+ } else {
+ die $@;
+ map {
+ my $type;
+ $type = $_->field_type;
+ #$callback_data{$_->name} = undef;
+ $_->get_callback(\&caget_callback, $type);
+ } @chans;
+ my $fields_read = @chans;
+ $callback_incomplete = @chans;
+ CA->pend_event(0.1) while $callback_incomplete;
+ return $fields_read;
+sub caget_callback {
+ my ($chan, $status, $data) = @_;
+ die $status if $status;
+ $callback_data{$chan->name} = $data;
+ $callback_incomplete--;
+# Given record name and interest level prints data from record fields
+# that are at or below the interest level specified.
+# Usage: printRecord( $recordName, $interestLevel)
+sub printRecord {
+ my $name = $_[0];
+ my $interest = $_[1];
+ my ($error, $recType, $field, $fType, $fInterest, $data);
+ my ($fToGet, $col, $base);
+ #print("checking record $name, interest $interest\n");
+ $recType = getRecType($name);
+ print("$name is record type $recType\n");
+ exists($record{$recType}) || die "Record type $recType not found in dbd file --";
+ #capture list of fields
+ my @readlist = (); #fields to read via CA
+ my @fields_pr = (); #fields for print-out
+ my @ftypes = (); #types, from parser
+ my @bases = (); #bases, from parser
+ foreach $field (sort keys %{$record{$recType}}) {
+ # Skip DTYP field if this rec type doesn't have device support defined
+ if($field eq "DTYP" && !(exists($device{$recType}))) { next; }
+ ($fType, $fInterest, $base) = getFieldParams($recType, $field);
+ unless( $fType eq "ezcaNoAccess" ) {
+ if( $interest >= $fInterest ) {
+ $fToGet = $name . "." . $field;
+ push @fields_pr, $field;
+ push @readlist, $fToGet;
+ push @ftypes, $fType;
+ push @bases, $base;
+ my $fields_read = caget( @readlist );
+ # print while iterating over lists gathered
+ $col = 0;
+ for (my $i=0; $i < scalar @readlist; $i++) {
+ $field = $fields_pr[$i];
+ $fToGet = $readlist[$i];
+ $data = $callback_data{$fToGet};
+ $fType = $ftypes[$i];
+ chomp $data;
+ $col = printField($field, $data, $fType, $base, $col);
+ print("\n"); # Final line feed
+# Prints list of record types found in dbd file. If level > 0
+# then the fields of that record type, their interest levels and types are
+# also printed.
+# Diagnostic routine, usage: void printList(level);
+sub printList {
+ my $level = $_[0];
+ my ($rkey, $fkey);
+ foreach $rkey (sort keys(%record)) {
+ print("$rkey\n");
+ if($level > 0) {
+ foreach $fkey (keys %{$record{$rkey}}) {
+ print("\tField $fkey - interest $record{$rkey}{$fkey}[$iIdx] ");
+ print("- type $record{$rkey}{$fkey}[$tIdx] ");
+ print("- base $record{$rkey}{$fkey}[$bIdx]\n");
+# Prints list of fields with interest levels for given record type
+# Diagnostic routine, usage: void printRecordList("recordType");
+sub printRecordList {
+ my $type = $_[0];
+ if( exists($record{$type}) ) {
+ print("Record type - $type\n");
+ foreach $fkey (sort keys %{$record{$type}}) {
+ printf("%-4s", $fkey);
+ printf(" interest = $record{$type}{$fkey}[$iIdx]");
+ printf(" type = %-12s ",$record{$type}{$fkey}[$tIdx]);
+ print (" base = $record{$type}{$fkey}[$bIdx]\n");
+ else {
+ print("Record type $type not defined in dbd file $theDbdFile\n");
+sub HELP_MESSAGE {
+ print STDERR "\n",
+"Usage: capr.pl -h\n",
+" capr.pl [-d dbd_file] -r\n",
+" capr.pl [-d dbd_file] -f <record_type>\n",
+" capr.pl [-d dbd_file] <record_name> <interest>\n",
+"Description:\n",
+" Attempts to perform a record print \"dbpr\" via channel access\n",
+" for record_name at a given interest level.\n",
+" The default interest level is 0.\n\n",
+" If used with the f or r options, prints fields/record type lists.\n",
+"\n",
+"Options:\n",
+" -h: Help: Prints this message\n",
+" -d Dbd file: specify dbd file used to read record definitions.\n",
+" If omitted, the environment variable CAPR_DBD_FILE must be defined\n",
+" -r Prints the list of record types\n",
+" -f Prints list of fields, interest level, type and base for the\n",
+" given record type\n",
+"\n";
+ exit 1;
- Re: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Andrew Johnson
- Re: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Ralph Lange
- Re: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Ronaldo Mercado
[Merge] lp:~khkim/epics-base/fix-timestamp into lp:epics-base Kim, Kukhee
<2010>
2025
2026
Re: [Merge] lp:~khkim/epics-base/fix-timestamp into lp:epics-base Ralph Lange
<2010>
2025
2026
